Old 01-16-2011, 06:29 PM   #76
3r!c84
Badass
3r!c84's Avatar
Re: Barn raising
wow ! gotta say nice build. i just looked threw the pics (ill read later) awsome work. !!!!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-16-2011, 08:40 PM   #77
Mike Bradbury
Mike Bradbury's Avatar
Re: Barn raising
Originally Posted by chevy2tom View Post
Mike, I'm thinking of running the Patriot side pipes on my 71. Where did you get them ,what length kit did you orgionaly buy,and how is the sound outside and inside the cab at idle and on the throttle? Thank's, Tom
When I bought the truck the mufflers were pretty shot, so I installed a set of flow masters 40 series while I decided what I was going to do. It was so loud in the cab from the resonance that my wife and daughter did not want to ride in it. The Patriot glass pack side pipe has a fuller more mellow tone but still has a rich classic sound both inside and out of the cab. You can buy the kit from Patriot which includes the collectors that have three dummy pipes and only one that works, Hooker has a similar kit that is 4" pipe. I deleted those and built my own single 3.5 single 90* that tucks nicely under the front wheel well.
I got the 73" length but it really did not matter because I was getting rid of the collector in front of the side pipe so I could have made it any length.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 01-17-2011, 02:40 AM   #78
Mike Bradbury
Re: Barn raising
Originally Posted by 67chevy1series View Post
my cab came from a 67 3/4 ton truck and i now have it 1/2 ton and wanted to know if i was gonna have any problems
All my body panels are original, all I changed was the drive train, not sure if they will hassle you since the vin # is on the cab.
Old 01-17-2011, 03:00 AM   #79
67chevy1series
67chevy1series's Avatar
Re: Barn raising
oh ok thanks mike
67chevy1series is offline   Reply With Quote
Old 01-17-2011, 10:13 AM   #80
crakarjax
crakarjax's Avatar
Re: Barn raising
If it was me I would just swap the VIN tags. I know, I know... but the cabs are exactly the same, so morally speaking I think it would be ok to do.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-22-2011, 02:18 PM   #81
Mike Bradbury
Re: Barn raising
Had a little bit of time to waste the other day so I finally got to finish off the trailing arms the way I wanted to. Went and got some solid aluminum round stock and made myself some billet trailing arm ends and polished them up, and installed a set screw to hold them all in place. I am happy with the results and I think it finishes off the arm nicely. I will eventually clear coat them but for now I just put some sealer on them.
Old 01-22-2011, 02:21 PM   #82
67cheby
67cheby
67cheby's Avatar
Re: Barn raising
looks killer, what did you use for a "sealer"
67cheby is offline   Reply With Quote
Old 01-22-2011, 02:40 PM   #83
Mike Bradbury
Re: Barn raising
The guy who polished my grill sugested Master Formula. I got it at the San Diego County Fair last year, it seems to work ok, haven't used it too much though.
Old 01-22-2011, 04:43 PM   #84
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Barn raising
Also, try Gords polish.
http://www.gordsaluminumpolish.com/
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-22-2011, 04:52 PM   #85
67cheby
67cheby
67cheby's Avatar
Re: Barn raising
thanks for the tips
Old 01-23-2011, 04:02 PM   #86
mwilliams5891
Re: Barn raising
why did you not do the hooker side pipe one one?????
this is my plan but im pretty sure I will need to modify my headers oh well
http://www.summitracing.com/parts/HOK-2234HKR/
into these
http://www.summitracing.com/parts/HOK-50735-1HKR/
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 01-23-2011, 04:43 PM   #87
Mike Bradbury
Re: Barn raising
Several reasons why I did not go with Hooker; The hooker pipes are 4" dia. and with them hanging low on the side I did not want to add any more clearance issues. The Patriot side pipes are 3.5" an would give a bit more clearance given that it is a long wheel base and going into driveways and parking lot I did not want to high center. Since this is a daily driver it was more of an issue than if it was a weekend toy. Second is the price, Patriot was quite a bit less than the hooker pipes. From what I could tell there was not much difference between the two other than the Hooker glass pack could be removed and replaced when the glass was blown out or for racing. The Patriot pipes have a single tack weld holding the glass pack in place so if I needed to remove the muffler I could with out much trouble. Third was the length, maybe they do sell them longer but the longest I found the Hooker product in 65" length and I needed 73" and Patriot had them that long. SWB trucks might have an easier time with the shorter length pipes.
