11-19-2016, 09:35 PM | #76 |
Re: 4x4 48'
After a small hiatus I got back to work on making a bracket for my dash speaker.
I also finished installing the door latches. Next is the door locks. |
11-26-2016, 10:50 PM | #77 |
Re: 4x4 48'
With everything fitting on the cab I did a little painting and sprayed some rubber coating on the floor
12-03-2016, 08:43 PM | #78 |
Re: 4x4 48'
Chassis looks pretty good painted
02-01-2017, 10:00 PM | #79 |
Re: 4x4 48'
Doing more work on my headliner
02-02-2017, 08:15 PM | #80 |
6>8 Plugless........
Re: 4x4 48'
Nice work you're doing there!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-11-2017, 02:54 PM | #81 |
Re: 4x4 48'
Headliner is done! Truck pannles are painted (pics to come). Exhaust should be done this weekend. Assembly starts next weekend!
02-18-2017, 01:28 AM | #82 |
Re: 4x4 48'
Started installing the body on the chassis. Hope to have all the big pieces on by end of weekend
02-19-2017, 09:49 PM | #83 |
Re: 4x4 48'
The body is successfully installed on the chassis now on to the hundreds of pieces that go on it.
02-26-2017, 08:50 PM | #84 |
Re: 4x4 48'
Got the front and back glass in. I had to make an adjustment to the exhaust. Found out that the tailpipe was pointing straight into the rear fender. Nice to have a neighbor who has a pipe bender.
02-26-2017, 08:54 PM | #85 |
Re: 4x4 48'
Also got some trim put on. I love how that visor looks on there
02-28-2017, 12:08 AM | #86 |
Re: 4x4 48'
That is looking very nice. I really like the visors on them!
03-07-2017, 05:30 PM | #87 |
Re: 4x4 48'
Got my engine harness back and got it installed but need to tie it into the trunck harness. I'm planning on using the harness out of the s10 since I'll use everything but the fluid pump. I started diagramming the wires and hopefully I won't get confused. I got my air intake put on but need to shorten it to fit in the tight space. I got some panels for the back of the cab to get covered with the same clothe from my seat.
05-07-2017, 08:53 PM | #88 |
Re: 4x4 48'
Been working on the cab. Fitting the seat, column,and radio. Also laid out the bed boards
05-10-2017, 06:23 PM | #89 |
Re: 4x4 48'
That is looking very nice. Are you planning on taking it to Good guy's this year?
05-10-2017, 07:00 PM | #90 |
Re: 4x4 48'
Yeah if I have it done in time.
06-16-2017, 05:53 PM | #91 |
Re: 4x4 48'
Getting a few more things done on the truck. Came to the conclusion that I'm not making Good Guys this year, hopefully next year.
06-16-2017, 05:55 PM | #92 |
Re: 4x4 48'
Got the steering shaft in just need a steering wheel
06-16-2017, 08:45 PM | #93 |
Re: 4x4 48'
Nice work! What are you lacking to get it to GG's?
06-16-2017, 09:52 PM | #94 |
Post Whore
Re: 4x4 48'
Great project! I would love to put a visor on my 51 GMC but I'm 6'2" and I can't see stoplights as it is. I'm tuned into this channel!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-16-2017, 10:00 PM | #95 |
Re: 4x4 48'
I still have the follow to do
Fuel line Wiring harness Steering wheel Break lines Seat Radiator AC Oil/trans cooler I don't think I'll get it all done in one weekend. |
06-16-2017, 10:34 PM | #96 |
Re: 4x4 48'
Looking good so far!
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917 |
06-19-2017, 09:42 AM | #97 |
Re: 4x4 48'
Mounted the battery. Now I need to run the cables.
07-09-2017, 11:07 PM | #98 |
Re: 4x4 48'
Haven't got too much done lately. But should have the cooling system down soon. Panels came back from the upholster
08-21-2017, 06:07 PM | #99 |
Re: 4x4 48'
I got the engine/trans cooling lines ran to the radiator. Also got the heater and ac lines ran. Even got the rats nest of wires looking better.
08-25-2017, 04:38 PM | #100 |
Re: 4x4 48'
Once I got the steering lines reconnected I threw on the grill then I started one the fuel line now that the pump is installed. Hoping to have a test fire of the engine soon!
