02-23-2014, 09:22 PM | #76 |
Re: 1950 3100 Full Custom **GunMetal**
Looks good with the cab and running boards on....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-23-2014, 10:38 PM | #77 |
Thanks hope to have the front end all together in the next week or so
02-23-2014, 11:03 PM | #78 |
Formerly- 1972SuperCheyenne
Looks amazing, great work man.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-23-2014, 11:21 PM | #79 |
looking good, remember to plumb in a water trap before the accuair valve. looking forward to your updates
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
02-23-2014, 11:37 PM | #80 |
Thank you sir ! Yeap plan on putting the trap right right off the tank
02-24-2014, 08:59 PM | #81 |
finally got the accuair in today..... and got to pound away on it for a few hours got most of the wiring ran .... need to get some compress lines made... and still debating if i want to go with the copper line kinda weighing my options at this point..
pretty happy with how i was able to hide most of the wiring.! The accuair setup is top notch ... unbelievable technology. |
02-24-2014, 09:01 PM | #82 | |
i havent gotten this far in the instructions but when you installed your accuair i assume you get everything plumbed and wired and working with the accuair controller and then continue on to installing the sensors??? |
02-24-2014, 09:41 PM | #83 |
Truck is looking great Vince.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
02-24-2014, 10:31 PM | #84 |
Thank you sir
02-25-2014, 12:00 AM | #85 |
I don't think the sequence matters but I installed my sensors first because I was working on the shock mounts in the same area, I knew you would be impressed with the quality, I was
02-25-2014, 07:24 AM | #86 |
Okay got it and you had no problems keeping it in the 2.75 travel range ?
02-26-2014, 09:42 PM | #87 |
02-26-2014, 09:51 PM | #88 |
looks so awesome!
02-26-2014, 10:04 PM | #89 |
02-26-2014, 10:16 PM | #90 |
Wow, that looks incredible! Well done.
'58 Apache |
02-26-2014, 10:22 PM | #91 |
Thank you sir
02-26-2014, 10:56 PM | #92 |
looks stellar man, so your just running plastic up the front? I like how the compressor is farther from the tank, let that air cool down before filling the tank. really dig that accuair set up. Thought about that the route and may even go there.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
02-26-2014, 11:04 PM | #93 |
Yes I took the cooper to the outside of the frame rail and then switched it over with a union fitting ... Worked out well and no leaks ( knock on wood )
As far as the Accuair it's amazing I won't do another vehicle without it. If only they could have a little faster shipping it would be stellar but its well worth the wait. The compressors worked out well and luckily I have a great guy right down the street the does any kind of line fittings I could ever want |
02-26-2014, 11:42 PM | #94 |
Super nice job, looks great...Jim
02-27-2014, 01:15 AM | #95 |
Very nice.
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build |
02-27-2014, 07:05 AM | #96 |
Thanks fellas hope to get the sensors installed tonight !
02-27-2014, 10:21 AM | #97 |
Looks great. I love the contrasting color of the copper next to the gray frame paint. I imagine Copper is pretty easy to work with. The only draw back would be the cost. Are those both fair assesments?
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-27-2014, 10:28 AM | #98 |
The copper was very easy to work with ...after I got it straightened out. With a good tubing bender it's pretty straight forward
And as far as cost I probably only spent about 60 bucks on 50 foot and ended up with about 15 foot left ( I used a bit to practice on ) |
02-27-2014, 11:38 AM | #99 | |
Marc
02-27-2014, 11:50 AM | #100 |
Cut my pieces to the lengths I needed and then layd it out on the bench and took a 18 inch 2-4 and rolled it ... Comes out straight as an arrow
