Old 10-23-2011, 10:30 PM   #76
62 Bowtie
62 Bowtie's Avatar
Re: 63-72 Chevy P/U Rear Shock Mount System
are you sure these wont work on the 60-62 frame is it where the brackets bolt to the u-bolts?
62 Bowtie is offline   Reply With Quote
Old 10-24-2011, 09:46 AM   #77
kieth
kieth's Avatar
Originally Posted by 65Gregg View Post
Rob I got my relocation kit installed, great stuff. While I was under my truck admiring your parts and my labor a thought crossed my mind. I'm sure you get enough of the arm chair engineers and our ideas but here goes anyway. What would happen if you made the lower shock brackets "flipped" over to reduce scrub line issues? Most of your design work is done it would mean extending the shock mount hole out to clear the trailing arm and if it was just a little wider the part that currently hangs down would be flush up against the lower edge of the trailing arm. Let me know what you think.
Just my armchair quarterback opinion, you will loose travel on the shock, I think that was why he chose this location and the angle of the shock would change......JMO Kieth
kieth is offline   Reply With Quote
Old 10-24-2011, 11:11 AM   #78
65Gregg
65Gregg's Avatar
Question Re: 63-72 Chevy P/U Rear Shock Mount System
I agree that you would lose some travel but the shocks that are supplied per Rob "the 'A' shoch measures 14" closed, and 23" open, thats nine inches of travel" would still offer far more travel than the 5" of travel that I had. I am guessing you might lose 2" of travel with an inverted mount. Again I'm just guessing and wondering, I'm not an engineer/fabricator, but unless you ask the guy that is you won't ever know.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 10-24-2011, 03:09 PM   #79
robnolimit
robnolimit's Avatar
I haven't looked into the 60-62 chassis. If you'd like to try a set, I'll give you an unconditional return option, and another 10% back after posting up the info, good or bad. As this would help out other with the 60-62,
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 10-24-2011, 03:13 PM   #80
robnolimit
robnolimit's Avatar
While it could be done, you'd loose appx 2 3/4" of shock travel. Even if your on 15" wheels, you have to drive it on a flat until the tire was gone before it really scrubbed. The value of the longer shocks is worth it. Hows the ride/handling of your truck now? do you feel it was worthwhile?
Old 10-26-2011, 02:21 AM   #81
62 Bowtie
62 Bowtie's Avatar
Hey thank you for your generous offer Rob Im running airbags with a different setup now but was just asking
Old 10-30-2011, 11:19 PM   #82
65Gregg
65Gregg's Avatar
There is a huge difference. I have put about 100 miles on so far. I find myself stuffing it into curves that I previously didn't. I haven't really thought about doing it, it just seems to happen It also passes the wife test, she thinks it's great. I do have a question about the bump stops you have on the shop truck, did you get it from a GM dealer or where can they be found? P/N# etc?
To answer your question "is it worthwile?" HECK YEAH!!
65Gregg
Blue long bed
White TBSS
61 Impala
Old 10-30-2011, 11:34 PM   #83
jayman68
Fun Stuff
jayman68's Avatar
Congrats on passing your test.
This is a great upgrade.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 10-31-2011, 12:05 PM   #84
robnolimit
robnolimit's Avatar
The Bump stops are from G.M. motorhome chassis. I'll see if we can get a part # for you.
65Gregg Thats great!! glad you feel it was worth it. Anything that makes your truck drive better will help it to be drivin more.
Old 10-31-2011, 12:07 PM   #85
robnolimit
robnolimit's Avatar
SEMA is here. We'll be posting live picts and video wed/fri from Vegas. Check out www.facebook.com/nolimithotrods to get the updates.
Old 11-09-2011, 08:01 PM   #86
coop34
Just got my kit installed. This is a quality kit, and the difference in ride is outstanding. I don't know how it compares to the other shock relocation kits, but blows the stock mounting out of the water. Nice work Rob.
coop34 is offline   Reply With Quote
Old 11-09-2011, 08:19 PM   #87
robnolimit
robnolimit's Avatar
Glad to hear it. We are always happy to hear back from the end user/driver/installer on how if fits and works.
Old 11-10-2011, 05:27 PM   #88
68Stepbed
68Stepbed's Avatar
Rob, will this kit work with a rear mounted fuel tank? I'll have to get a pic later to see if you can tell if it will work with mine. I may not be able to get to the inside of the frame rail anyway.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-10-2011, 06:07 PM   #89
coop34
68 Step... I have a rear mounted tank and I got it installed. Had to twist my arm in all sorts of weird ways, but got it done. If you don't have much of a gap between the tank and the frame rails, you may need to drop the tank.
Old 11-29-2011, 10:30 PM   #90
jbice70gmc
jbice70gmc's Avatar
Do you have to raise/flip the trailing arm mounting bracket on the crossmember with this kit. Or is this something you would recommend doing. I have 2" blocks C notch and bags. 70 GMC
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 11-30-2011, 12:31 AM   #91
65Gregg
65Gregg's Avatar
Have you had a chance to find th P/N for the bumpstops yet?
65Gregg
Blue long bed
White TBSS
61 Impala
Old 11-30-2011, 10:06 AM   #92
OJ1988
Just a car guy
OJ1988's Avatar
I wouldn't think you would have to, but they recommend doing that on lowered trucks. Just finished flipping mine and installing poly bushings.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 11-30-2011, 10:59 AM   #93
jbice70gmc
jbice70gmc's Avatar
Frame is powder coated poly bushings are in and didn't really want to have to do this but I guess it would be worth it if Rob recommends it.
Old 11-30-2011, 04:24 PM   #94
robnolimit
robnolimit's Avatar
you don't have to, but you may be giving up a slight handling advantage, and yes, I said 'slight'. Do be careful to check the pinion angle at RH and make sure it is a god match to the crank CL
Old 11-30-2011, 04:44 PM   #95
OJ1988
Just a car guy
OJ1988's Avatar
If my trans is 4 degrees pointing down, what should my pinion be?
1973 Vega Drag Car
1970 C20 tow rig
Old 11-30-2011, 08:14 PM   #96
jbice70gmc
jbice70gmc's Avatar
I think I can probably flip the backets without doing any damage. Also been thinking about going with an aftermarket crossmember anyway. Is there one you would recommend for this application? Thanks in advance and will be ordering the shock relocators and shocks in the next week or two. Which shocks for bagged C notch 101, 102 B?
Old 11-30-2011, 09:54 PM   #97
robnolimit
robnolimit's Avatar
First, really check the crank angle. The trans pan rail is not parallel to the CL. Use the oil pan rail, or the driveshaft yoke.
If your crank CL is 4* down, set your pinion 3* to 4* up at RH.
Old 11-30-2011, 09:58 PM   #98
robnolimit
robnolimit's Avatar
Honestly, the only aftermarket crossmember I've ever used is from Early Classics. It fitted very good. I'm sure the others from reputable companies would be fine. As for 101B for smoother ride, 102B is a bit more controled, and needed if you plan to drive pretty low.
Old 12-11-2011, 01:09 AM   #99
jbice70gmc
jbice70gmc's Avatar
Could I just flip the whole crossmember? Would it bolt up?
Old 12-11-2011, 04:05 PM   #100
robnolimit
robnolimit's Avatar
I've never tried it. Maybee, but it does sound like more work. Anyone???
