Old 06-15-2015, 04:59 PM   #76
disasterbus
Re: Ian's Tennessee Honey '64 Short Box Step-side - England
very neat installation, looks excellent.
disasterbus is offline   Reply With Quote
Old 06-24-2015, 04:07 PM   #77
ibrown50
ibrown50's Avatar
A quick up-date on progress,
I've finished the power steering pump install, the modified bracket is on and works great and the pulley (which is not included in the kit) is fitted and lines up spot-on.
Name:  Power steering pump.jpg
I also managed to get the drop arm, idler arm and tie rod fitted without any fuss, however the kit also doesn't include the pitman arm nut (so don't throw your old steering box away until you've removed the nut Martin)
And today my "new" control arm arrived, all the way from Albuquerque New Mexico, kindly supplied by Michael Bustamante, a top bloke air freight courtesy of Langy's rod Shop and sourced from this very forum. Oh and thanks to Don for the sound advice a week or two back
Now it's off to the blasters and then I can begin my suspension rebuild
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 06-24-2015, 05:07 PM   #78
michael bustamante
michael bustamante's Avatar
s`cribin
1967custom
michael bustamante is offline   Reply With Quote
Old 06-27-2015, 07:03 PM   #79
ibrown50
ibrown50's Avatar
Got the control arm back from MD Shot blasting today, blasted and primed, it's in really good shape.
Name:  Michael after.jpg
I've managed to strip out the old bushes and shafts (you can't beat a 3ft power bar) and put a coat of high build etch primer on today, but before doing that I prepped the arm (I'd done the other three a while back).
I'm probably stating the obvious but it really is worth spending 20 minutes "de-burring" the edges if you want to avoid rust. The majority of edge burrs are caused during manufacture, some are from the blanking dies, however, some are also caused by the material flow which is a by-product of this type of stamping process.
I've worked for a number of car manufacturers over the years and done a fair bit on suspension. In-order to give anti-corrosion warrantees the OE's perform a CCT test (compound corrosion test) where parts are literally sprayed with a near boiling (like 180 - 200 degrees) caustic solution. Parts are checked for corrosion every 100 hours or so and the point at which they start to rust becomes the rating. (like 200 hours CCT, 300 hours CCT etc.) every failure I ever saw was caused by edge burrs.
Ofcourse I should have done the prep before blasting!!
Two coats of primer on the edges also keeps the rust away!
Old 06-27-2015, 09:32 PM   #80
Ta2Don
Ta2Don's Avatar
Great Work!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 06-28-2015, 10:47 PM   #81
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Hi Ian. Some nice work going on here. Interesting thread... everything from pinstripes to pandas. I especially like the pinstriping on the steering wheel. I look forward to seeing more.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 06-29-2015, 07:16 AM   #82
ibrown50
ibrown50's Avatar
Originally Posted by Ta2Don View Post
Great Work!
Thanks Don
Johnny, thank you for your kind words
Old 06-29-2015, 07:28 AM   #83
ibrown50
ibrown50's Avatar
A quick up-date, I managed to finish painting the control arms yesterday, as usual I coated up the edges first,
Then hung them up so I could get right round them, they got 2 coats of an isocyanate based 2 pack each, it dries really hard and wears well. (plus it's very shiney )
Yesterday was really sunny so once they'd dried a little, I hung them in my green house to "bake" (DIY paint oven), to be honest I've been so busy with other stuff this year this is probably the first time I've been in there.
I'm really pleased with the way they turned out, next job will be to fit the ball joints and start rebuilding the suspension
Old 07-06-2015, 04:14 PM   #84
ibrown50
ibrown50's Avatar
Well my eldest daughter has just bought her first house (it's a bit of a fixer -upper) so this weekend I have been DIY dad.
I still managed a bit of progress though. Saturday I assembled the upper control arms, very straight forward once I'd figured out the ball joint (thanks to chevy_mike).
Name:  Upper arm ball.jpg
The upper control arm shafts are the perfect shape to clamp in a vice while tightening the bushes. I used a 36mm socket on an 18" power bar and they went together very easily.
Name:  upper shaft.jpg
Name:  Upper arm vice.jpg
Name:  Upper arm assy.jpg
Old 07-06-2015, 04:25 PM   #85
ibrown50
ibrown50's Avatar
Sunday I did the lower control arms, these were a little more of a challenge. I have a ball joint press but it was designed for English cars and just isn't man enough when it comes to Chevy trucks .
So I improvised, with a piece of a 9" axle case, a 42mm socket and a 10" G clamp, this is what my dad would call a ship yard fix, but it worked a treat.
Name:  Lower arm press.jpg
The shafts and bushes were much the same as the uppers, once again clamped in the vice and tightened. This time a 42mm socket and 24" power bar
Name:  Lower arm vice.jpg
I was especially chuffed because I got them all built up without damaging the paint
Name:  Lower arm assy.jpg
All assembled ready to fit.........as soon as I can find the next couple of spare hours
Name:  Lower and upper assy.jpg
Old 07-06-2015, 05:15 PM   #86
mjh1965
mjh1965's Avatar
Looking good Ian if you weren't so far away I would drop mine off because you have done such a good job . It's great that you are ahead of me in your build . That way I get the heads up on how to assemble everything before I do it on mine .
A wise man learns from his mistakes a wiser man learns from the mistakes made by others
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 07-07-2015, 02:16 AM   #87
Grizz1963
Grizz1963's Avatar
Now why did I not think of that first......?
