Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-04-2011, 11:30 PM   #76
blackout
blackout's Avatar
Re: 1987 chevy scottsdale 4x4 first project
good running truck for 500 ! i found an other suburban that was lifted, had a custom bumper and winch and in good shape for 750 with a 350/350/np208 combo
http://67-72chevytrucks.com/vboard/s...d.php?t=434087 chevy scottsdale first project
blackout is offline   Reply With Quote
Old 06-10-2011, 11:37 PM   #77
blackout
blackout's Avatar
Its been a while since i posted guys but i have gotten alot of progess.
i put the bed back on. decided to pull the motor to clean up and paint
and fix some leaks and replace some parts. pulled the tranny to fix some
major leaks and replace the fluid and filter.
Going to paint the exhaust manifolds black. the transmission and block silver and the other accessories black
had to use the tractor to get that engine lift out
Old 06-11-2011, 01:40 AM   #78
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Looking good!
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 06-11-2011, 01:51 AM   #79
blackout
blackout's Avatar
thanks man! yours as well. that front end rebuild was good and detailed!
Old 06-12-2011, 10:04 PM   #80
blackout
blackout's Avatar
The transmission is painted. took longer than expected with 30 years of caked grease on it. next is to paint the engine block. Just need to get that power steering pulley off, so i need to rent a puller. great time to check my timing chain for slack! Name:  IMG_0088.jpg
Old 06-14-2011, 10:02 PM   #81
blackout
blackout's Avatar
So far i half the engine painted and whole transmission painted.I cant get the exhaust manifold on drivers side of the engine without taking the powersteering pulley off and this whole bracket off.....what were these engineers thinking !
Old 07-16-2011, 11:48 PM   #82
blackout
blackout's Avatar
engine is almost done i just need to install the intake manifold and waterpump gaskets and im good to go. the bed is back on, fuel tank is installed for good,
i took of the serpentine system off and switched to the v belt accesories. now i can use my old SI alternator so i dont have to change any of the wiring
should have this thing running and driving in less than a month!
Old 07-17-2011, 08:46 AM   #83
Chris Guthro
Its really coming a long way, i cant wait to see how it progress'
Chris Guthro is offline   Reply With Quote
Old 07-17-2011, 11:34 PM   #84
blackout
blackout's Avatar
got my fuel filler mocked up just need to do the final touches tomorrow, next to go in is the motor and tranny! i also got my transmission cooler and oil cooler mounted
Old 07-17-2011, 11:48 PM   #85
MTCK
MTCK's Avatar
Looks good! What size tank is that? I've been debating a blazer tank swap to get rid of my second transfer pump, and go with a quieter in-tank pump while I'm at it... I've been debating how to do the fuel fill, since I run a tonneau cover all winter, and use the bed a lot in the summer. I'd like to avoid the sheet metal work involved with another filler behind the rear wheel but I think it is necessary for my application.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 07-18-2011, 03:10 AM   #86
blackout
blackout's Avatar
thanks chris.
its a 33 gallon suburban tank. i originally made a fuel filler that reached all the way to the rh stock filler location. but i ditched that because i was worried it would take longer to fill, you could go with the filler in one of the tail lamps theres a thread on here about it.
if you have any more questions about the swap ill be glad to help ya!
