#76 |
Who Me?
Re: My 61 FL Apache 10
Out of necessity I needed to replace my radiator.. I just ordered a Champion radiator today and hope to see it later in the week. I will post pics of that soon.. Im debating on using an electric fan or keep the stock fan.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#77 |
Who Me?
#78 |
Who Me?
New radiator status....
On FedEx vehicle for delivery May-31-14, 04:08 PDT, WEST PALM BEACH, FL 33404 But its not here yet!!!
#79 |
Who Me?
I started working on this today after it arrived.
Old and new ![]() Radiator and fan installed. ![]() Also found a nice upper hose that fits like factory. ![]() I just need to wire up a relay and clean up the wiring up front. That will be tomorrow.
#80 |
The radiator looks great. What upper hose did you use it looks spot on?
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#81 |
Who Me?
Its a Dayco #20607 and im not sure what it came off of.. I took in my ribbed universal hose that was already bent into a shape and the parts guy matched it up with this one.. I had to cut off about 4-5 inches from one end and its almost a perfect fit.. There is a very slight bend at the T-stat housing, but you cant really see it.
#82 |
Who Me?
Here is the finished job! Everything went as expected.
![]() ![]() ![]() The temp looks good to me.. This was after an hour ride and about 1/2 hr idle when I returned. ![]()
#83 |
Who Me?
#84 |
Your new radiator installation looks great. Keep up the awesome job that you are doing on your truck. I bet it is a blast to drive.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
#85 |
Who Me?
Thank you!! It is a lot of fun!
#86 |
I love this build! I found it looking for rear bag setups. Is there any more progress? Did you ever install a radio?
1972 C/10 Cheyenne, Daily Driver. SOLD 1978 GMC K15 High Sierra. |
#87 |
Who Me?
Thanks Benny!! Im just driving the wheels off of it!! My thoughts for a radio was using a bluetooth amp.. Something like this.
![]() I would have music on a phone or ipod and use bluetooth to get to the amp and power a couple of 6" door speakers. everything would be hidden except the speakers.. I want a clean look when I do it. Other things have come before it, but hope to do this at some point.
#88 |
Who Me?
Today I got a set of spark plugs in the mail. I believe these plugs were installed by the PO, I had not looked at them until now since I bought the truck.
I discovered it had the wrong plugs in it.. This engine is a 1979 305 and thats the plugs I ordered. Here is the difference I found from old to new. The old ones are R44TS8, which means they need a .080 gap.. This engine calls for a R45TS and runs a .045 gap. The old plugs were gapped at.045, that was pretty ghetto! Here is a pic of old and new plugs. ![]()
#89 | |
Have you noticed any difference in performance with the new 'proper' plugs?
#90 | |
Who Me?
I also have a 180* stat to replace and the "correct" temp sender too.. Those are also on tap for tomorrow.
#91 |
Who Me?
Ok. So tomorrow got here a little sooner. The rainy weather we had today moved out and there was some daylight left so I got to install the new temp sender and t-stat.
Here are some pics of what was installed today. ![]() ![]() The aftermarket gauge shows 180* for the new stat and the stock gauge is showing a normal temp. The old sender would peg the gauge all the way to the right.. This one looks much better. ![]() ![]()
#92 |
Who Me?
Road test coming tomorrow or Sunday on the way to a car show.
#93 |
Nice thread. Just read the whole thing. Keep up the good work. Love the truck! You've really made it your own.
#94 |
Who Me?
Thank you!! Its been a fun truck to have and work on.
#95 |
Who Me?
After leaving a car show today I stopped for some food and still had no place for a cup.. This is something I have been planning on fixing for some time now. So after I got home and finished my burger I started on this cup holder. This is the first test fit. I have since cleaned up the welds and painted it. It will get installed tomorrow after the paint dries.
#96 |
aside from that horrible front license plate, Go Seahawks!, you got quite a sweet ride my friend!
As we've both just installed new champions rads it will be cool to see what the difference, if any, is between an electric fan and a belt driven fan. I'm hoping to get a shroud on mine at some point, but will check in on yours to see if maybe a single electric fan is worth it. also, thanks for the good exhaust photos, the X-frames on these '61s didn't leave a lot of extra space for pipes to be run! i'm contemplating building my exhaust from a kit (with the help of my welder/hot rod buddy) or just taking it into a shop. With your x-pipe being right below the T-bar cross member, do you find you have enough clearance? I think our trucks have a similar stance and height so i'm hoping that you're not having any problems so I can copy it. thanks
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
#97 |
Who Me?
Thanks for the compliments and im a Steelers fan from Florida.. Go figure!! Teams down here suck.. I had to pick a winner back in 1977. I think I did good!
The radiator was one of the best additions to this truck. Little money well spent!! I have had no rub issues on the exhaust, the torsion bar bolts were lower. That was my hitting point. My build thread should have enough pics for you. I dont have the truck any longer to take any additional, but I did save everything I took of the truck.
