Old 05-08-2012, 10:01 AM   #76
gettmoneyy7
gettmoneyy7's Avatar
Re: My 82 shortbed
Used the bench seat bolts to bolt the chain to..
gettmoneyy7 is offline   Reply With Quote
Old 05-08-2012, 06:44 PM   #77
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: My 82 shortbed
Watch the cab doesn't roll forward on you....it is very front heavy.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 05-10-2012, 09:14 AM   #78
gettmoneyy7
Re: My 82 shortbed
Yea at that point we were just messing with it and experimenting. after a little trial and error we figured it out.
Old 05-10-2012, 09:42 AM   #79
gettmoneyy7
Re: My 82 shortbed
Couldnt get it to balance on just the one chain from the two front bench seat bolts so went ahead and drilled a third hole up by were the tranny sits under the cab, that i will fill later. bolted another chain to the new whole and to the other chain and experimented again till i found a center of balance. Jacked the cab up then jacked the frame up and took of the one wheel so it would go over the legs of the lift. Lucky had the help of a few friends with this one. It worked pretty good if i do say so myself. tell me what you think?
Old 05-11-2012, 09:41 AM   #80
gettmoneyy7
Re: My 82 shortbed
Started doing a little body work for the hell of it.. and look what i found lol.. what looks like a bullet hole on on the back passenger side cab corner, maybe this truck has a history behind it
Old 05-11-2012, 01:59 PM   #81
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Re: My 82 shortbed
That truck might have been on an episode of cops
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 05-14-2012, 09:13 AM   #82
gettmoneyy7
Re: My 82 shortbed
You never know but were it was it had to go threw the wheel well and hit the cab, so whoever was in my truck was running or just got caught in the crossfire haha
Old 05-14-2012, 09:48 AM   #83
gettmoneyy7
Re: My 82 shortbed
valve covers came in ....set everything on just to see what she would look like..
Old 05-14-2012, 09:56 AM   #84
gettmoneyy7
Re: My 82 shortbed
Started stripping the messed up frame off the 86.... salvaging as much as i can..
Old 05-14-2012, 12:28 PM   #85
grayharville
Re: My 82 shortbed
Valve covers look sweet.
East Tx Squares
Old 05-15-2012, 10:31 AM   #86
gettmoneyy7
Re: My 82 shortbed
i thought so too... lol
Old 05-16-2012, 09:28 AM   #87
gettmoneyy7
Re: My 82 shortbed
You guys might hate me lol but figured id make use of the frame since it was already messed up tell me what you think..?
Old 05-16-2012, 09:38 AM   #88
gettmoneyy7
Re: My 82 shortbed
Next morning took apart the front suspension to salvage as much as possible..
Old 05-17-2012, 11:08 PM   #89
grayharville
Re: My 82 shortbed
Lol you making a Swb trailer? Nice.
East Tx Squares
Old 05-17-2012, 11:31 PM   #90
texastruckjunky
texastruckjunky's Avatar
Re: My 82 shortbed
Looking good I want to see more. Nice progress!!
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 05-18-2012, 09:34 AM   #91
gettmoneyy7
Re: My 82 shortbed
thanks.. and yes i will continue post more pics as i get them together..
Old 05-18-2012, 10:04 AM   #92
gettmoneyy7
Re: My 82 shortbed
Next day sprayed trailor down with satin black and put the 82 bed on the 86 trailer and bolted it down, loaded up the spare parts we dont need and now it was off to be stored at my uncles house.. did have any room for it at my house.
Old 05-18-2012, 10:23 AM   #93
gettmoneyy7
Re: My 82 shortbed
Now it was time for the 82 frame to get stripped.. cranked it up and moved it outback. started by removing the steering column and that section
Old 05-18-2012, 10:29 AM   #94
gettmoneyy7
Re: My 82 shortbed
now i have parts everywere.. dont think my dads to happy about that lol
Old 05-18-2012, 08:32 PM   #95
texastruckjunky
Re: My 82 shortbed
Your makin good progress, the parts won't be there long. Then he will be happy again.
Old 05-21-2012, 09:14 AM   #96
gettmoneyy7
Re: My 82 shortbed
Thanks and yeah lol he wont be happy till every part is out of his back yard lol
Old 05-21-2012, 09:29 AM   #97
gettmoneyy7
Re: My 82 shortbed
Now for the motor.. hooked it up and after fighting a couple 30 year old bolts it was out last pic is when i was about to pressure clean the remaining areas i couldnt get before because of the motor being in.
Old 05-21-2012, 09:54 AM   #98
gettmoneyy7
Re: My 82 shortbed
Now as for the bed took it off and standed it up against the wall. Next day tried using my dads compressor and sandblasting but it just couldnt keep up and didnt have much pressure. Started calling around and found a place that had a peice that attached to the end of a 4000psi pressure cleaner and would spit the sand out with the water. planned a day and went and rented it for 40 for 24 hours. trying to keep the sand moving threw the line was a pain. and couldnt get wet till it got used so had to make sure it was covered up good. once i had got it figured out for the most part i started sandblasting a section. Not going to lie it worked quick and went to bare medal in a second but used up ALOT of sand in the process when it was working right And made a big mess everywere. Before you could even dry it off surface rust would begin to arise. So called that plan a failed attempt. i wish i would have took a pic of the peice to show you guys.
Old 05-22-2012, 10:21 AM   #99
gettmoneyy7
Re: My 82 shortbed
well after searching around i found a place not to far that would sandblast it for a decent price. Only thing was we had to bring it to them so borrowed a friends trailor and loaded my baby up along with the core support and fenderwells and it was off to the shop... oh and btw we couldnt get those caps off the rims so we needed to find a way... the tool i had was loose and those rims must have not came off in a very long time but luckly on the way to the sandblaster stopped by a wheel place and bought a new one and they even loosened them up for me.. and you cant tell in the pictures but yes we did strap it down.
Old 07-20-2012, 08:35 PM   #100
Gordonr1973
Home Built '87
Re: My 82 shortbed
Just fyi since you were asking about LS swap costs, there was a thread on here that kept a list of each of the expenses, I think it was Glock's build called "Fred".
Gordon
c10, frame off build
