Old 12-16-2010, 11:51 PM   #76
BrianS
Re: show your67 72 chevy spot light trucks
yes. shortly after i got the truck home.
BrianS is offline   Reply With Quote
Old 12-16-2010, 11:59 PM   #77
67chevy1series
67chevy1series's Avatar
well glad it works when you drive you have to have it pointed down to you r roof ?????
67chevy1series is offline   Reply With Quote
Old 12-17-2010, 12:01 AM   #78
BrianS
what do you mean? it isnt on all the time, its on a switch. when im driving it, it will face down im sure. i got a while before that happens though.
Old 12-17-2010, 12:03 AM   #79
67chevy1series
ya i was just checkin becauce i was told i cant have it facing to the traffic
Old 12-17-2010, 12:04 AM   #80
BrianS
yea that makes sense.
Old 12-17-2010, 12:24 AM   #81
67chevy1series
ya cool your first posts all here are you going to put a fleetside on it
Old 12-17-2010, 12:27 AM   #82
BrianS
yes i picked up a parts truck with a clean box on it. also has a 67 front clip i may use. not sure yet.
Old 12-17-2010, 12:35 AM   #83
67chevy1series
the passenger fender s are hard to come buy in good shape ive been lookin for about a year now
Old 12-18-2010, 08:32 PM   #84
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Wahoo Ive got one too! I'll post pictures when Im done putting it back together/cleaning regreasing it..
Where can i get parts for it?..
John
1999 Toyota Tacoma 4x4
Old 12-18-2010, 09:12 PM   #85
67chevy1series
unity they stillm mak parts and there wonderful to deal with
Old 12-18-2010, 09:29 PM   #86
oldblue1968chevy
Can i get some of these clips that hold light to housings? Mine are pretty much all broken..
John
Old 12-18-2010, 09:31 PM   #87
oldblue1968chevy
Can someone help me dis assemble the gears etc below the light (exterior) it has water on it and the shaft is rusty im going to clean it up also but I cant figure out how it comes apart, I took the pin out and all the screws, but 1 of the heads broke off, im giong to have dad help me take the broken screw out when he gets home..
Is it the broken screw holding it together still or what?
John
Old 12-18-2010, 10:33 PM   #88
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Certainly looks that way..!! not sure for certain though.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 12-19-2010, 12:19 AM   #89
oldblue1968chevy
Anyone know how this comes apart Still havent figured it out lol
John
Old 12-19-2010, 12:35 AM   #90
67chevy1series
your right mine is different but mine doesnt have that ring with klips so i would need to know as well i havent taken mine apart that much
Old 12-19-2010, 02:08 PM   #91
oldblue1968chevy
Ok, According to this FAQ thing I found..
http://67-72chevytrucks.com/vboard/s...d.php?t=403869
My inner tube retaining screw broke the head off the screw. I drilled the screw out (Brass I think?) But its still not budging, But maybe Im not holding/pulling something right.?
John
Old 12-19-2010, 03:01 PM   #92
67chevy1series
that is a good FAQ
Old 12-19-2010, 07:14 PM   #93
markeb01
Senior Enthusiast
markeb01's Avatar
It appears you are trying to remove the headpost from the housing. As indicated in the marked up photo below. the open hole is for the rotation adjustment screw. It screws in flush with the housing and does not have a head on it. It’s a set screw with a slot on top. To remove the headpost, drive the retaining pin out in the direction indicated below. If it has already been removed, there is nothing else holding the headpost in place except for friction or corrosion:
Normally I’ve been able to get the headpost out by wrapping the flange with duct tape, then wiggling it back and forth with pliers until it pops out of the housing. If this doesn’t work – mount the housing into a well padded vise. Then wrap a small gear clamp around the flange as tight as you can and start tapping on the screw on the clamp with a hammer and punch until it breaks free. If it is really cruddy inside, you might need to soak it in WD40 or your favorite penetrating oil first. When these were new they used some type of waxy grease that over time can become hard enough to break to teeth on the gears.
Make sure to do all this on a clean work surface, preferably with a light colored towel on it so the parts don’t bounce around. The headpost is made up of several pieces and you want it to be easy to keep track of everything. If you cannot remove the headpost at all, it can help to remove the end cap from the forward end of the headpost housing and press up on the headpost gear from the bottom. I don’t have it indicated in the picture below, but the retaining screw for the cap is directly below the lamp on the bottom of the housing (it's the forward most screw). Normally I like to pull the headpost first, because it is easier to remove the cap by pushing out from the inside, avoiding the risk of damaging the finish by prying the cap off. But if you absolutely can’t get the headpost out, this may be the only option.
Let me know which screw you have that is broken off, or if you have any more questions.
Old 12-19-2010, 07:21 PM   #94
oldblue1968chevy
I broke off the inner tube retaining screw. I'll work on this again tonite when I get back (going to ice cream with gf shortly)
Thanks mark, that last post was VERY informative! I'll post pix when I get it all together/or on the truck. Whats a ballpark est. of what one of these things are worth in working condition?
(Not sure if im going to install it or sell it to someone, dunno if I like the look or not)
John
Old 12-19-2010, 08:29 PM   #95
markeb01
Senior Enthusiast
markeb01's Avatar
The values can cover a pretty wide range depending on the vintage of the light, but most important is the cosmetic condition of the lamp shell and the die cast chrome parts. I've bought them as cheap as $10, and seen them sell for as high as $150. eBay is loaded with listings that are way overpriced. Most don't sell for more than $50-$75 unless they have a rare and desirable mounting bracket that is unique to a specific application. There are also a few with very rare heads that can sell for up to $500, but old used spotlights with dings, dents, and pits in the chrome just aren’t worth very much.
In response to your earlier question, the bulb retaining springs are still available from Unity but are a bit spendy. So far I've always managed to come up with serviceable clips out of spare parts lamps. Here is a link to new replacements:
http://unityusa.3dcartstores.com/U-6...ing_p_353.html
If you want a mint condition lamp without much effort, you can also buy an 80's vintage lamp from eBay. I bought this one NOS for $25. I retained the vintage inner and outer tubes, and used everything else from the new lamp after adding the vintage emblem to the new lamp shell. To the casual observer it looks brand new and cost much less than a mint original or new replacement:
Old 12-19-2010, 08:34 PM   #96
67chevy1series
i would like to replace my handle assembly and the little badge at the top where it says unity or gm i need the part numbers , idont know them . i want to go on the unity site and look up so i can order them
Old 12-19-2010, 11:01 PM   #97
tcb-1
Nothing to see here.....
tcb-1's Avatar
piggybacking onto what Markeb01 said. I just went to the garage and fate had it, I had a rebuilt headpost housing laying right there in front of my. once the tension screw and the locking roll pin is out, the headpost and flange is held in by a very slight press fit. If your is a bit corroded, I'd try some type of Liquid Wrench, PB Blaster, etc to where the flange meet the headpost housing. then, very carefully, insert a sharp screwdriver between the flange and housing and try ti get some movement up. be aware that there is a spring under the headpost flange!
if all else fails, pm me again. I can fix ya up, cheap!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 12-20-2010, 12:30 AM   #98
oldblue1968chevy
Anyone have a couple of the clips they wanna sell CHEEP? lol
Im need at least 1 maybe 2 not sure
Hopefully i get my spotlight done tomorow!
John
Old 12-20-2010, 12:30 AM   #99
oldblue1968chevy
I thought the clips are spendy?! There 3 bucks! lol
John
Old 12-20-2010, 12:31 AM   #100
67chevy1series
your gonna put it on
