Old 07-12-2011, 03:55 AM   #76
kikkegek
kikkegek's Avatar
Re: Suburban K20 1986 Silverado
thanks man! thats what I fugured!
kikkegek is offline   Reply With Quote
Old 07-19-2011, 03:24 PM   #77
kikkegek
kikkegek's Avatar
a buddy of mine offered to put the Burb in his garage during painting! very cool of him.
since I am inside I figured i do some more stuff
repaired a hole in the rear fender.
repaired some rust and holes in the cargo door
and making some progress
it now has 4 layers of white on top. finally no red coming through.
I have one coat of black on and need one more. the black covers like the best. allmost in one coat.
I need to take the rear bumper off to paint the red thing between the bumper and the chassis.
it looks kinda nice without the running boards. I might not put them back on.
I do need a step of some kind so grandma can get in the car. any ideas?
Old 07-19-2011, 04:12 PM   #78
motornut
78K & 79C Jimmys
motornut's Avatar
thats cool
sure looks white on top now
black looks good too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-22-2011, 06:56 PM   #79
kikkegek
kikkegek's Avatar
outside is finished!
Old 07-22-2011, 10:05 PM   #80
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Looks really good!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-23-2011, 06:39 AM   #81
kikkegek
kikkegek's Avatar
thanks man!
yeah, came out pretty nice!
Old 07-24-2011, 03:19 PM   #82
kikkegek
kikkegek's Avatar
hopefully fixed a leaking radiatorconnection by putting some good old JB Weld on there. first of course cleaned it very thoroughly...
Old 07-25-2011, 02:26 PM   #83
kikkegek
kikkegek's Avatar
damnit! I let the JB Weld dry overnight 20:00 till 8:30h in the morning, but it started leaking again today.
So I have let it dry for 12,5hours, but that is probably not enough......
I'll fix it again tonight and let it sit for 36hours. hopefully its solved then...because I would hate to take the complete rad out, because I think the tranny cooler is also in there.
is it hard to disconnect and then reconnect the tranny cooler?
Old 07-26-2011, 09:43 AM   #84
motornut
78K & 79C Jimmys
motornut's Avatar
looks good finished !
John
Old 07-26-2011, 09:57 AM   #85
motornut
78K & 79C Jimmys
motornut's Avatar
it dosn't look like there is an external cooler(usally out front of regular rad)
no pressure when not running
so just the two lines (yellow)undo
and i baggie the ends so they don't drip and just a strip of duck tape over the tranny fittings on the rad to lift it out
when i've used the JB i've found more thinner coats work better
but havn't used it on a rad
John
Old 07-26-2011, 01:15 PM   #86
kikkegek
kikkegek's Avatar
thanks man! I applied JB again yesterday and I am now letting it rest for 36h before starting the engine again. If it doesnt work, then I will probably take the rad out and solder it outside the engine bay
Old 07-26-2011, 01:54 PM   #87
TheApocalyptican
TheApocalyptican's Avatar
How good does the paint job look up close? It looks great in the pictures!
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 07-26-2011, 02:53 PM   #88
68Timber
I know the pieces fit
68Timber's Avatar
Looks great! Needs some black wheels now.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-26-2011, 03:25 PM   #89
kikkegek
kikkegek's Avatar
thanks man!
it has some orangepeel, but I kinda like it like that. rough car, rough paint...
@Bruiser: yeah, when the chrome runs out on these boys, I'll have m powdercoated black...that will look sweet!
Old 08-02-2011, 07:13 AM   #90
kikkegek
kikkegek's Avatar
Nice photo today at the beach in Scheveningen, Netherlands!
Old 08-14-2011, 03:47 PM   #91
kikkegek
kikkegek's Avatar
I changed the original radiator for a Spectra Prenium CU730...
was a b1tch to fit, what should be a bolt-in-replacement, became a supercustom-replacement...the rad was thicker and high then the original...
Rubbers didnt fit, top radiator brackets didnt fit...etc.....
Old 08-16-2011, 07:16 PM   #92
ejn74
ejn74's Avatar
Nice looking truck paint and radiator look good!
Life is short, Live each day as a new day and keep on Truckin!
ejn74 is offline   Reply With Quote
Old 08-18-2011, 09:56 AM   #93
motornut
78K & 79C Jimmys
motornut's Avatar
yup looks good should work well
John
Old 08-20-2011, 07:42 AM   #94
kikkegek
kikkegek's Avatar
took the eco-module of the firewall today. I also tried to remove a lot of the smog wiring, because all the smog stuff is gone. But they all run to the back of the engine and I cant see where they go. Can I just cut these babys?
all the connectors are (when facing the engine bay from the front) to the left of the engine and run to the left rear side into a wire protection plastic hose...
Old 10-01-2011, 01:48 PM   #95
kikkegek
kikkegek's Avatar
I replaced the seal of the valve covers and gave them a paintjob.
and finally mounted the sunvisor on the Burb
Old 10-01-2011, 02:15 PM   #96
89Suburban
89Suburban's Avatar
This has been a very interesting thread. I like that tach on the left, the led's in the guages. Visor makes a big difference. The new radiator is very nice looking. Did the truck come with those dual batteries? Was this truck orginally a diesel? I will be roller painting the bottom half of my truck when the time comes.
1999 Bass Tracker Pro Team 175 - 40 HP Merc
1989 GMC Suburban V-1500/5.7 L TBI/700r4/NP241C/GM 10 Bolts
89Suburban is offline   Reply With Quote
Old 10-01-2011, 04:35 PM   #97
kikkegek
kikkegek's Avatar
thanks man! No I have no clue why it has dual batteries. I bought it like that and changed both old batteries for new ones. I guess the previous owner was a big user (hahaha)....
Old 10-01-2011, 10:57 PM   #98
str8axle55
My 86 gas also came with dual batteries, it was an option. The paint looks very nice. i was thinking about doing mine black in the middle w/a roller.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 10-04-2011, 09:46 AM   #99
motornut
78K & 79C Jimmys
motornut's Avatar
visor looks great i may do mine yet
Vcovers look nice and new again
John
Old 10-16-2011, 08:04 AM   #100
kikkegek
kikkegek's Avatar
Installed a second hand Analog MSD 6AL (6420) in my car last night.
cars runs fine. I am not sure if I am noticing any difference from the stock setup with the HEI ignition.
I'll check my mpg this week and see if it helps any...
