Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-19-2017, 05:18 PM   #76
cablackone
Re: Rusty 68 K20 Burb
On my 67 to the center of the distributor is 2 3/4 inches.
cablackone is offline   Reply With Quote
Old 07-19-2017, 05:21 PM   #77
cablackone
Firewall to front edge of core support in center is 39 3/8. Same above headlights 39 3/8
Old 07-19-2017, 06:46 PM   #78
Jsfucttruck
Thanks so much. Do you have a hei or points dizzy?
That motor is set back in there tight to the firewall, that must be a pain to lift out of there. That is not much room to be able to tip the motor down to get it in too.
So I would assume that the fan shrouds are also different between 2 and 4wd.
Thanks again. The info here is priceless.
Jsfucttruck is offline   Reply With Quote
Old 07-19-2017, 07:15 PM   #79
cablackone
Mine has points thats why I measured to the center. The centerline will not change on either. As far as being tight as long as you can get a screwdriver in to remove the cap it wont really matter. Can't anwser the shroud ? Have the stock v8 one with my burb. My C20 6cyl dosen't have one.
Old 07-19-2017, 07:24 PM   #80
Jsfucttruck
On another note. I didn't have to scrap the 68 K20. I had a few interested peeps but the solid one fell through the wk I had to make the shell/tub/chassis go away.
A good friend took it, not sure what he is going to do with it, but it found another home.
Old 07-19-2017, 07:35 PM   #81
Jsfucttruck
Sweet. Good info. Thank you. I think I am going to luck out and maybe have a little more room the a 4x 67-72 frame, but less than similar yr 2wd. We'll see
Old 07-19-2017, 07:43 PM   #82
Jsfucttruck
What is the measurement to the firewall?
Old 07-19-2017, 08:17 PM   #83
cablackone
firewall to radiator support
Old 07-20-2017, 07:00 PM   #84
Jsfucttruck
Here is where I am measuring from. If that measurement is on the $ then I am close.
Old 07-20-2017, 07:05 PM   #85
Jsfucttruck
So the gas tank might be able to move slightly forward. The front body mount has room to go forward just enough. I got to lift off the body again to remove the stock 78 K20 Driver rear shock mount that is mounted to the top of my frame. It is in the way of a crossbar.
Old 07-20-2017, 07:11 PM   #86
cablackone
You are about 4 inches to far forward.... with your core support
Old 07-20-2017, 07:28 PM   #87
Jsfucttruck
Fuel filler is on the opposite side too. Not sure what I am going to do about that. Might just hack up a 81-91 burb filler door setup.
Old 07-20-2017, 07:30 PM   #88
Jsfucttruck
Are you measuring the same spot?
Old 07-20-2017, 08:09 PM   #89
cablackone
I measured from the top of firewall by the seal
Old 07-20-2017, 08:30 PM   #90
Jsfucttruck
I almost had to do this.
Old 07-21-2017, 01:39 AM   #91
Jsfucttruck
So the neighbor was out of town and let me get a few more measurements. Looks like I am 5" off the mark, and my core support will have to come up too. This puts the front body mount in the way of the upper shackle. I might have to swap in the 52" springs and move the eye hole back sooner than later.
Old 07-31-2017, 09:15 AM   #92
notchbackgta
Just spin the fuel tank around. I did the opposite of you kind of. I put the square body tank in my 69 frame and I just pointed the neck on the tank to the drivers side, so it should work spun around in the square body frame.
notchbackgta is offline   Reply With Quote
Old 08-02-2017, 04:18 PM   #93
Jsfucttruck
I had thought of that but I never liked the external fuel fill, and for 4x4 purposes, I am worried I might rip it off in the rocks/trees.
Old 08-03-2017, 12:26 PM   #94
notchbackgta
Either way, you should be able to turn the tank around and put the filler on the LH side
Old 12-07-2017, 06:24 PM   #95
Jsfucttruck
Man this project is moving much slower than I want. Time and $$$ seem to keep going to other things. Life. And a few other broken trucks.
I kinda got to put the body mounts on hold. I got a few other things to consider before I mount it.
I started bolting up a few doors and converting the clamshell setup to barndoors. The doors are pretty beat up, but it's what I got for now.
There is a set for sale on here that even have the correct trim to match. Not the right color, but I lack the trim on my beat up set.
I also need to find front doors, maybe with the odd trim too.
Old 12-07-2017, 07:01 PM   #96
Jsfucttruck
The doors and hardware came off a burb that had already converted from tailgate to barn door. I am not sure if the hardware like the strickers and stoppers are in the correct spots. I also got this piece of wood as a spacer attached to one door.
Does anyone got pics of the original stuff?
Old 12-07-2017, 09:50 PM   #97
Jsfucttruck
I got the doors on and somewhat adjusted. They are pretty dented/bent up. The bottom has some rot coming through. I still have the strikers,stoppers, and limit brackets to mount.
If I could find a decent price on some rear glass seals I could almost have it sealed up for the winter.
