Old 09-25-2016, 10:48 AM   #76
'63GENIII
'63GENIII's Avatar
Re: L29 454 Build for '63 K15 with NV4500
Originally Posted by Captainfab View Post
Looks good
Yeah I would have to do that as well.
Did you use the DIY4x B52 brackets for your front springs?
Captain, yes I used the B52 kit for 67 - 72.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-27-2016, 03:04 AM   #77
aotte1
Looking very nice!
Les
aotte1 is offline   Reply With Quote
Old 09-29-2016, 12:34 PM   #78
Marshy
Looks real nice. Except that axle, you'll need to paint that too.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 09-29-2016, 03:36 PM   #79
'63GENIII
'63GENIII's Avatar
Yeah. That's been bugging the crap out of me too. Just not as much as having a non running truck in the garage😁.
Chris
'63 k15 long step
Old 10-01-2016, 03:28 AM   #80
MTCK
MTCK's Avatar
Very cool project. Bringing back all kinds of memories! How many likes did your donor motor have on it? My L29 cleaned up with a hone and a polish too with 180k on the clock.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-24-2016, 12:26 AM   #81
'63GENIII
'63GENIII's Avatar
Thanks Marcus, the guy that I got it from said around 80k. My machinist said it really didn't seem to have a whole lot of miles on it. So.. I guess 80k might have been right.
Chris
'63 k15 long step
Old 10-24-2016, 12:30 AM   #82
'63GENIII
'63GENIII's Avatar
Wow, I haven't updated in a while but Ive made a lot of progress since last time. Let me get some pics up in a minute.
Chris
'63 k15 long step
Old 10-24-2016, 01:23 AM   #83
'63GENIII
'63GENIII's Avatar
With the firewall and frame painted, it was time to drop in the engine and transmission. I assembled everything outside of the truck thinking it would be easier than installing the trans from underneath. I was partly right.
Once in the truck though, the engine would not turn over by hand easily. Turned out that the flywheel was hitting the Advance Adapters BH and needed grinding. DOH! Out came the 4500 and the bell housing. Not terribly difficult but unexpected and necessary.
I was going to run the exhaust manifolds that came with the L29 but they would have required way too much frame trimming for my liking. I had a set of Thorley Tri Ys for a square body that fit nearly without an issue. So they went in.
I figured that while I was in there, Id re do all the brake lines that had been cobble together for the last 50 years. After I finished the brake lines, I felt confident enough to do the fuel and hydraulic clutch lines. Yes I scrapped a few beautiful lines after getting a perfect double flare and then seeing the tube nut on the workbench. The black plastic blocks are my home made fuel, brake and electrical support clamps. 6$ worth of plastic. We'll see how they hold up.
Chris
'63 k15 long step
Old 10-24-2016, 01:32 AM   #84
'63GENIII
'63GENIII's Avatar
I was on a roll at this point until I read something somewhere that said something about an O-ring that needed to be put in between the rear main cap and the block to seal the oil passage that goes through it. You can see the recess that it goes into at the right of the crank. After deliberating on it for a couple of days, I accepted that I'm an idiot and that the engine was not going to be fired without that damn o ring sitting on the workbench. BTW, the new 1 piece pan gaskets are kinda expensive. Really hated to tear apart the brand new one that was in there for only a couple of weeks and zero run time!
Chris
'63 k15 long step
Old 10-24-2016, 01:40 AM   #85
'63GENIII
'63GENIII's Avatar
Onto the wiring. Well I don't really have many photos of the wiring but I must have spent at least 30 hours on it. When I got the harness from Howell in 2009, I had planned on putting the ECM in the engine compartment. 7 years later, I changed my mind and wanted it in the cab. The wiring was long enough to allow the ECM to mount under the dash but I had to relocate a lot of the sensors and other controls. With a little measuring and a lot of guesswork, I decided this would be the best location to go through the firewall. BTW, I am envious of anyone who has smoothed out a firewall. I didn't have the time or the budget anymore to fit that in. Swiss Cheese it is I guess.
