Old 03-12-2019, 09:41 PM   #76
jamyers
jamyers's Avatar
Re: 1969 C10 Longbed BubbaTruck
I can't believe it, but somehow I don't have any pics of installing the brackets, spacers and hubs, sigh...I'm sure I took some...
At any rate, the brackets bolt to the spindles in 3 places, one at the top where the old brake cylinder mounts, the other two at the bottom. Scarebird sends new Grade 8 bolts for everything.
Scarebird kit has two spacers. One goes onto the stub axle, right up against the inner shoulder - it moves the inner bearing out away from the body maybe 1/4". They're very well made and a precision "slip" fit onto the axle. The second spacer is for the outer bearing, which has a larder ID than the OD of the axle. It's more of a sleeve with a tiny lip that goes to the outer edge of the bearing.
Otherwise, installation of the hub/rotor is straightforward. The grease seal rides on the inner spacer, and the original outer bearing washer catches both the outer bearing and the bearing sleeve/spacer. The original nut is used, and Scarebird sends a new cotter pin.
That gets the bracket, bearing spacers, and hub/rotos mounted.
(looking for pics)
My Chevy Truck Project Build Thread
'62 Ranchero - 200 I6, 3-on-the-tree, power nothing.
'71 LeSabre - 455 Stage 1, power everything.
jamyers is offline   Reply With Quote
Old 03-13-2019, 06:00 AM   #77
Metaldoc
Metaldoc's Avatar
I saw your lifters and feel your pain. These are 1/2 hour old and my cam looks like yours. Complete engine rebuild twice.
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 03-15-2019, 12:15 PM   #78
jamyers
jamyers's Avatar
OUCH!!! That hurts just looking at...