Old 01-24-2011, 02:28 AM   #88
mwilliams5891
Re: Barn raising
alright well thank you man good to know! any idea if the hooker headers will clear our fenders?
oh and I want to hear yours!!!!!
-03 Mazda Protege 5
Old 01-24-2011, 02:43 AM   #89
Mike Bradbury
Re: Barn raising
Fenders? or frame? I am using the original ram horn headers that came with the truck and they work great. They were routed at a 90* bend directly behind the rise in the forward frame rail, about right in line where you see them disappear under the truck. I did not come out from the headers in the wheel well area, the way it works out the side pipes miss the fender and wheel well altogether. It was definitely a custom fit up and not just bolt on item.
I am still trying to get a good sounding video of the truck, just dragging my feet I guess.
Old 01-24-2011, 04:12 AM   #90
mwilliams5891
Re: Barn raising
well my big concern is if the hooker headers will go low enought to clear the fender but not too low.... I called hooker and they don't even have dimensions
-03 Mazda Protege 5
Old 01-24-2011, 11:49 AM   #91
Mike Bradbury
Re: Barn raising
I guess I am not surprised, try Doug Thorley they seem to know more about the product they sell from my experience.
Old 01-24-2011, 01:03 PM   #92
mwilliams5891
Re: Barn raising
ok will do!!! thanks again and I love your truck
-03 Mazda Protege 5
Old 01-24-2011, 01:57 PM   #93
Garthc20
Garthc20's Avatar
Re: Barn raising
wow just checked out your build thread , we have to get together some time
1970 Custom camper 20 lwb
1978 yamaha xs1100
(insert clever quote here)
Garthc20 is offline   Reply With Quote
Old 01-24-2011, 03:08 PM   #94
longhorn396
S.D.M.F.
longhorn396's Avatar
Re: Barn raising
Awesome truck man. I love the lowering kit and all the custom work u did i wish i could do all of that. U should paint the chevrolet in the grille black and around the headlights or have someone photoshop it to see what it would look like.
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 01-27-2011, 07:13 PM   #95
Mike Bradbury
Re: Barn raising
Garth,
I would love to get some of the San Diego members together. Seems like the So Cal chapter is mostly up in L.A. area. I am going to start going to the La Mesa and El Cajon street meets when they start up again. I know that spots can be reserved for clubs to come and park, and it would be cool to have a whole line of trucks on display.
Long Horn,
Yeah, that is on my list to get done, but I just cannot seem to find the time and I have a bunch of other projects in line in front of it.
Old 01-27-2011, 07:18 PM   #96
Mike Bradbury
Re: Barn raising
Hey I almost forgot, after about 8 month battle with the DMV they finally said uncle and issued the YOM plates that I restored. Had them on the truck that day. Now I just need to build a rear bumper to hang it on, The rear window placement is getting old. Pics tommorrow.
Old 01-27-2011, 07:23 PM   #97
67chevy1series
Re: Barn raising
dont you mean ''uncle sam''
Old 01-27-2011, 08:37 PM   #98
72SWBChevy
72SWBChevy's Avatar
Re: Barn raising
Look great!! Sweet ride with all the upgrades/details on a solid truck, rust free. Awesome find!
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 01-27-2011, 09:38 PM   #99
Garthc20
Garthc20's Avatar
Re: Barn raising
I m in Mike just drop me a pm when you hear of any thing
1978 yamaha xs1100
Old 01-28-2011, 03:37 AM   #100
Mike Bradbury
Re: Barn raising
Looks like they start on June 30 and go until December 8
