Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-29-2012, 12:47 AM   #76
rayfinseats
Re: My new project
Going in the body shop Monday.
rayfinseats is offline   Reply With Quote
Old 07-13-2012, 10:39 AM   #77
rayfinseats
Re: My new project
TA DA!
Old 01-20-2013, 01:34 AM   #78
rayfinseats
Re: My new project
I kept getting belt squeal no matter what I did. New belts, belt conditioner, adjustments. I didn't want to over-tighten the belts so finally I put a 29-30" belt from my water pump pulley to my alternator. The other belt goes to the power steering, water pump and crankshaft pulley.
Old 01-20-2013, 03:04 AM   #79
MTCK
MTCK's Avatar
Re: My new project
Did that fix your problem? I did the serpentine conversion for the same reason and haven't had a problem since.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-30-2013, 06:57 PM   #80
rayfinseats
Re: My new project
Ya that fixed the problem.
I replaced my perfectly good 600 Edelbrock carb with a Quadrajet to see if I can get better mileage. I have to work out a small idle problem bit it seems to have about the same power. Thanks to Charlie Roupe for the parts. What a great guy!. The Qjet has smaller primaries. I like the simplicity of the Edelbrock, too bad it isn't a spreadbore. I think they're in kahoots with the oil companies. My next vehicle may be S10 4x4.
Old 12-25-2015, 03:21 PM   #81
rayfinseats
Re: My new project
OK gas mileage update. We built a low dollar 388 small block with vortec heads and a performer intake with Qjet. 10.3 compression flat tops and a 350/327 cam, ramhorn exhaust. Gas mileage went up about 30-50%. I'm sure the torque and efficiency of the heads made a big difference. Truck weighs about 4200. The reason I say low dollar, we used swap meet heads, ebay intake, speedway parts, $200 long block. Wish I had a 2200 stall and maybe 3.73 gears but pretty happy with it. Thinking about maybe summit headers next summer.
I am now running a 96 chevy starter with 1000 amp Interstate battery and Ford LTD starter relay on the inner fender. Starts on demand now. Dual tanks, (3 port switch) electric pump.
Old 12-25-2015, 03:30 PM   #82
rayfinseats
Re: My new project
I am now running a
Last edited by rayfinseats; 12-25-2015 at 03:42 PM. Reason: trying to delete this entry.
