Old 10-22-2012, 05:29 PM   #76
flips72
flips72's Avatar
Re: CRGRS 66 – Winter Build Thread
the 5 speed will be nice behind the 350, i see lots of tire smoke in your future i cant get over how solid your truck is,great to have a platform like that to start with.
flips72 is offline   Reply With Quote
Old 10-23-2012, 08:02 AM   #77
CRGRS 66
CRGRS 66's Avatar
Thanks Flips, I am ecstatic at the condition of this truck, no tire smoke for this boy though
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-23-2012, 09:52 AM   #78
Bazooka
Keepin it old school
Bazooka's Avatar
Originally Posted by CRGRS 66 View Post
Picked up my transmission today, Camaro 5spd with S10 tail shaft, has new bearings and seals. Picking up my crate engine Thursday.
I'm doing the same swap on my grandpas old truck to keep it alive and just make it more enjoyable to drive. The old granny low trans thats in there now def has to go. I think its on its last leg anyway.
I don't think I'll be doing any burnouts either not sure how much abuse a t5 can take behind a 350. Should last a long time the way I drive. I have got my share of tickets in the past and tires are expensive anyway. buuut I havent had a 3rd pedal behind a v8 in awhile hopefully I can resist the urge.
Bazooka is offline   Reply With Quote
Old 10-23-2012, 09:57 PM   #79
CRGRS 66
CRGRS 66's Avatar
little bit of progress the last couple of days in preparation of pulling the engine
-dropped the drive shaft
-disconnected the e brake cables
-removed the shifter
-disconnected exhaust
-removed engine and bell housing mounting bolts (bell housing mount rubbers are pretty swollen, will order new ones
-removed rams horns (gonna blast and paint those up pretty)
-disconnected fuel line, and removed fuel pump
still need to disconnect ignition wiring and drop the tranny, will double check, but I think it will be ready to yank then, going to store it in the crate that the new engine will be coming in
Getting quite a collection of parts to blast and paint. Need to get the sand blast booth I bought put together. I am off Friday and Monday, so should make plenty of progress this weekend.
Craigerrr
Old 10-23-2012, 10:00 PM   #80
CRGRS 66
CRGRS 66's Avatar
Thanks for posting bazooka, yes, the T5 will not stand up to much abuse, but the drive-ability factor is my goal with the swap, no racing plans in my future.
Craigerrr
Old 10-23-2012, 11:26 PM   #81
Snowbound
Snowbound's Avatar
Could you post up some shots of your engine mounts? Curious what the differences are from your V8 to my L6 mounts are.
Started a build thread finally, since you were prodding me, LOL.
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 10-24-2012, 08:36 AM   #82
clemdaddy
clemdaddy's Avatar
man, that trans is too cool. new motor, new trans...wow.
you going hyd. clutch or mech.? changing gears? posi?
nice work!
clemdaddy is offline   Reply With Quote
Old 10-24-2012, 10:22 AM   #83
CRGRS 66
CRGRS 66's Avatar
Brian
Will try to get you ssome pictures at lunch today. I will have a look for your thread, and start creeping you too
nice work!
sticking with the mechanical clutch, sticking with the stock gears (believe they are 3.73), first gear ratio is very close to the original 3speed, overdrive gear should make highway driving... a little more bearable and fuel efficient. Thanks for the comp too!
Craigerrr
Old 10-24-2012, 05:23 PM   #84
McMurphy
McMurphy's Avatar
Brian
Brian on this page of my build there is a lay out photo of the 2 different frame mounts.
http://67-72chevytrucks.com/vboard/s...487100&page=12
Hope this helps.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-24-2012, 06:01 PM   #85
Greg63
Enjoy your truck
Greg63's Avatar
Brian
I have often wondered what the difference in frame mounts were between 6cyl and 8 cyl.
Back in 1982 I simply took off the engine mounts that were on my original 230 c.i., bolted them onto my 350 (long gone) and bolted both sides to the original frame mounts - without relocating or replacing them.
30 years later I still am running the same mounts.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 10-25-2012, 11:47 PM   #86
CRGRS 66
CRGRS 66's Avatar
Kind of excited today, picked up my 350, got it onto the engine stand. Just need to drop the tranny, and pull the O'l 283 out. Curious to see how the flywheel looks, assume it needs to be resurfaced, hope there aren't any cracks. Will be plopping the 283 on the skid that the 350 came out of, then it is time to tear down the front suspension, and prep the frame and firewall for paint.
