Old 06-03-2014, 02:36 PM   #76
semn49
Re: 1950-ish Chevy 3100 Build
Progress!
I do have an engine stand you could borrow if you need. I know it's a ways to come get it, but if you're heading to Rochester?
semn49 is offline   Reply With Quote
Old 06-03-2014, 02:38 PM   #77
jrdamien
Originally Posted by semn49 View Post
Progress!
Appreciate it but I'll just drill the front plate through the frame.
jrdamien is offline   Reply With Quote
Old 06-03-2014, 05:29 PM   #78
jrdamien
Went over this afternoon before work just to drill the plate. Got the engine about as dead center in the frame as possible and drilled. Wasn't easy but it got done.
Now the question will be how precise the holes needed to be and whether or not I'll have to widen them to compensate for being off.
Old 06-30-2014, 02:44 PM   #79
jrdamien
So here's what the truck looks like right now.
http://i.imgur.com/w8KtgtCl.jpg
Engine is mounted. T5 with plate is mounted. Need a water pump adapter bracket I am waiting on. You can see the drive shaft laying on the floor. It's from a '92 Astro and is a perfect fit, literally. I'll set the pinion this week and get the rear welded up.
Then I just need to get some tires for it and it'll be ready for the body, brakes and clutch.
Old 06-30-2014, 02:59 PM   #80
semn49
Looking good!
What are you looking for in tires? Wheels too? Six hole disc brake style obviously.
Old 06-30-2014, 03:01 PM   #81
jrdamien
Looking good!
No, I put discs on the front and a Blazer rear axle with discs, too. But I have the wheels. Just need some decent but used and cheap radials. I'm thinking 235 75r15's would be tall and not too wide?
Old 07-29-2014, 05:23 PM   #82
jrdamien
This hasn't been exactly step by step because of all the in-between time spent learning the intricacies of what I'm doing. But here's the truck today with the engine mounted and the T5 in place. The engine is cleaned up, the water pump adapter plate and early pump are in place, and ready for paint. Oh, and got some great tires.
Old 07-30-2014, 05:52 PM   #83
jrdamien
And the first coat of paint:
Old 07-31-2014, 10:52 AM   #84
semn49
Lookin' good! Keep up the good work!
