Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-08-2012, 12:41 AM   #76
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Ryan's 72 K10 Build
Love your build, I had a 70 with the same color combo yeras ago. On the bedliner..did you shoot it yourself? did it come with a special gun? And lastly what size wheels are you running? I tried buying BFG All Terains about 3 years ago...spent 3 monthes trying to locate some with no luck...same story back then..on national back order. I had always used the AT on my trucks and Blazers...I like my MT KOS but really miss the old AT.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-08-2012, 12:32 PM   #77
Average Joe
Average Joe's Avatar
Cool build! I really like the color combo. Just curious where you got your paint from and what brand of gun your using.
Average Joe is offline   Reply With Quote
Old 07-09-2012, 10:20 AM   #78
ryanmctee
ryanmctee's Avatar
Thanks! Paint is Kirker single stage urethane with clear over it. Gun is a DeVilbiss "starting line" kit - around $150
Thanks! Bedliner is Raptor by Upol, comes complete with the gun. Got it on-line from TP Tools. A kit goes for about $120 delivered. Read about three comments back for more info on the bedliner. The wheels are 15 x 8.
Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=512620
ryanmctee is offline   Reply With Quote
Old 07-09-2012, 10:29 AM   #79
ryanmctee
ryanmctee's Avatar
Bed finally on!!
I finally got the bed on the truck for the last time! Had a family get-togethor, and I told them if they wanted free food/booze, then they would have to help! Amazing how easy a bed goes on with 8 sets of hands on it. It sure was fun dismantling the trusty bed dolly I built so I could get some garage floor back! Anyways, once the bed was on, I finished color-sanding and buffing it. Turned out great! Also got the rest of the dog dish caps painted. And got the rear marker lights and brake lights put back in. Getting close now!!
Old 07-09-2012, 10:32 AM   #80
ryanmctee
ryanmctee's Avatar
Pics of dog dish caps:
Old 07-09-2012, 10:35 PM   #81
4x4Jake
Not sure if you mentioned it before or not, what color/type of blue paint did you use on the bowties on the hubcaps??
4x4Jake is offline   Reply With Quote
Old 07-10-2012, 10:23 AM   #82
ryanmctee
ryanmctee's Avatar
Got it at my local Ace Hardware Store. "Ace Rust Stop Continental Blue", but I've also been told Ford Blue tractor paint works well too. Here's a picture of the can.
Old 07-10-2012, 11:09 AM   #83
ryanmctee
ryanmctee's Avatar
Ok, installed new Holley carb and new HEI distributor. The truck had a HEI distributor and Edelbrock carb and ran. Ran lousy, but ran. Screwed up and didn't mark the distributor prior to taking it out. After installing the new distributor, I get a backfire through the carb. Have double checked all the spark plug wires and confirmed they're correct. I know everyone is going to say it's 180 degrees out, but I tried that too, and still get the backfire. I'd like some input on how to start from SCRATCH with a new HEI install. Find TDC, rotate the oil pump shaft, install the dizzy.
Any suggestions? Thanks in advance - Ryan
Old 07-11-2012, 10:50 AM   #84
ryanmctee
ryanmctee's Avatar
Last night I used a compression gauge on the #1 cylinder to confirm the upstroke of the piston. Bumped the engine until I could feel the piston at the top of the stroke with a screwdriver. That's TDC right?? Installed the spark plug then put the distributor back in. Rotor pointed towards the #1 cylinder, then installed the plug wires in the firing order 1-8-4-3-6-5-7-2. Confirmed the wires went to the correct plugs. Fired truck. No backfire, but also no start. What gives??? Anyone care to help before I completly go nuts?
Old 07-12-2012, 10:33 AM   #85
ryanmctee
ryanmctee's Avatar
Took a night off from the engine and finished up the bed, tailgate, and rear bumper. Really looking like a truck now. My windsheild is scheduled for tomorrow, I'm really crossing my fingers that I can get the trim in. Then I can get the cowl on and hood on and the exterior of the truck will be finished! Here's some pictures of the bed trim/tailgate/bumper.
Old 07-12-2012, 05:41 PM   #86
47thriftmaster
47thriftmaster's Avatar
Truck is looking sweet, great job.
