12-04-2011, 03:26 PM | #76 |
Carpe manana
Re: 72 K20 been parked for 31 years!!
I don't know anything helpful as relates the motor but this is turning into a motivational build thread for me. I've got a K20 motor w 54k miles caked in a hard shell of west Texas greasy dirt. Keep going!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
12-04-2011, 03:40 PM | #77 | |
Vintage 4x4s
Buddy and I lifted the whole assembly and it wasn't unbearable but it wasn't light Is the np205 by itself heavier than a TH400? I can handle those by myself. Also how heavy is the bare 350 engine block by the way?
I'd like to keep the original trans in there. Would like to put a gearvendors on in the future.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
12-04-2011, 03:42 PM | #78 |
Vintage 4x4s
Thanks! This is the first chevy engine I'v rebuilt so I'm definitely having to take it slow and ask questions
12-04-2011, 04:29 PM | #79 |
Gear Vendors O/D, now that is a good idea.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-04-2011, 04:39 PM | #80 |
Carpe manana
I'm not familiar with these and am trying to decide whether or not to keep the non-original TH350 in my K20 OR go with a built 700R4. Any benefit to going with the Gear Vendors O/D other than preserving an original type tranny and not relocating motor mounts?
12-04-2011, 04:54 PM | #81 | |
Vintage 4x4s
12-04-2011, 05:09 PM | #82 |
Carpe manana
Great to know! These look pricey but attractive. I bookmarked their website.
So, if I go with a 700R4 AND the OD that gives me an 8 speed and I'll be turning low 2k's at 200 mph with the 411s in my HO52 while towing a flat bed trailer Sweet.
12-04-2011, 07:10 PM | #83 | |
Spending the money for an O/D is good in only few ways. The biggest is reduced RPM and a likely MPG increase when properly geared. Also splitting gears to reduce RPM drop is great when pulling a load and even better on a grade. You get better performance and sometimes better overall MPG numbers as a result. Last thing to consider is driveline speed. The faster the shafts and gears rotate the more vibration and wear can be expected. Truck drivelines don't like spinning 6K.
12-04-2011, 07:50 PM | #84 |
Still Learning
Looks like someone needs to go ahead and start a build thread
Very nice piece of history! That was a beast in it's time. Can't wait to see you get it back on the road. BTW, I have a home for those slots if you get tired of them...... |
12-05-2011, 08:55 AM | #85 | ||
When I was a kid I picked up the bare 350 block that is now in my 72 Chevelle. Like other driveline pieces, the days of me lifting a bare block are behind me. I know you're after the original look. What I would do is use a 700r4 and just put that original th350 on the shelf. If some day there is a call for all original, numbers matching K20s, you'll have it handy. In the mean time you'll have a better tranny. Like I said before I REALLY wish I could go back to the day I decided to take my th350 to the rebuilder instead of a core 700r4. I made my decision only on fuel savings. Even at $4/gallon you don't save anything for a really long time. However when I have to take my 3.73 gears out on interstate 35 with a 70 mph speed limit, 3300 rpms really sucks. Its loud and it can't be doing my engine and drivetrain any good. Does gearvendors even make a unit that bolts to the back of your NP205? That is a whole lot of stuff to run through to get to the rear axel. Flywheel -> torque converter -> tranny -> coupler in adapter -> NP205 -> gear vendors -> driveshaft -> rear axel. Maybe they have a little driveshaft behind the 205 to get into the gearvendors unit. That is a whole lot of stuff to go wrong.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-05-2011, 08:56 AM | #86 | |
12-05-2011, 09:20 AM | #87 | |
Vintage 4x4s
12-05-2011, 09:47 AM | #88 |
We did this last week. Short version is mod. the trans. to mimic a T350. Then bolt it up to transfer case and move engine forward about 2". Its not a simple one for one swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=495513
12-05-2011, 02:07 PM | #89 | ||
If you follow the link inside the link SS tim posted, you'll find a more detailed post I created about this swap. Long story short, the 700r4 is not a direct swap but with the advanced adapters output shaft it is sort of a direct swap. You have to move your engine forward close to 2" but since a stock 4x4 V8 sits back about 2" compared to a stock 2wd V8, there is enough room. And you can make it look totally stock with a different GM fan shroud. I haven't done this swap yet but I would start with a 2wd shroud if you're planning on going stock. Since the transmission crossmember on a 4x4 is actually a transfer case adapter cross member, and since the tail-less business end of a 700r4 looks just like the back of a 4x4 th350, you put in that AA output shaft in the tranny, bolt the transmission in place of the th350, move the engine cross member up a bit, test fit with engine installed - to mark holes, get the V8 out of the way, make your holes, then bolt it all together. Since the speedo output is on the transfercase you don't have to worry about that. If your speedo was correct before it will be correct now. All you need to do is get the cable for the 700r4 and use it instead of the stock TV cable that tells the th350 when you want a downshift.
12-05-2011, 03:52 PM | #90 | |
http://67-72chevytrucks.com/vboard/member.php?u=96601
12-05-2011, 05:02 PM | #91 |
I am sooooo jealous! I want one like this for my place in the country but all I ever find is 2wd.
