Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-06-2012, 10:45 AM   #76
SFTorange
SFTorange's Avatar
Re: 1960-66 parts from big stash
What do you have in the area of hubcaps? Condition isn't particularly important as long as they aren't completely rusted through. I'm interested in '64-'66 caps.
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 04-07-2012, 10:35 AM   #77
62 Barnfind
62 Barnfind's Avatar
Looking for a right side door for a 60-63. How much with shiping with grayhound?
62 Barnfind is offline   Reply With Quote
Old 10-26-2015, 04:19 AM   #78
Nils
Nils's Avatar
Originally Posted by GMCNUT View Post
Been playing with 60-66 trucks for 18 yrs and got a bunch of left-over stuff that came in a big pile of 60-66 parts I bought from a guy recently - do not need over 1/2 of this stuff - maybe someone else does.
1) gas tank supports w/ straps rust / rot free = 20.00 (pair)
2) small back glass = 20.00 (clear)
3) kick panel vent housings w/ vents = 20.00 (pair)
4) 60-66 cowl extensions = 20.00 (pair)
5) 60-66 wiper cowl panel = 20.00
I have bunches of other stuff - will post other stuff separately as I get pictures taken or feel free to inquire if you are hunting something - I probably have it
Shipping will have to be added to the above prices based on your zip code but will only be exactly whatever it actually costs me - FedEx, USPS, Parcel post, whatever you want. I take Paypal, Money Order, Check, Cash etc
Hi,
I need a Mount for my wiper Motor like this. Do you have some one like this ???
Thank you verry much.
Greetings
Nils
Nils is offline   Reply With Quote
Old 10-26-2015, 04:42 PM   #79
MoeMan
Hi,
Looking for short bedside for drivers side. Would also be interested in a good hood for my 65.
r/Moe
MoeMan is offline   Reply With Quote
Old 10-26-2015, 08:06 PM   #80
GMCNUT
GMCNUT's Avatar
Originally Posted by Nils View Post
Hi,
Greetings
Nils
Nils, I believe I have a junk cab we could possibly cut that area out of and get you the spot-welded wiper motor flange you need. Do you have rotted sheetmetal around yours? if so we can maybe cut it out bigger than needed to give you something to work with....
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 10-26-2015, 08:08 PM   #81
GMCNUT
GMCNUT's Avatar
Originally Posted by MoeMan View Post
Hi,
r/Moe
No bedsides presently Moe, but I will put you second in line behind another guy who called yesterday wanting the only hood I have left. If he passes, I will contact you
Old 10-28-2015, 08:18 PM   #82
jb9281
jb9281's Avatar
Hi, I need a nice looking radio antenna for a 66 c10 and I also would like a key lock cylinder for a door. I do not need a key, will get it rekeyed. Thanks
jb9281 is offline   Reply With Quote
Old 10-29-2015, 04:47 PM   #83
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Do you have any 63-66 chevy/gmc painted front bumper guards? Thanks.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-31-2015, 07:23 PM   #84
ralewis3
PM sent GMCNUT.
ralewis3 is offline   Reply With Quote
Old 11-01-2015, 07:08 AM   #85
ralewis3
How about an automatic transmission steering column for a '66 GMC? Don't need the wheel. Just the column.
Old 11-02-2015, 01:53 PM   #86
verdell
verdell's Avatar
Hey,
got any 60-63 passenger side doors?
verdell is offline   Reply With Quote
Old 03-10-2017, 01:20 AM   #87
bondo510
Any chance do you you have a 60 draglink ? Mine got bent in a wreck . Thanks
bondo510 is offline   Reply With Quote
Old 04-26-2017, 09:18 PM   #88
Dhelm2atl
Looking for a part for my 1964 c10 steering column, believe it is the mast jacket. Originally 3 on tree, previous owner moved shifter to floor and gutted the column. Currently my blinker housing does not attach to anything on the lower part of the column and will just rotate around on the column. The blinker housing does sit in the shifter housing. The piece I have looks to have been sawed on or broken off where the blinker housing would slide over (the bottom slats) to secure it.
Thanks in advance,
- Duane
Dhelm2atl is offline   Reply With Quote
Old 04-27-2017, 08:39 PM   #89
GMCNUT
GMCNUT's Avatar
Thanks in advance,
- Duane
Sounds like you need a new 3 speed manual column if the switch housing has nothing to attach to - I have a nice one for 100.00 that is complete
Old 05-01-2017, 02:08 PM   #90
sirJim
Wouldent happen to have one of these would you?
sirJim is offline   Reply With Quote
Old 05-02-2017, 02:14 AM   #91
GMCNUT
GMCNUT's Avatar
pretty sure I already sold the NOS 4 speed backup switch and pawl I had, but will check
Old 05-02-2017, 02:17 AM   #92
sirJim
Thanks. Jim
Old 05-02-2017, 02:21 AM   #93
GMCNUT
GMCNUT's Avatar
Old 05-02-2017, 03:00 AM   #94
Cletus1960
Any 1960 Chevy hubcaps? need all 4
Cletus1960 is offline   Reply With Quote
Old 11-19-2017, 05:17 AM   #95
dkerr
Hi, do you have all the components for the park brake on a 65? I have cables and the inside cab lever but need the cross member assembly and the components in the rear wheels.
Regards, David
dkerr is offline   Reply With Quote
Old 12-15-2017, 10:56 PM   #96
Submariner616
Active Member
Do you have an oil bath air cleaner for 60 283 V8 2bbl without PCV? Thanks!
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 12-16-2017, 08:43 AM   #97
63frankintruck
GM outer rocker panels for 63?
63frankintruck is offline   Reply With Quote
Old 12-17-2017, 01:33 PM   #98
GMCNUT
GMCNUT's Avatar
sorry seeing this so late, but I think I have one - 200 bucks if still looking
Old 12-17-2017, 01:35 PM   #99
GMCNUT
GMCNUT's Avatar
GM NOS rockers come up on ebay fairly often and range in price; I have bought and installed both reproduction and NOS and personally don't see a value in GM part numbers pieces over nice Tri-plus ones - Tri plus is actually heavier guage metal to boot. Hire a good body man and get him some Tri-plus parts and you won't be disappointed.
Old 12-17-2017, 01:43 PM   #100
GMCNUT
GMCNUT's Avatar
Regards, David
I may actually have all that on a 63 frame I am going to have to move and crush soon. When I retrieve it I will see if all that stuff is on it and remove for you but you'll have to be patient because at the moment I am not entirely certain when that frame will get moved yet. I am in-process of moving a bunch of crap from a distant site to a more nearby one