Chris
'63 k15 long step
Old 10-24-2016, 01:51 AM   #86
MTCK
MTCK's Avatar
Real good progress. I did the same thing with the o-ring and rtv on the rear main cap, but it wasn't in the truck yet...
-Marcus
Project Plow Truck
Old 10-24-2016, 01:51 AM   #87
'63GENIII
'63GENIII's Avatar
They say that after a month of potatoes and beans, even a change to beans and potatoes can be a good thing so I left the ECM mounting for later since the harness was into the cab now. I needed to do something different so I turned to the fuel system.
I had an '89 blazer tank sitting under the house for many years and recently installed it when I had the bed off for the rear spring swap. At that time, the carbed 396 was doing just fine so I set the tank up for a carb but had never hooked up the fuel lines.
I dropped the tank, pulled the pickup and sending unit out and started to figure out how Id run the 0-30 fuel gauge with this set up. Then I remembered that Vin63 was modifying sending units to work with our old gauges. I read some of the posts on this and decided that the best thing for my set up would be to cut the original sending unit off of the in cab unit and weld it to the new pickup / in tank pump unit. I checked it after with an ohm meter and it doesn't seem like I messed it up. I think it may work ok.
Chris
'63 k15 long step
Old 10-24-2016, 02:14 AM   #88
'63GENIII
'63GENIII's Avatar
I reinstalled the tank after putting new fuel injection hoses on the sending unit, connected the gauge and pump wire harness and fuel supply / return lines. These for whatever reason, I used 37 deg flares and Russel AN fittings. I think it may be because Russell made an adapter fitting for the stock fuel flex lines that are on the engine. Either way, one side of the fuel system is almost done.
I had really been stressing over the filler neck location though. I didn't want it too far to the rear of the truck as I kinda liked where it was on the cab. I couldnt use a "in the bed" filler because Im frequently hauling stuff and didn't want it buried. I didn't want to buy a kit (they're pretty expensive) and wasnt confident enough in my bodywork skills to install a gas door type of filler. Again, turned to this forum and voila! I saw on one of the posts where a member had gone to a muffler shop to bend up a filler tube. BAM! I was down at the muffler shop this weekend with my Son to do just this. He was the only guy open on Saturday, did super clean bends and even swedged the ends of the pipe to fit the hoses I was connecting. 20$! He will be doing the exhaust when I get it out of the garage!
I brought the pipe home, made a couple of adjustments with a bandsaw, trimmed the filler neck that came with the tank, took a few more measurements and punched the hole in the fender using a knockout punch. I test fit all of the pieces, prepped the filler neck to weld, got out the welder and no gas! LOL. Looks like Im working on something different again!
Chris
'63 k15 long step
Old 10-24-2016, 02:24 AM   #89
'63GENIII
'63GENIII's Avatar
Yeah, that was right after I has pulled the bell housing / trans and reinstalled. Was WAY bummed about the o ring. Little different than the old Mark IV engines. Oh well, cheap tuition. At least we found them at the right time right?
Was yours a stock rebuild or did you do any work to it? Not a lot of info on these things. Most throw a carb on em and ditch the FI.
Chris
'63 k15 long step
Old 10-24-2016, 02:36 AM   #90
'63GENIII
'63GENIII's Avatar
Being without gas and looking for another project that needs finishing, I turned back to the electrical - namely mounting the PCM. I had found a place under the glove box that I thought would work. I just needed to fabricate a mount now.
I had a rough idea of what I needed and also the 1997 under hood PCM mount for the fender.
I cobbled a sheetmetal brake out of a gate hinge, a 2x4, an 8" piece of angle iron and a vise.
I then cut up the factory mount so I could attach it to the sheet metal shell that I made on the DIY backwoods brake. Its not a show piece but it painted up well and holds the PCM perfectly under the dash with room to mount the fuel pump relay and power supply.