Are you going to restore or mod or keep it just like it is? Congrats |
12-05-2011, 05:07 PM | #92 | |
Vintage 4x4s
Leaning more towards the gear vendors since its a bolt up and then I'd have a 6 speed. I just need to make sure they engine rpm will be 2500 or less at 70 in 6th gear. Although assuming I do the stroker, I will have plenty of torque and could maybe swap in a 3.54 Dana 60 and powerlok I have and really cruise!! That would be amazing, I am excited at the thought of that ...low cruise rpm but plenty of gears for towing. I'd conquer at least the northern hemisphere with that kind of equipment
12-05-2011, 06:40 PM | #93 | |
OK I feel better now. Don't forget if you change the rear to 3.54 you have to change the front too if you ever want to use 4wd again. Another thing about the th350. Heat. With no lock-up converter it is always slipping some. That energy has to go somewhere and that somewhere is heat. Now I have a th350 and and an auxiliary cooler which handles the heat just fine. But as far as I know GM didn't offer stock auxiliary tranny coolers back in 1972 so then you're stuck back with the not stock looking component on a truck you want to look stock. And unlike something like a 700r4 verses a th350 that blends in, that aux cooler will be sticking out there in front of the radiator for everybody to see. Heat wise I did a test right after I installed my freshly rebuilt th350. I had to pull my boat from Lindstrom to Red Wing to get ready for a tournament. One Saturday I went without the auxiliary cooler. At a stop light down in Stillwater my transmission temp gauge shot up to 240! That is too hot. It cooled down again when I got moving. The following weekend I did the same pull with the same basic outside temps. Right around 70 degrees outside for both trips. At the same light I was running just over 200 and alot lower before and after that light. 700r4 OD is .7:1. So if I'm running 3300 at 70mph, 30% off of that is 2310 rpms. Plus there will be a hundred or two less for the lock-up converter taking the slip out. 4.10 is 10% more gear than my 3.73s. So if your tire is 28" tall assume you'll be running 3630 rpms at 70 mph. Now I'm guessing stock 3/4 ton tires are taller than stock 1/2 ton but I'm not sure. If you get on the google and look for final gear ratio calculators you can do some pretty good guestimating of what you're looking at with no OD and with. I have no clue what the GV unit gives you for an OD reduction but I'm sure somebody here or the google can tell you that number.
12-07-2011, 12:29 PM | #94 | |||
Vintage 4x4s
Now if i wanted to swap in a 3.54 Dana 60 I have, I could have Power Lok and less RPM's. Also if I did that, even without the GV unit, I'd be 2700rpm at 75 mph and 2550rpm at 70mph. I do have 4.10's for it also that I'd use if I ran the GV unit. So on one hand, I'd have the best of all worlds with the GV unit except cost to install, which would be about $3000. On the other, without GV, I'd have to invest nothing but be running 250 higher rpm at cruise speed and have a lot less wheel torque (3.54 vs 4.10 rear) to get loads started when towing. I will probably tow 1/2 the time with this truck but when I do it will be pulling a 2500lb trailer that will have up to 5000lbs on it (truck or tractor). Thoughts?? I would probably have to build less of an engine (flat tappet cam) if I go the GV route since I don't have an unlimited budget.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 12-07-2011 at 12:35 PM. |
12-07-2011, 12:37 PM | #95 |
Vintage 4x4s
The ratio of 2wd to 4wd in 1972 was about 10:1 so they are def harder to find. Also, many of the 4x4's you'll find are converted 2x4's. I looked at so many trucks and still had to drive 300miles one way before I found a truck like this, and even it was locked up and not running
12-07-2011, 07:51 PM | #96 |
If you are going to build a stroker I wouldn't use the "stock" heads that were on the engine you pulled from the truck. They are most likely 882 heads so they are 1.94/1.50 valves and 76 cc chambers. That engine needs to breathe better than that. If you're worried about your stock crank you could ask a local machine shop if it would polish out with out having to grind it. Just my 2 cents. Killer truck and looking forward to seeing it come together.
Bud |
12-12-2011, 12:39 PM | #97 | |
Vintage 4x4s
12-12-2011, 02:29 PM | #98 | |
Regarding final RPM numbers, does your tire speed calculator take into account slip in the torque converter? There isn't a lot on the highway but it is still there with a th350. If you run a 700r4 you won't be pulling in OD but I believe the torque converter still locks up in 3rd on that transmission. If you switch your rear, remember you need to switch your front too. They need to be matched (front and rear gears) when you engage 4wd. I just dug out my log. I can't believe it has been that long already but I did my 3-speed manual to th350 swap on 12/9/01. 10 years ago. He he he - my notes were projecting that if gas ever got over $1.799/gallon it still wouldn't be worth the swap for the amount of miles I drive the truck. I should recalculate for $4/gallon which is what I've been paying for the non-oxy premium lately. Long story short where I missed the boat is the wear and tear on my truck and my eardrums when running high rpms down the highway. All that being said I'd still be leaning towards a 700r4, 33" tires, and 4.10 gears.
12-13-2011, 08:37 PM | #99 | |||
Vintage 4x4s
Thanks for your advice, nice to talk with someone with a similar rig who's been there before.
12-13-2011, 08:41 PM | #100 |
Vintage 4x4s
Been rounding up parts, here are some nice original door panels I scored off ebay a few weeks ago: Now if i could find the matching armrests I'd be in better shape.
