Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-28-2011, 11:10 PM   #76
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My build thread.. 63 LS powered C10
This is the first time I have seen this build thread.
The 1960 - 1966 Chevrolet & GMC Pickups Message Board
projects and builds.
http://67-72chevytrucks.com/vboard/f...play.php?f=197
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 12-28-2011, 11:47 PM   #77
bigboybodry
bigboybodry's Avatar
Originally Posted by 68 C-10 KID View Post
LOOK AT SHAUN GOING BIG TIME!!!!!
The motor is going to love the new heads.
The cage work looks great.
For the some that does not understand the gusset's. Those are mandatory for any joint that can not be welded 360*
they are in my car everywere in the door bars at the windsheild etc..and its certified to 750
keep up the great work and keep me poasted mine is next!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 12-28-2011, 11:54 PM   #78
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
That's one BAD A Camaro!
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-29-2011, 12:33 AM   #79
bigboybodry
thanks brother
Old 12-29-2011, 01:53 AM   #80
bigboybodry
Didn't mean to jack the tread truck looks awsome Shaun!
Old 12-29-2011, 02:23 AM   #81
Super73
Super73's Avatar
bcdeutsch731,
The lower sill bar needs to connect the bottom of the A-pillar bar and main hoop together. Being the main hoop does not go bellow the cab, it would be hard to run it under the cab. Also not sure the legality regarding distance from the diagnal door bar.
There does not have to have an X in the door, just needs to be a diagnal, but an X is more on the safe side. I am nimble enough to get in/out.
Thanks all for the compliments.
Most likely going to pull the motor on sunday, get the heads off and to their new owner. Then order the new ones with gaskets, put it all back together ASAP.
Come on 10.5x ET NA... I don't think it will happen first time out but sure would be nice.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-29-2011, 07:26 AM   #82
BigDan3131
BigDan3131's Avatar
Ok, instead of having an upper loop with the forward door bars welded in place he does it the opposite way. Was there some reason you chose not to run the forward door bars thru the dash and then down giving you more room? That and the hoop behind the drivers seat is much higher than the front one. With all those tie-in bars it looks sloppy to me especially that diagonal bar. Was that placed just to keep the hoops apart for welding?
Sorry if I ticked you off I'm just really picky about some things.
BigDan3131 is offline   Reply With Quote
Old 12-29-2011, 10:33 AM   #83
Shon
NICE!
Wasnt this going to be your tow rig for the Camaro you are building??
I got the same problems!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-29-2011, 01:01 PM   #84
Super73
Super73's Avatar
Dan, not mad, your opinion is your opinion. But let me clarify a few things for you.
I don't follow your train of thought here exactly. If you have a picture of what you are talking about, it might make better sense. Most 8-12 point cage I see have
A main hoop like behind the seat
The A pillar bars that come off the top of it to the winshield and down to the floor
A winshield bar that seperates the top them
Sometimes a dash bar depending on how much floor was removed
And a diagnal bar from the drivers shoulder to their feet, bar going out the back
Something like page 22 of this (Section 20.24):
http://www.nhra.com/UserFiles/file/G...egulations.pdf
Actually there is. Ever been in a 60-63 cab with the wrap around windshield? The location in which the cage would have to go through the dash has very little meet to cut a hole through and pass a tube. It would have been a mess.
The hoop is that high to clear my big head and helmet. The front is lower than the rear, again for a reason. Joe tries to maximize space for getting in and out as well as hide the cage from the outside.
In order for the windshield bar to be up higher, the A-pillar bar would have had to dive sooner. In other words, the bend would be closer to the main hoop. Being that bar now dives straight down, he actually created more entry/exit space for me being we didn't have the ability to go through the dash.
The curve and windshield cross bar are actually very close to the windshield, again forcing the hight to be lower than the main hoop.
The diagnal bar serves a function. God forbid the truck didn't stay shinny side up (oh wait, there is no shinny side with my truck) it will help the cage from compressing at the tops in a roll over. A diagnal bar adds a lot of strength. Heance why I opted to have Joe X the door way. Like others mentioned, the small diagnal gussets also serve a funtion!