Chris
'63 k15 long step
Old 10-24-2016, 02:44 AM   #91
'63GENIII
'63GENIII's Avatar
As of today, this is about where it stands. I was really hoping to be done by August, then my birthday at the end of September, then Halloween and I don think I'm gonna make Halloween now. Think Ill be happy with having it running by Christmas this year! LOL.
Chris
'63 k15 long step
Old 10-24-2016, 05:46 AM   #92
snj8198
snj8198's Avatar
Neat!
I like your brake lines. I'm looking forward to hearing how the Tri Y's perform. I've ran them before on small blocks but I have no experience on big blocks. I really considered them on my current motor and believe they would have done superbly for my uses. They look like they have a full 3/8" flange. The Hooker Comps dont.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 10-24-2016, 01:21 PM   #93
61K10
61K10's Avatar
Looking good--your pcm is in the way of your AC lol. I guess you get that nice ocean breeze most of the time though. you're getting close.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-25-2016, 01:34 AM   #94
'63GENIII
'63GENIII's Avatar
Originally Posted by snj8198 View Post
Neat!
The brake lines went pretty simple. I used the copper / nickel / steel stuff and its pretty easy to bend. Thought Id get fancy with the gravel guard to cover up some of the little wows in the lines but that idea backfired a little. The gravel guard actually rattles a little. It may come off later.
The Tri Y headers are almost as heavy as the manifolds. 3/8 flanges and heavy wall tubing. I was tempted to try them without gaskets. They were a freebie. Hoping they work well with the cam and heads.
Chris
'63 k15 long step
Old 10-25-2016, 01:46 AM   #95
'63GENIII
'63GENIII's Avatar
Haha! Ive got a real hot "tune" on that PCM. When it starts getting too hot, its programmed to automatically open the kick panel vent with a stepper motor! LOL.
To be honest, its gonna be close to the heater elbow that comes into the cab. Looks like a Vintage Air setup is out and the knee freezer is going back in.
Yes its getting close. Down to little knick knack stuff like having male ends for both connectors on the O2 sensors, intake plumbing ect. But yes, getting so close its driving me nuts working OT at work to try to keep the project moving but not having time to wrench! Always a catch 22 right?
Hope to get gas for the welder on Wednesday and maybe finish the filler pipe / neck this week.
Chris
'63 k15 long step
Old 10-30-2016, 10:34 PM   #96
'63GENIII
'63GENIII's Avatar
Drumroll please....... it fired right up today! My son helped me get the fuel primed up to the injectors and voila! I tried to get a video from my phone but the file is too big to upload. Anyway, just thought Id share. Now for cooling, exhaust, front sheetmetal and interior LOL. Might have it done by next spring at this rate!
Chris
'63 k15 long step
Old 10-30-2016, 10:53 PM   #97
snj8198
snj8198's Avatar
Congrats! I was wondering how you were coming along on this. It's been so long I figured you scrapped it for a Toyota.
Steve
Old 10-30-2016, 11:13 PM   #98
Captainfab
60-66 Nut
That is a great feeling when an engine you build fires up and runs good. Congrats.
Old 10-31-2016, 12:16 AM   #99
MTCK
MTCK's Avatar
Great work! That's an accomplishment that just makes a person smile. I was so relieved when it made oil pressure hahaha.
-Marcus
Project Plow Truck
Old 11-01-2016, 11:02 PM   #100
'63GENIII
'63GENIII's Avatar
This thing they call work is keeping me from getting done and helping me finish all at the same time. Toyota? C'mon Steve, Id have to get one of those VWs with the sneaky computer!
No doubt Captain! Only glitch was having the supply and regulator return lines reversed at the tank. Wasn't even planning on trying but realized all I had to do was connect 3 wires to the computer. It actually kinda scared my Son and I when it lit. So much so that I had him shut it down almost immediately.
Thats the very next thing on the list - getting all of the gauges connected! I did prime the engine with a gauge on it but pulled it off to install the engine. Just a little more pipe work!
Chris
'63 k15 long step