47thriftmaster is offline   Reply With Quote
Old 07-12-2012, 06:22 PM   #87
Gene
Gene's Avatar
Awesome job! I almost went with Olive Green/White, now I wish I had!
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 07-12-2012, 07:41 PM   #88
birdistheword
birdistheword's Avatar
Awsome build love the color combo and white rims and hubcaps. You wouldn't happen to know where I can get a set do you?
birdistheword is offline   Reply With Quote
Old 07-12-2012, 08:00 PM   #89
ryanmctee
ryanmctee's Avatar
I got the hubcaps from a member here on the board. TOOMUCHSTUFF. Look him up and he'll take care of you. The truck came with the steel rims, I just sand blasted them and painted them white. Thanks for your comments guys!
Old 07-12-2012, 10:11 PM   #90
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Hey Ryan your truck is really looking awesome! I like that step bumper. I bet you cant wait to roll that thing out of the garage for the first time. Good luck with the windshield tomorrow, from what i've heard, its either a walk in the park, or a nightmare. Hope it goes well!
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 07-12-2012, 10:30 PM   #91
ryanmctee
ryanmctee's Avatar
Thanks Nick, This will be the second attempt at the windshield. My glass guy said he's bringing another windshield, gasket, and I have both styles of trim, so all I can do is cross my fingers and toes and make sure I have plenty of cold beer
Old 07-13-2012, 08:55 PM   #92
Chevymaniac
Awesome job to detail, truck is looking like it just rolled off the assembly line. Did u get your engine running? The first thing that popped to mind is check all your ground wires. Make sure battery cables are not loose. Hope this helps.
Chevymaniac is offline   Reply With Quote
Old 07-14-2012, 03:11 PM   #93
ryanmctee
ryanmctee's Avatar
Thanks. I get plenty of juice, just won't fire. I'm going to have a mechanic buddy come over and give me a helping hand. Working on rear electrical now. Everything works except the rear marker lights won't blink. Looking at the schematic, it shows a yellow wire going to both the left rear marker and rear brake light. My new harness only has a brown going to both rear markers (along with a black ground wire.) Any thoughts?
Old 07-14-2012, 03:14 PM   #94
ryanmctee
ryanmctee's Avatar
You must be kidding..... I just read a thread that says the rear markers aren't suppose to blink. Can this be correct? Seems really weird that only the tail lights blink. Can anyone else confirm this?
Old 07-15-2012, 08:17 AM   #95
birdistheword
Yeah it's true. The front side markers blink and the rear side markers don't blink. And thanks for the hubcap info.
Old 07-16-2012, 12:33 AM   #96
70K10Hunter
70K10Hunter's Avatar
first of all very nice build awsome body and paint work! I noticed you had the motor out and detailed it, did you reseal the whole motor with new gskts? and if yiou did, check the timing chain condition and timing? that is the whole basis of the engine tunability, if you are on TDC with your no.1 cyl technically you can put number one any where on the distributor and run your firing order from there. not trying to sound like a smart a$$ #1 cyl is at the drivers side front. distributor rotation is clockwise looking straight down on it, then again you may have an issue with your dist.
70K10Hunter is offline   Reply With Quote
Old 07-16-2012, 10:08 AM   #97
ryanmctee
ryanmctee's Avatar
Good weekend, getting real close now. Got the tool box painted, tires on, and amp/speakers installed. Had a small mis-hap with the windsheild, glass guy is coming back this week. Hopefully another week or so and I'll be on the road!
Old 07-16-2012, 10:02 PM   #98
BLAZERMAN
BLAZERMAN's Avatar
Man that is lookin Sharp!! and that vintage tool box looks right at home on there!
Old 07-17-2012, 01:10 AM   #99
wyomech
wyomech's Avatar
I make sure that #1 is on top dead center,then set the distributor in ,usually aimed at 5 o'clock for cylinder 1, turn on the switch put a plug in the number 1 wire and ground it then turn the distributor around by hand till the plug fires,it should start
wyomech is offline   Reply With Quote
Old 07-17-2012, 02:31 AM   #100
67chevy1series
67chevy1series's Avatar
oh man the steelies and caps just added the cherry on top! beautiful!
67chevy1series is offline   Reply With Quote
1972, k10
