Old 01-04-2012, 12:09 AM   #76
docrock
docrock's Avatar
Re: My 54 GMC Build
Size:  40.0 KBwent with the 93 column. nicer wheel and operation
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 01-04-2012, 12:13 AM   #77
docrock
docrock's Avatar
Re: My 54 GMC Build
Old 01-04-2012, 12:17 AM   #78
docrock
docrock's Avatar
Re: My 54 GMC Build
Old 01-04-2012, 12:24 AM   #79
docrock
docrock's Avatar
Re: My 54 GMC Build
i had to cut the shift arm because I forgot to slide the outer tube before welding. iIt is a lot more room in the cab. Next step I think I will raise the bracket a little higher to hide the lower bracket and tighten the gap at the dash
Old 03-06-2012, 04:51 PM   #80
docrock
docrock's Avatar
Re: My 54 GMC Build
Decided my fire wall needed some bling so I cut up the original valve cover and buffed it so it would look worn. Name:  015.jpg
Old 12-12-2012, 04:27 PM   #81
docrock
docrock's Avatar
Re: My 54 GMC Build
Not much going on with this project. I have been working on a 49 Olds Woodie and a 49 Ford Woodie lately, but hopefully will get back to this project next month. Funny how time flies on these builds.
Old 01-04-2013, 10:49 PM   #82
docrock
docrock's Avatar
Re: My 54 GMC Build
i bought windshield weather strip form lmc and it didnt quite fit right and my windshield was not staying all the way in. Picked up a new one from Stelle and it fits great.
Old 01-10-2013, 08:25 PM   #83
docrock
docrock's Avatar
Re: My 54 GMC Build
Much better fit then the other seal
Old 01-10-2013, 09:57 PM   #84
docrock
docrock's Avatar
Re: My 54 GMC Build
Old 01-26-2013, 10:44 PM   #85
docrock
docrock's Avatar
Re: My 54 GMC Build
Worked on fender today. Sand fill prime repeat
Old 01-31-2013, 10:53 PM   #86
docrock
docrock's Avatar
Re: My 54 GMC Build
Posted via Mobile Devicegot some paint on a fender today
Old 01-31-2013, 11:10 PM   #87
docrock
docrock's Avatar
Re: My 54 GMC Build
Posted via Mobile Devicecleaned up the wheel and put the hub cover on. I am starting lik this truck
Old 01-31-2013, 11:26 PM   #88
docrock
docrock's Avatar
Re: My 54 GMC Build
Posted via Mobile Devicethis is the look I am going for but I might paint the running boards satin black
Old 02-02-2013, 08:36 PM   #89
docrock
docrock's Avatar
Re: My 54 GMC Build
Posted via Mobile Devicemoved the oil cooler to under because the radiator location was where the grill attached. The cooling fan is going to be pushing and when I add the ac unit it will have to fit in there some where too. So under is it.
Old 02-02-2013, 08:37 PM   #90
docrock
docrock's Avatar
Re: My 54 GMC Build
The bumper will cover this area and this cooler is made out of steel
Old 02-02-2013, 08:40 PM   #91
docrock
docrock's Avatar
Re: My 54 GMC Build
Posted via Mobile Deviceput some more pieces on and built a battery box
Old 02-02-2013, 10:49 PM   #92
docrock
docrock's Avatar
Re: My 54 GMC Build
Posted via Mobile Devicewhile working the fender and hood and waiting for high build to dry I started outing the bed back together. Go to get the height right for the running boards and the side aprons. I cut the gas filler door out of the 93 truck so I am going to reuse it. Thinking about making a tool box with a removable bottom so if the fuel pump fails I don't have to drop the tank. Anyway lots of measuring
Old 02-02-2013, 10:50 PM   #93
docrock
docrock's Avatar
Re: My 54 GMC Build
Old 02-03-2013, 10:29 AM   #94
solidaxel
solidaxel's Avatar
Re: My 54 GMC Build
Nice choice on color.
I had the same problem with LMC window rubber but Steel cured that for me also
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-03-2013, 02:12 PM   #95
docrock
docrock's Avatar
Re: My 54 GMC Build
Thanks for checking out my project
Old 02-16-2013, 12:59 PM   #96
docrock
docrock's Avatar
Re: My 54 GMC Build
Installed one of the new headlights from a jeep cj. It has the removable bulb. Bought the plug adapter on eBay to plug into the 93 harness
Old 02-16-2013, 11:13 PM   #97
kdog3121
Re: My 54 GMC Build
nice, i like that. can you give us some more details on the parts for the cj headlight conversion?
kdog3121 is offline   Reply With Quote
Old 02-16-2013, 11:39 PM   #98
kdog3121
Re: My 54 GMC Build
H4?
Old 02-17-2013, 10:25 PM   #99
docrock
docrock's Avatar
Re: My 54 GMC Build
2007 Jeep Liberty Headlight Housing with the black mounting taken off then use the standard retainer and ring. The bulb is a 9008 or H13 and the socket matches the bulb. working on lighting it up next week
Old 02-18-2013, 01:43 PM   #100
kdog3121
Re: My 54 GMC Build
thanks!
