Old 09-13-2014, 10:03 PM   #76
COS399
COS399's Avatar
Re: 1991 V3500 Project Heavy Hauler
Looking good. We have already had some snow and below freezing mornings over here.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 09-14-2014, 03:20 AM   #77
MTCK
MTCK's Avatar
Thanks COS. Glad to see you are getting out and driving your rig a bit. I'm hoping the white stuff stays away another couple of weeks... I have some more outdoor home improvement work to do before the snow flies.
I swapped the steering column, adjusted the shift linkage (after a brief freak out when I couldn't put it in park), and decided to just button it up. I've seen a few of these trucks be able to pull off the wood grain trim, but this isn't one of them, so I put the Cheyenne trim in place of the Silverado trim before installing the dash pad. I put in all my LED dash lights, dome light and courtesy lamp under the front dash. Much better. Had to tweak the contacts on the lights as the dash lights are supposed to be replaced as an assembly that includes the plastic mounting base. I took them apart and made it work.
I couldn't resist taking it for a little ride, so I took my wife a coffee since she is on night shift. Turned over 100k miles on the way there. Sure is nice having tilt steering, a real steering wheel and a stereo with Bluetooth.
Need to center the steering wheel, install the rear belts, install the fat mat on the roof, doors and pillars, drill the rest of the holes for the trim and and and and.....
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-14-2014, 12:48 PM   #78
jhama78
jhama78's Avatar
Originally Posted by MTCK View Post
Do that for sure, j-rod. What time of year are you normally up here? We are supposed to be getting some great aurora these next few nights but it is overcast. I've been out to poker flats for a tour about 20 years ago when I was in junior high. It was pretty cool!
I'll actually be coming back out there sometime between Turkey Day and Crimmas for about a week to do some surveying work on one of the launchers. But, we normally are there in the summer since 90% of our work is outside.
Ill give ya a shout when I head that way in Nov/Dec for sure.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 09-14-2014, 12:50 PM   #79
whitels1
whitels1's Avatar
I gotta get me some of them LEDs they are super bright! Looking good man!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-14-2014, 03:16 PM   #80
MTCK
MTCK's Avatar
Sounds like a plan, j-rod. Thanks Dave. Funny you should mention how bright they are, since they come from www.superbrightleds.com Haha. I was farting around looking for pics of this stock color on a 3+3 and came across this truck. For 25k you could not duplicate what this truck had done to it:
http://www.cajeeprestoration.com/tru...91/crew-cab/45
http://www.2040cars.com/Chevrolet/Ot...on-4x4-626276/
-Marcus
Project Plow Truck
Old 09-15-2014, 02:45 AM   #81
MTCK
MTCK's Avatar
Had to work a half day so didn't get as much done. I picked up a steamer from Walmart and removed the film from the back window and rear doors. No more purple tint! I also finished the fat mat install on the rear doors and got the left side all buttoned up. I had to trim the plastic where the power window switch was originally to allow the crank to pass through. The fabric trim piece covers the exposed end almost perfectly. When the interior upholstery is getting done I'll have them make a smaller hole centered at the crank.
Amazon came through with my seat heaters for four seats. If you are sitting in the middle back you are SOL. Everybody else will have toasty buns. These were highly rated and made by Dorman.
-Marcus
Project Plow Truck
Old 09-15-2014, 10:09 PM   #82
MTCK
MTCK's Avatar
Made in the USA! Thanks CaptKaos. Quality appears to be excellent, just don't ask what shipping to AK cost.
-Marcus
Project Plow Truck
Old 09-15-2014, 10:33 PM   #83
whitels1
whitels1's Avatar
Lookin good!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 09-16-2014, 12:25 AM   #84
joe231
joe231's Avatar
Gotta ask...
How much was shipping on the door panels? And how much were the panels?
I need a set
CHEVY ONLY
Old 09-16-2014, 03:27 AM   #85
MTCK
MTCK's Avatar
Originally Posted by joe231 View Post
Gotta ask...
