#76 |
Grandpa in the rustmobile...
Re: Rebuilding 71 crossmember..
Picked up my parts today! (Still no pix probably wont bother uploading any until I go back to WA and have spare time).
Got the upper BJ's in (easy) but the lowers meh not so much. I rented a tool but I couldnt figure it out in mulitple configurations so Im going to get another one from somewhere else (got it from carquest) I watched a youtube video of someone doing it with an autozone kit. I spray bombed the cross shafts for the A arms and then said ya know what I'll regret bombing the spindles and shafts so they'll get powdercoated too. Dropping them off tomorow hopefully he can do them quick otherwise I'll have to get someone to pick them up for me and wait until next time. Right now its a 4.5" front drop and will be a 5 or 6" rear drop. Idk if I'll C notch or not. My ? for tonite is- Would it be OK to powdercoat the crontol shafts for the A arms? Im planning on doing the spindles (drop) and the 4 shafts. Everythings poppin' with red bushings and calipers and black powdercoat ![]() Im scared the truck will be too nice to drive... ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#77 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You can coat the shafts. Just tell the guy if he doesn't mask off the areas where the bushings go you're gonna burn his shop down.
![]() Posted via Mobile Device |
#78 |
^^^Yeah, he's right.
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#79 |
Hmm, mine look a little different than that. This only applies to the tops???
Thanks TX
#80 |
Frame in the barn loft
The 1.25 swaybar is the only pic of 'done' that I have, maybe the gf took some more than I did Im home I had a absolute blast in TN but im tired and a little homesick now back in WA
#81 |
I cut the vin out (no title) but it matches frame.
What year is it? Its def a 69 or a 70 I cant tell
#82 |
It is a 1969 2wd V-8 truck built in Atlanta. Any other info has to come from the SPID (on glovebox door)
#83 |
Cool! I always hoped it was a 69.
#84 |
Old cab goin to the crushers to build a china warship or something probably in 30 years.
#85 |
I <3 Junk
#86 |
Got about $70 bucks for the cab (STRIPPED) plus a bunch of small crap I had in the barn.
Still need to do/buy: Strip frame/trailing arms Paint install trailing arm bushings Figure out what LS engine brackets I should use (if I go this route) Strip/paint rebuild rear brakes/axle Buy front bumper & figure out what brackets Im missing (have some not all) Buy bumper/brackets for the rear (sport) Buy 6" Rear springs/Airbags (already have spring retainers powdercoated) Buy inner/outer tie rod ends Buy Idler arm/Pitman arm Buy steering box (quickturn?...) Buy a SWB bed TIRES AND WHEELS I really wanna get ATVPRO (guy that builds sick crewcabs here in spokane) to build a reg cab for me to take to TN with me oneday, but I have nowhere to store it so until better circumstances Im cabless still.
#87 |
I had the spindles (dropped) and cross shafts powdercoated I explained to the guy I didnt want certain areas powdercoated (see above post) but I didnt get to pick them up-dad did. Im trying to get him to send some pix so I can tell what he coated but no luck.
If the areas are coated-what should I do (Id like to know ahead of time so when I get to work on it for the 20 days or so next time I can work on it not wait for it to get back from powdercoaters..)
#88 |
Subscribed!
How are things going for you John? Keith |
#89 |
Im doing great! Actually heading to TN for 2 weeks in less than a month im excited hopefully I can get this danged frontend together I have all the parts just lacking (some) know how and maybe a lil gumption. Need to get lower bj's installed and get all (4) control arm shafts put in then I can bolt everything to the crossmember and hang the spindles and brakes etc
#90 |
![]() Join Date: Jan 2009
Hey man! Any progress on the truck??
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#91 |
No progress unfortunately. Im only home for maybe a month out of the year and building trucks is pretty low on the to do list while im home.
Need to finish installing the BJs and need some advise/help/how to on the control arm shafts (been so long im not sure what parts I have/need/) I have most or all the stuff for the front crossmember/suspension/brakes just need to do some work... Thanks for the bump lol Id nearly forgotten about this thread.
#92 |
Just checking around.
![]() Any new progress on the truck lately John? Keith |
#93 |
No progress :/ hoping to get the a arm shafts put in next month (October 15) and maybe blast and rebuild the rear control arms. Joined the military in 2012 and haven't played with old trucks besides when I'm home on leave. Will probably have dumb questions next month Stay tuned! Hah
