Old 01-04-2014, 10:50 PM   #76
Monte's62
Re: LVPhotos 1962 Build
Nice truck LV. I'm new around here but I've been looking at a lot of threads and I like your build. I am really digging the salt flat wheels. What size are you running and do you plan on fronts as well?
My main question is before you put the porterbuilt front end on how low were you able to go with the torsion bars and do you have any pics? I didn't know which pics were with the torsions and with the porterbuilt.
I have a 62 and will be starting a similar build soon but I may want to keep the torsion rods.
Monte's62 is offline   Reply With Quote
Old 01-04-2014, 11:21 PM   #77
LVPhotos
LVPhotos's Avatar
The truck is still rolling stock front. No bumpstops and cranked all most out. 235/60/15 stock. The rear are 295/45/
18 Nitto 555 on 18x9 Salt flats fronts will be 18x8 probably 245/40/18. Thanks for looking
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-04-2014, 11:31 PM   #78
LVPhotos
LVPhotos's Avatar
Mine vs stock. About a bumper lower. If you look to the left of mine there is a camera shooting a commercial for TUCKERS Trucks. Seen on Powerblock. After all the footage all I got was the corner of fender on tv.
Old 01-05-2014, 01:00 AM   #79
Monte's62
Thanks for the pics. They help a lot as I didn't realize you still had the bars in. I like the stance of your truck as it sits now, but I do like em low. Is the ride ok at that height? Keep up the good work and I'll be keeping an eye on the rest of your build.
Old 01-05-2014, 01:46 PM   #80
LVPhotos
LVPhotos's Avatar
The ride is softer the more you lossen and stiffer as you raise. I had the a-arms flat now up a little knowing the new stuff is coming. Remember with adjustment you need alignment or tire wear is eminent.
Old 02-07-2014, 04:51 PM   #81
LVPhotos
LVPhotos's Avatar
Playing in the garage. Porterbuilt Track bar mount tacked in, bar cut and welded to length. Some pie left overs from trimming fenders. The circle is schrader valve for bags. The black outline is stock shock mount for those looking to move to outside frame. Ground down the top of the pumpkin. Oh and installed the longer PB trailing arms.
Old 02-07-2014, 07:26 PM   #82
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Yer truck is so awesome!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-09-2014, 08:42 PM   #83
ZouchaR
This picture was taken at Tuckers????
And then I actually read the post... I knew it was Tuckers.... been there many times!!!
ZouchaR is offline   Reply With Quote
Old 02-09-2014, 09:36 PM   #84
LVPhotos
LVPhotos's Avatar
Yep, that was at TUCKERS a few years back. Just stopped in this Saturday after stopping by Fig Speed there on the corner to get spark plugs. Been to their shows, showed up to pick up parts and they were filming tv spot. Camera Guy was all over truck but as per most tv the good stuff gets cut. My desert race videos always got my Durango in at least one shot.
Old 02-11-2014, 08:01 PM   #85
LVPhotos
LVPhotos's Avatar
Sharing photos I came across these. The Welder Up guys will be hitting the Discovery TV show list in April. This one tows the '55. 1200 ft/lb it does it fast. Quite for little stack.
Old 02-11-2014, 08:11 PM   #86
LVPhotos
LVPhotos's Avatar
The crank really starts car. Neat how it works.
http://youtu.be/-eVt4RL2FLU
Old 02-11-2014, 08:13 PM   #87
LVPhotos
LVPhotos's Avatar
http://youtu.be/aMevqNjVV3M
Old 02-24-2014, 05:38 PM   #88
LVPhotos
LVPhotos's Avatar
Filling seams. If you look in the bed you can see where the fender trimming was done. Note: aired up not at ride height.
Old 03-22-2014, 11:01 AM   #89
ChrisDollins
ChrisDollins's Avatar
Cool truck! Really like the salt flats and tire choice! I was looking for pics of 18" wheels and tire sizes and ran across your post.
Chris
ChrisDollins is offline   Reply With Quote
Old 03-29-2014, 10:45 AM   #90
LVPhotos
LVPhotos's Avatar
Back from shop. Had everything welded up and notches installed. Shocks relocated.
Old 03-29-2014, 10:53 AM   #91
LVPhotos
LVPhotos's Avatar
Shocks mounted on PorterBuilt trailing arms. #extremeautocustoms
Old 03-29-2014, 11:48 AM   #92
informi
Thanks for sharing the pics. Looks great. In looking I see that you have 5 lugs in the rear. Just curious what you did to get rid of the 6 lugs? I have a 62, swapped in a newer cross member (out of an 84) so have 5 lugs up front and now need 5 in the back to match. I have looked into getting the spindles re-drilled, but not sure that is the best way to go. Any suggestions would be welcome.
informi is offline   Reply With Quote
Old 03-29-2014, 05:09 PM   #93
LVPhotos
LVPhotos's Avatar
I used the CPP axle swap. Or you can order up others with right measurements. The drums are stock five lug replacement parts. I believe the axles were 33.5 " not much to it. Pull tires, drums, drain rear, remove retainingbolt and pin, push axles in to release c-clips.
Old 03-29-2014, 05:50 PM   #94
informi
Do you happen to have the CCP part number? When I looked before (and again just now) they did not have a 62 listed. It starts with 63. Or were you able to get the 63+ one to work?
Thanks again
Old 03-29-2014, 06:32 PM   #95
LVPhotos
LVPhotos's Avatar
Mine was a 67-70 12 bolt. So the 63+kit worked . The older ones came with spider gears. Call Cpp to conferm.
Old 03-30-2014, 09:35 AM   #96
informi
Ok, that makes sense. Thanks for the help.
Old 03-30-2014, 11:38 AM   #97
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Looking good Bud! I'm dying over the ratrod with that cummins!
Old 03-30-2014, 11:49 AM   #98
LVPhotos
LVPhotos's Avatar
The new show for the Welderup guys will be coming out April on discovery. They also just shot Five Finger Death Punch video at the dry lake bed just outside town. They got a rat truck with 4bt. Facebook is packed with their projects. https://m.facebook.com/profile.php?id=140791382642269
Also the Guys at #extremeautocustoms posted many in progress pictures of mine.
https://m.facebook.com/profile.php?id=203626139674792
Old 04-21-2014, 12:44 PM   #99
LVPhotos
LVPhotos's Avatar
The six is in a 56 Bel Air.
Old 04-21-2014, 12:50 PM   #100
LVPhotos
LVPhotos's Avatar
More.
1962 chevy, bagged c10, manual transmission, short bed c 10
