Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 10-09-2010, 09:23 PM   #76
texastrendz
Re: D52 Caliper Rear Disc Brake Brackets
pm sent, as well as the money
texastrendz is offline   Reply With Quote
Old 10-23-2010, 09:22 PM   #77
texastrendz
got my brackets, i need the years for the parts that i need. like rotors, calipers and things of that nature
Old 10-23-2010, 11:33 PM   #78
Captainfab
60-66 Nut
The applications and years are listed on the first page of this thread.
Basically you will need front rotors for a '92-'02 AWD Astro/Safari van. The D52 calipers were used on the trucks from '71-'87, as well as many full sized cars from the 60's and 70's. If you need a D52 caliper with a built in e-brake you will need the rear calipers for a '76-'78 Eldorado. As for hoses you can either use hoses from a '71-'72 pickup, hoses for a '79 Chevette, or any of the aftermarket braided stainless hoses.
Is there any other parts you need help with?
Old 10-24-2010, 01:54 PM   #79
texastrendz
that is exactly what i needed. thanks for the quick response, brackets are beefy. not going to be any flex in them. nice
Old 10-27-2010, 02:22 AM   #80
shiner2001
shiner2001's Avatar
Originally Posted by Captainfab View Post
Those are the Eldorado D52 calipers with the built in e-brake. Those are the ones you would use if you need an e-brake on this conversion. If you turn those in as cores, make sure you keep the e-brake levers. As far as I know you cannot buy replacements for them. And yes you can use 15" wheels as long as they are disc brake compatable.
If I were to buy new calipers from the parts store, does that mean that they will not come with everything needed to run an e-brake? Are there parts that will ultimately have to be found used or in a junkyard? I was planning on not running an e-brake, but it hadn't occurred to me that it was necessary for the state safety inspection, so I'll have to go with the Caddy calipers it looks like. Anyone had an experience with finding the Caddy calipers new with the e-brake setup? I don't actually think that for the safety inspection that they usually even check the e-brake, but I'd rather be safe than sorry and not be able to pass inspection sometime down the road.
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 10-27-2010, 11:55 PM   #81
Captainfab
60-66 Nut
I haven't bought the Eldorado calipers myself, but I have read that they don't come with the arms for the e-brake. Some guys have made their own using the correct size wrench. If you get a set of the Eldorado calipers and they don't come with the arms, and you can't get the issue solved, let me know and I'll get you taken care of.
BTW, your brackets shipped today. You should see them Saturday or Monday at the latest. Thanks again.
Old 10-28-2010, 12:25 AM   #82
shiner2001
shiner2001's Avatar
I got the shipping info today, I appreciate it. As far as the calipers go, I haven't taken a look at any yet in person, so I'm not familiar with them. If anyone has any photos of what they look like in stock form and with a fabbed e-brake set up, that would be awesome. When you say with the correct size wrench, what exactly are you referring to? Sorry for being so in the dark about it all, like I said, I haven't had the calipers in my hands to see for myself yet.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 10-28-2010, 11:03 AM   #83
68 TT
Still plays with trucks
68 TT's Avatar
I have a set of the Eldorado calipers at home. I will dig them out and post some pics of them this weekend.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-28-2010, 11:07 AM   #84
shiner2001
shiner2001's Avatar
That would be fantastic! And if you'd care to sell them...I know a guy in Texas that would probably take them off your hands.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 10-28-2010, 11:20 AM   #85
68 TT
68 TT's Avatar
I have three projects of my own fighting over which one will get the Eldorado calipers I have. I will let you know if I come across any more.
Old 10-28-2010, 11:22 AM   #86
shiner2001
shiner2001's Avatar
I completely understand that. I will be more than thankful just to get some good pictures of them. May head over to the junkyard in a bit and see if I can get lucky enough to find a set.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 10-28-2010, 12:13 PM   #87
MrClean
I'LL TRY TO FIX IT!
MrClean's Avatar
I found these awhile back, but they are way out of my budget
http://www.tsmmfg.com/3121.htm
-- Jorge --
1972 Custom/10 LWB 350
My Build
MrClean is offline   Reply With Quote
Old 10-31-2010, 02:30 PM   #88
texastrendz
capt. fab,
i have assembled my rear disc brake kit(d-52 style) and noticed the outer pad is dragging on the rotor hat. is this normal, or should i be concerned? looking at your post of the installed pads it looks like yours are touching as well. is this going to create a singing noise or a vibration in the braking system? thanks again.
Old 10-31-2010, 07:40 PM   #89
cpetersen
cpetersen's Avatar
Size:  75.5 KB Make sure you that you keep the E-Brake brackets.
cpetersen is offline   Reply With Quote
Old 10-31-2010, 07:41 PM   #90
shiner2001
shiner2001's Avatar
Originally Posted by cpetersen View Post
Attachment 650448 Make sure you that you keep the E-Brake brackets.
Can you post some other angles of that? Particularly the e-brake bracket...many thanks!
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 10-31-2010, 07:42 PM   #91
cpetersen
cpetersen's Avatar
Did you also put longer wheel studs in?
Old 10-31-2010, 10:19 PM   #92
Captainfab
60-66 Nut
The assembled brackets shown in the pics were the prototype's. And yes the pads were touching the 'hat' of the rotor. After seeing that issue, I made the caliper brackets 1/16" longer to move the caliper farther from center. This is the first that I've heard of anyone having the pads touching the 'hat of the rotor. I suppose there is a certain amount of variances with different pad manufacturers. I don't know if this would create any noises or issues. Do you have a way to grind down the flange on the pads where they touch?
capt. fab,
Old 10-31-2010, 11:16 PM   #93
texastrendz
i resolved the issue by clearancing the contact area of the pad on the caliper itself. i think by grinding the pad i was not resolving the issue. by clearancing the caliper i now can replace the pads without any issue in the future. i only have about .040 clearance. since this is a floating caliper i think it will be fine. i tweaked the mounting tabs of the pads to pull it tight against the caliper not not let is float as much. seems to look o.k. i used a napa brand semi metalic pad.
Old 12-02-2010, 08:22 PM   #94
SBTork
Garage wrench
SBTork's Avatar
These look awesome and I will be getting a set in the future. I just want to make sure of one thing. I can use my stock master cylinder and just add an adjustable proportioning valve and they should work fine, correct?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 12-03-2010, 12:50 AM   #95
Captainfab
60-66 Nut
Some guys get away with doing that, but it isn't the correct master cylinder to use. Since you're replacing the rear wheel cylinders with calipers, you need more volume to the rear. So the best master cylinder to use is one designed for a disc/disc brake system. Then you can either install a disc/disc proportioning valve, or install an adjustable proportioning valve in the rear line. The Wilwood unit I posted a pic of above is a nice all in one unit.
Old 12-09-2010, 02:17 PM   #96
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
PM sent
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-10-2010, 01:16 AM   #97
Captainfab
60-66 Nut
PM returned....thanks
Originally Posted by Captkaos View Post
PM sent
Old 01-06-2011, 06:14 AM   #98
shiner2001
shiner2001's Avatar
Anyone ever come up with any more e-brake solutions other than the Caddy calipers?
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 01-07-2011, 12:36 AM   #99
Captainfab
60-66 Nut
I've been looking into the possibility of adding another caliper to the assembly that is mechanically operated.
Old 01-07-2011, 01:38 AM   #100
shiner2001
shiner2001's Avatar
Sounds good to me. I'll be keeping my eyes peeled for any updates!
Derek
79 Scout II 345
01 GMC Yukon 5.3L