But to agree there with Martin, your progress is awesome Ian, and things continue to look great on your build.
I am currently getting the itch to start back on my truck as some of the recent distractions are winding down.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-07-2015, 02:30 AM   #88
ibrown50
ibrown50's Avatar
Martins thank you, love the quote, I'm sure to use that myself, sorry I can't help with the control arms but the pin striping will be fine
Rian, thank you for the kind words, I must admit seeing the progress of others on this site motivates me to keep going
Old 07-08-2015, 11:08 AM   #89
ibrown50
ibrown50's Avatar
Today I had taken the morning off work for my sons "school sports day. This ended up being cancelled due to the cold wet weather. It looks like summer may be over........... this year it was on June the 26th, between mid day and 3 in the afternoon
However every cloud has a silver lining, MD blast cleaning had collected my hood on Saturday to blast and prime it for me. About 10:00 they rang to ask if they could drop it off,
Oh yeah
It looks even better now it's been blasted and primed, with only a couple of tiny holes revealed by the blasting. To be honest they are so small I'm not sure what to do with them I'm so used to bigger rust repairs!
I also managed to get the control arms bolted up on both sides, so not a bad day after all.
Name:  Fromt suspension PS.jpg
Name:  Front suspension DS.jpg
Old 07-09-2015, 03:00 PM   #90
ibrown50
ibrown50's Avatar
Nothing to do with my build but very nice
Today was a funny day. I work in Newcastle city centre on the Quayside, home of the largest Court in the Area and surrounded by Law firms and the cafes, bars and resturants that seem to go with them. You will also see every model Jaguar, BMW, Audi and Mercedes you could ever wish to see.
Today the monotony was broken by a really cool Captian America bike, complete with reproduction Pan Head and matching helmet
Name:  Captain america.jpg
And an even cooler (68 I think) short box C10, certainly brightened up my day
Old 07-10-2015, 07:26 PM   #91
Johnny_Lamebridge
Looks like a rear bumper on the front of that C10.
I've always preferred Dennis Hopper's "Billy bike" over Fonda's.
Old 07-11-2015, 08:12 AM   #92
Ta2Don
Ta2Don's Avatar
X2 on the "Billy Bike"
DON
Proverbs 27:17
Old 07-11-2015, 03:34 PM   #93
ibrown50
ibrown50's Avatar
X3 For the Billy Bike
Although I've always been a bit of a "Fat Bloke" myself, below are some pictures of my last ride, mods included Cyclesmith fat bars, 5 gallon tanks and a custom candy and pearl paint job (including Betty Boop) by yours truly.
Old 07-12-2015, 12:51 PM   #94
ibrown50
ibrown50's Avatar
The plan for the front was a 4 - 4.5" static drop with a disc brake conversion thrown in for good measure. After "researching" many of the posts on this forum I eventually went for 2" drop spindles and 2" lower springs. Living in the UK I can't simply go to my local auto parts store and pick up a few parts if I need them, so for this reason I've always tended to buy kits and the most comprehensive ones I can find. This spindle kit came from Tom's Classics and includes McGaughy's 2" drop spindles and 12" drilled and slotted rotors.
The Spring kit is from POL and includes 2" drop springs front 4" rear and comes with matching shocks and hardware. Both kits were sourced through Langy's Rod Shop here in the UK.
Name:  POL Spring kit.JPG
The "spot the difference" picture
The springs and spindles were assembled using the "red neck" spring compressor (a trolley jack) and were a perfect fit on the new ball joints.
Old 07-12-2015, 01:00 PM   #95
ibrown50
ibrown50's Avatar
The rotors include new bearings, seals, nuts etc, you literally only need your own grease.
The callipers include flexi's, pads, banjo bolts, even the copper washers.
They all went together really well, I was very pleased with both kits, neither are particulary expensive but both (IMHO) are both great value
Old 07-12-2015, 01:41 PM   #96
Ta2Don
Ta2Don's Avatar
Awesome work...
DON
Proverbs 27:17
Old 07-12-2015, 03:24 PM   #97
Grizz1963
Grizz1963's Avatar
Ian, you really are busy building a serious keeper here.
Looking great, thanks for the update.
Old 07-12-2015, 05:18 PM   #98
mjh1965
mjh1965's Avatar
Looking good , glad it went together well ,it's defiantly worth buying a complete kit . Keep up the good work it won't be long and you'll be driving it again
MY BUILD THREAD:
Old 07-14-2015, 10:54 PM   #99
Johnny_Lamebridge
Originally Posted by ibrown50 View Post
...custom candy and pearl paint job (including Betty Boop) by yours truly.
That paint job looks great! Its too bad you have to run that huge yellow license plate.
Coincidentally, I have the same Hooker exhaust on my Softail.
Your front suspension / brakes are looking good. The drop is same as what I did. The one thing I wish I would've done was change to the newer control arms with the rubber bushings. Smoother ride and no maintenance.
Old 07-15-2015, 02:26 AM   #100
ibrown50
ibrown50's Avatar
Awesome work...
Thanks Don
Yep don't think I'll be parting with this one anytime soon (but would love an early Blazer to park next to it)
Thanks Martin, although the "to do" list is still very long
Thanks Johnny, I reckon dragging that licence plate around costs about 5 mpg I agree the later arms would be a better deal, the problem we have in the UK is finding parts