Plain and simple it is a lot stronger, and the point of a cage is safety right? At least that's what you said here: http://67-72chevytrucks.com/vboard/s...65&postcount=6
It is obvious you have never built a NHRA certed cage, yet my chassis builder has been doing so since the late 80's. I'll will trust his "Mickey Moused" ways and know that I have a solid, safe, well built good looking cage.
Again, not mad, just trying to help someone out that "doesn't get it"
Old 12-30-2011, 01:37 AM   #85
BigDan3131
BigDan3131's Avatar
So after further review your guy is doing yours like Chris Alston does. My guy in CA and the one here in WA use the style that S&W and Chassis Engineering use with a main overhead hoop like this:https://chassisengineering.com/shopD...&ProductId=852
Old 12-30-2011, 01:54 AM   #86
Super73
Super73's Avatar
Different ways to skin a cat.. I personally like the way mine is done vs the two hoop deal.
Old 12-30-2011, 02:06 AM   #87
bigboybodry
me too shaun. you can kick the top windsheild bar up some and get it out of the line of sight.
Old 12-30-2011, 11:44 AM   #88
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Cage looks good man. Awesome work
Still trying to figure out what is so mickey mouse bout it.
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 12-30-2011, 03:47 PM   #89
1Bad62Pro/Street
Talking Re: My build thread.. 63 LS powered C10
You have anymore new videos of you roast'em down the track bud?
Old 12-30-2011, 05:06 PM   #90
Super73
Super73's Avatar
If you are asking me, nope nothing right now. Truck hasn't been to the track since I did some 1/8 mile racing in May.
Old 12-30-2011, 09:53 PM   #91
Street Smart
Street Smart's Avatar
Another update, looks like my 72cc AFR 225's are sold and will be coming off the motor. Talking to Tony Mamo about the 64cc AFR 245 heads.
Tony`s a great guy, knows his stuff. He used to run a mid 70`s Monte when he lived in Long Island. His basement was sick, head porting stations and heads everywhere.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 02-10-2012, 12:02 AM   #92
68 C-10 KID
Mean Green
Waiting for more pics........
Super I Found a component for ya LOL
http://www.holley.com/data/products/...rge300-115.jpg
AKA MEAN GREEN.
Old 02-10-2012, 01:14 AM   #93
Super73
Super73's Avatar
It's cool looking, but I would have to buy a different N20 set up.
Old 02-11-2012, 12:24 PM   #94
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
I got looking at your photos and noticed that in a few areas that you could use a 90* gusset tabs, The outer part of that cab is not extremely strong. Add a few of the gussets on the outer support rail , to the frame. I am sure you have it under control. was just a thought, not in any way telling you have to set up the cage.
Just a heads up after putting my nova end over end and having the cage save my life. My dad was a huge help in helping me add the little extras that add up in the end.
Plus I need you to add more weight to that flying brick so I can be some what close to the rear bumper down the strip.
Talk to you later.
GMR-PERFORMANCE is offline   Reply With Quote
Old 03-10-2012, 08:53 PM   #95
Super73
Super73's Avatar
Got the new heads in. These also came today. 2" primary with 3.5" merge collectors.
Old 03-10-2012, 09:42 PM   #96
Street Smart
Nice! What brand are they?
Old 03-10-2012, 10:18 PM   #97
Super73
Super73's Avatar
Kooks
Old 03-12-2012, 12:03 PM   #98
bigboybodry
Boy them look awsome! You making me want to sell the bbc stuff more and more.
Old 03-13-2012, 02:36 PM   #99
nxtruck
nxtruck's Avatar
I've been considering selling my current motor and picking up a 6.0 or a 6.2 and putting some L92 heads and a bigger cam and going this route. What application are those Kooks headers for? Those are some nice pipes! Also, does anyone make some mounts to bolt the LS engines in our trucks in the stock location?
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 03-13-2012, 05:45 PM   #100
GMR-PERFORMANCE
Go the LS3 route hands down. From there a simple scat stroker kit and cam and you will have a very healthy engine that can take a huge amount of abuse. A screw super charger will provide a ton of power.. NOS is always fun as well but type of use would make that choice for you.
I already have plans for the next build