I need a set
Hey did my wife put you up to this??? The panels were a little under $200 and shipping was a little over $100. I was able to use the power door panels in the rear but no way up front. I'll get the front and rear fabric parts covered in the same material.
-Marcus
Project Plow Truck
Old 09-16-2014, 12:08 PM   #86
joe231
joe231's Avatar
Lol
Thanks!
CHEVY ONLY
Old 09-16-2014, 08:36 PM   #87
y5mgisi
Second Chance Program
y5mgisi's Avatar
I cant wait to see how you install the heated seat elements.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-16-2014, 09:14 PM   #88
MTCK
MTCK's Avatar
I'm going to hand them to the upholstery shop and tell them which direction to point the cords! The switches and relays will go in the center console.
-Marcus
Project Plow Truck
Old 09-23-2014, 02:09 AM   #89
MTCK
MTCK's Avatar
Finally got a little work done. My dad was in town this weekend so it was fun to do a little work with him. We bled the brakes after installing my ORD lines, but still had a mushy pedal so I grabbed a bleeding kit from napa and bench bled them. Lots of gunk came out of the brake lines.
-Marcus
Project Plow Truck
Old 09-23-2014, 02:14 AM   #90
MTCK
MTCK's Avatar
I installed the speaker pods. They fit great and feel solid. No parking brake clearance issues once I adjusted it. I also put the drivers door together buttoned up the seat belts in the rear.
Not pictured are working license plate lights and a new 7 - pin trailer wiring plug.
-Marcus
Project Plow Truck
Old 09-23-2014, 02:27 AM   #91
y5mgisi
y5mgisi's Avatar
You are getting lots of work done!
Old 09-23-2014, 11:00 AM   #92
joe231
joe231's Avatar
Very nice!!
CHEVY ONLY
Old 09-23-2014, 11:10 AM   #93
MTCK
MTCK's Avatar
Thanks guys. Man she is a lot quieter now! Still a lot of wind noise but that is expected with these trucks.
-Marcus
Project Plow Truck
Old 09-23-2014, 10:53 PM   #94
Greenlee
Greenlee's Avatar
Looking good!
Greenlee is offline   Reply With Quote
Old 09-28-2014, 12:57 PM   #95
MTCK
MTCK's Avatar
Thanks Greenlee. Truck has been getting lots of work done to it lately so today it had to return the favor. About an 11k lbs machine plus whatever the trailer weighs. I need more power!
-Marcus
Project Plow Truck
Old 09-28-2014, 11:49 PM   #96
Greenlee
Greenlee's Avatar
Nice! Looks like it's not squatting the rear end much.
When I was a kid my dad had a Case backhoe that probably weighed about 12,000 lbs. We pulled it all over with the place with a 78' Chevy 3/4 ton. I'm sure we needed more power and more suspension, but we didn't know any better.
Old 09-29-2014, 12:55 AM   #97
COS399
COS399's Avatar
So, will you truck be moving over to the diesel conversion section????
Looking good. Keep it up.
Old 09-29-2014, 01:11 AM   #98
whitels1
whitels1's Avatar
LSx Section...you mean?
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 09-29-2014, 03:21 AM   #99
MTCK
MTCK's Avatar
Greenlee you are right - I have hauled bigger loads with smaller trucks, but this 350 is just soooo tired. Thank goodness for 4.56 years. Got any pics of the Case and old 3/4 ton?
COS and Dave you guys are both close, but no cigar. Keeping spark plugs but not an LS motor. Hint on page one maybe?
Just calc'd my fuel mileage through a tank of fuel. Only about 15 miles were with a trailer. 8 mpg. Can't get much worse than that.
-Marcus
Project Plow Truck
Old 09-30-2014, 02:53 AM   #100
MTCK
MTCK's Avatar
Decided to stop tempting fate and wired up a new trailer brake controller. Tekonsha prodigy 2. I'll report on how it works tomorrow. I mounted the controller using the holes for the OBD port so I didn't need to drill any holes. No pictures since the website won't upload from my phone.
-Marcus
Project Plow Truck