Craigerrr
Old 10-26-2012, 07:33 AM   #87
notsolo
notsolo's Avatar
Sweet Score Craig ...Off to great start, black and white under the hood too.... When you get ready for cab insulation this is what I used.. Fat Man under this closed cell foam from EZ Cool .. www.lobucrod.com.. Probably over kill but it is nice.....Ed
notsolo is offline   Reply With Quote
Old 10-26-2012, 08:00 AM   #88
darkhorse970
darkhorse970's Avatar
Nice build you've got going, I'm in.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 10-26-2012, 08:27 AM   #89
CRGRS 66
CRGRS 66's Avatar
Thanks! The engine will actually be painted chevy orange. Thanks for the tip on the insulation, looks/sounds like a great product, and the price is right too.
Thanks for noticin!
Craigerrr
Old 10-26-2012, 10:25 AM   #90
Manny063011
Just checked out your thread, looking good! Man i bet its freezing up in canada right now. ill be keeping a eye out on your thread! oh and chevy orange FTW!
Manny063011 is offline   Reply With Quote
Old 10-26-2012, 01:37 PM   #91
CRGRS 66
CRGRS 66's Avatar
Thanks Manny, hope I don't disappoint... chevy orange FTW "for the win", not sure I get that, but I will take it
It went up to 72F here yesterday, more like 55-60 today, the nasty temps are comin though!
Craigerrr
Old 10-29-2012, 05:30 PM   #92
CRGRS 66
CRGRS 66's Avatar
Well, I got a lot accomplished on my extra long weekend. It helps to have a friend in the shop who listens, kinda wish Humphrey would pitch in here or there though
In between playing hockey myself, coaching my kids team, and going to watch my step son's Junior "C" hockey game, I got the engine/transmission out, and the front suspension and steering ripped off. It doesn't sound like much, but this IS my first rodeo, so I am learning as I go. I hadn't planned on removing the cross member, but it seemed a good idea to get it off and get it sand blasted. Would have been a nasty, time consuming job to prep that for paint in place. It was remarkably easy actually.
Craigerrr
Old 10-29-2012, 05:32 PM   #93
jsdoyle
jsdoyle's Avatar
Going to look great!
65 Chevy C10 Fleetside
jsdoyle is offline   Reply With Quote
Old 10-29-2012, 05:34 PM   #94
CRGRS 66
CRGRS 66's Avatar
missed the main shot...
Also, question for you guys... is the cross brace that is pictured supposed to be shaped like that?
The picture of the frame with the back of the blade against it doesn't really show it very well, but in front of where the steering box mounts there is quite an indentation in the frame. This is not normal either I presume (more evidence of the collision that I suspect took place at the front drivers corner)
Craigerrr
Old 10-29-2012, 05:36 PM   #95
CRGRS 66
CRGRS 66's Avatar
Craigerrrrr is ready for beer now
Craigerrr
Old 10-29-2012, 07:06 PM   #96
Snowbound
Snowbound's Avatar
The crossmember is bent down. Should be level, as that is where the 6 cyl rad mounts. Interesting the holes appear to be missing.
Old 10-29-2012, 08:04 PM   #97
CRGRS 66
CRGRS 66's Avatar
Hopin so! Thanks
This is an original 283 truck, not sure about the 6 cyl rad mount holes. If you look you will see the rad support saddle(s) at the top of that picture.
Craigerrr
Old 10-29-2012, 08:48 PM   #98
63sbssbbw
UCA63
63sbssbbw's Avatar
The x-m should have holes for both
So, yeah that's kind of strange.
Mine had a similar bend in it.nothing the BFH won't fix.
That framerail bow is different!
I assume the frame is square ??(+- 1/8").
It may interfere with your PS conversion plates(or not?),just something to watch for.
Looking good so far Craig
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 10-29-2012, 10:00 PM   #99
Ta2Don
Ta2Don's Avatar
Keep up the great work, looks and sounds like you are having as much fun with your build as I am with mine...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 10-31-2012, 08:37 PM   #100
MARTYZ
MARTYZ's Avatar
Looking good CRGRS. little late getting on board just found your thread.For your first rodeo you are motoring along like a pro.
Not far from Cambridge or Newmarket either,should find a show next summer we can all go to.
MARTYZ is offline   Reply With Quote
