Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-16-2016, 11:05 PM   #76
michelle911
Re: 65 Burb body mounts
I know this is over a year old, but I can't seem to find this anywhere else. I'm doing a 66 Panel and don't have my hardware. So I'm trying to make sure the bolts are the same, plus I need to know the sizes of the sleeves/spacers.
michelle911 is offline   Reply With Quote
Old 08-30-2016, 10:43 PM   #77
RoyL
RoyL's Avatar
ron posted bolt sizes on this thread. I assume panels are the same...
http://67-72chevytrucks.com/vboard/s...4&postcount=75
My understanding is you won't need sleeves if you use the reproduction ones from Truck Shop. I finally got a set from Truck Shop and will measure the hole diameters. And spacers will depend on if you need them for lining up body panels, fenders, doors.
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 08-30-2016, 10:59 PM   #78
padresag
i did work her with offline and she does have the truck shop ones. the frt bolt behind the "B" pillar is different length if I remember correctly between suburban and panel
ron
padresag is offline   Reply With Quote
Old 09-16-2016, 12:57 AM   #79
RoyL
RoyL's Avatar
Originally Posted by 66 Burban View Post
According to Steve, I got the last set until new shipment arrives.
Just checked one of mine........
Without raised section: .594" to .610"
Raised portion: .682" to .704"
The rubber does seem to be higher durometer (denser), and should not compress as much.
So, we're talking about less than .10" difference --- should not be a problem..
I finally got mine from truck shop so I measured the rectangular mounts:
Here's what I think they are supposed to be (Chevy parts book, ron, lewis) Truck shop measurements in blue:
length - 3.0" Truck Shop - 3.25"
width - 1.76" Truck Shop - 1.9"
height (thickness) - 0.92" w/ raised portion, 0.72" w/o raised portion
Truck Shop height - 0.69" w/ raised portion, 0.59" w/o raised portion
rubber side hole diameter - ~0.75" Truck Shop - 0.76"
steel side hole diameter - ~0.44" Truck Shop - 0.62"
Have not installed yet, anybody have a problem with them fitting between the rails, since these are a little wider?
And the diameter of the steel side hole is much larger, looks like it'lll make for a sloppier fit for the bolt?
1965 Suburban
Old 09-16-2016, 02:22 PM   #80
padresag
back to the assy illustration on line 75 there shows a sleeve that goes in the rubber hole around the bolt. they may refer to that as a spacer in the writtn descrition. this fills in the differential in sizes. and use shims as required.
I spent a bit of time going back and forth with Michelle911 about putting his/her body back on and got it done and off to the body shop. I asked if they would write a little note about the experience for others but only see silence. it is a one way street for a lot of people
these insulators were superceded several times over the years. as I said previously the square mounts I believe were used in 60-62. the rectangular mount was also used from 67-72 in suburbans but only see a listing for 69-72 for rectangular insulator part # 69-09703(truck and car shop). don't know what happened to 67/68. wonder if that is the same size as the earlier insulators in the 60-66 kit?. that insulator was used for 42 years.
ron
Old 07-23-2018, 06:41 PM   #81
Slowclimb
Slowclimb's Avatar
no longer making them whats next going to try these it has our trucks listed as to fit http://www.energysuspensionparts.com/3.4149
Slowclimb is offline   Reply With Quote
Old 07-26-2018, 03:01 AM   #82
padresag
I am moving up to sayward at the end of aug. it did get delayed a bit but is happening. I do have materials to make them which what I was going to do. if you are up that way drop by and i can share the info
ron
Old 07-26-2018, 04:13 PM   #83
Grandpa54
Grandpa54's Avatar
Originally Posted by padresag View Post
i am moving up to sayward at the end of aug. It did get delayed a bit but is happening. I do have materials to make them which what i was going to do. If you are up that way drop by and i can share the info
ron
not sure you are interested but i have a 66 panel and i up graded
to 67 thru. 72 suburban. I had to drill the holes in the frame bigger but the parts were easier the get and were better quality.
I have a set of the truck shop mounts left over if some one needs them you can pm me
mark
Grandpa54 is offline   Reply With Quote
Old 04-10-2022, 11:23 AM   #84
RoyL
RoyL's Avatar
And the diameter of the steel side hole is much larger, looks like it'll make for a sloppier fit for the bolt?
I finally got to replacing some of my rubber body mounts with the Truck Shop ones. I used the square ones with the sleeves on the frontmost cab mounts. Good fit, previous ones were round, I assume replaced at some point. Don't have the fenders on yet, so don't know if I'll need spacers for added thickness.
I used the rectangular ones to replace my rusted ones in the rear positions. They do fit between the rails, was concerned with extra width. Comments on the install of the rectangular ones:
  • No sleeve hardware provided, gotta find your own.
  • Raised half moon sections were too low, didn't really make a good positive interlock with the other mating half. OEM height was 0.2”, these are ~0.1" or less. Some were taller than others, not consistent.
  • Larger hole on the steel made for a sloppy fit, but not a big deal.
  • Thickness was less than original parts (not quite 1/4" less), you may need to use spacers
1965 Suburban
Old 04-12-2022, 07:15 PM   #85
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I hear that azproperformance has suburban body mounts.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-13-2022, 04:05 PM   #86
RoyL
RoyL's Avatar
https://azproperformance.com/product...05f943f0&_ss=r
These?
Not rectangular but has the sleeves. Would want to get the dimensions compared to OEM before I bought these.
1965 Suburban
