#76 |
![]() Join Date: Mar 2011
Re: 47 1-Ton to S10 build
looking amazing. Your truck makes me want to paint mine hotrod flatz black.
Blake. Sydney Aus 56 Chev 3100 build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363 LOW n LOUD ![]() |
#77 |
![]() Join Date: Mar 2007
Looks great. Good luck with your first trip down the road.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#78 |
Is this the paint you used on your truck Sir?
http://www.eastwood.com/rat-rod-blac...ck-primer.html i'm wanting the same look as your trucks paint on mine. |
#79 | |
1947 5 Window bagged S-15 frame 5.3 w/4L80E 1960 Apache LS Swap 5.3 w/4L80E |
#80 |
A little late, 4th of July pic...
#81 |
this truck looks sick, congrats nice and clean. how you liking the engine and trans? hows your gas mileage, heard of one guy getting 25 mpg once you get rid of all the emissions crap. kinda curious cause I'm doing a 5.3 in a 53' belair.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#82 | |
#83 |
bustac, thanks for the reply. I'm late to the game so I'm playing mad catch up, but learning quick. I really dig the things you can do with the LS stuff. Some serious HP can be obtained on the cheap, kinda like the vortecs but even better. Did you use an aftermarket trans controller? How'd you go about that?
#84 | |
I'm running a 4L80e, originally came with 4L60 so I had the segment swapped onto the PCM, I'm tuning with HP Tuners. Kinda weird plugging a laptop into 1947 truck. Only thing added was a ISS speed sensor that the 4L60 didn't have. The rest is all stock connections, my setup is also drive by wire with electronic pedal.
#85 |
I never got to excited over the hotrod flat black until I seen a 50 GMC at a car show recently. It was a nice clean build and was pretty sharp. Your truck has changed my mind completely, very nice build, you should be proud.
#86 |
cool, thanks for the info, I'm about a year or so away from getting that drivetrain going so I'll cross that bridge when I get there.
#87 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looks killer, I might have missed it but how high did you mount your cab off the frame? Did it need a trans hump?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#88 |
I forget but I made the same idea as the mounts described in some of the other threads I wanna say about 5". I used an original tranny cover but gave it about a 1" hump in the middle just be safe.
#89 |
Let's just say I like it.
Clean truck. Those rims with black centers and Nickel grill just the perfect combo with the matte black. ![]() |
#90 |
im working on my triangulated 4 link right now aswell. not sure if I'm over thinking it. but what angle did you set your upper bars at they dont look like 45*? also what did you use as your OG firewall,transmission bellhousing,front bumper,center of vehicle??? any help would be much much appreciated
#91 |
also your lower links on axle are they leveled under axle or pushed forward and the back shock mount plate is level up and down
