Old 09-03-2016, 07:04 PM   #76
OLDYELLOW
OLDYELLOW's Avatar
Re: 1970 Chevy C10 pickup
Originally Posted by rsgt View Post
what brand of door bottoms did you use? How was the fit? Thanks
We purchased them from Ecklers. On one of the bottoms where the door skin folds over on the side was trimmed a little short, so I had to weld a piece on. Like most reproductions, you have to make them fit.
OLDYELLOW is offline   Reply With Quote
Old 09-04-2016, 06:17 PM   #77
oldyellowssun
oldyellowssun's Avatar
While I stripped down the driver side quarter panel, my old man did the body work on the passenger side quarter panel.
I must be bright, Daddy called me sun--- http://67-72chevytrucks.com/vboard/s...d.php?t=703733
oldyellowssun is offline   Reply With Quote
Old 09-04-2016, 06:38 PM   #78
flashed
It's looking good .
flashed is offline   Reply With Quote
Old 09-18-2016, 01:02 PM   #79
oldyellowssun
Over the past 2 weeks, we finished up the body work on the passenger side quarter panel and got it primed. The hood hinges were cleaned and painted.
Old 09-18-2016, 02:02 PM   #80
In The Ten Ring
Originally Posted by oldyellowssun View Post
I also started to clean parts. We are using electrolysis to clean the hood hinge.
YES! Finally! A member after my own heart!!!!
I use a combination of electrolysis and Evaporust soak. First the former, followed by the latter. Much more effective over the other alone.
A sand blaster would be more efficient and effective, but I have no room for one.
In The Ten Ring is offline   Reply With Quote
Old 09-18-2016, 04:46 PM   #81
OLDYELLOW
OLDYELLOW's Avatar
Sand blasting has its place, but on parts like hinges, latches and window cranks I like to use electrolysis. There is nothing worse than opening a hood or rolling up a window and hearing that gritty grind.
Old 09-18-2016, 06:28 PM   #82
oldyellowssun
My pops fitted the lower pillar patch & cut out the passenger side floor board
Old 10-02-2016, 07:55 PM   #83
oldyellowssun
Typical Reproductions
Old 10-02-2016, 07:58 PM   #84
oldyellowssun
Floor board and rocker welded in on passenger side.
Old 10-02-2016, 09:09 PM   #85
IronCanine
I'm trying....
IronCanine's Avatar
Looking good. I like how you let the Grand Dorito photo bomb the hinge pics. Keep the Ford pics to a minimum please. This is a GM site.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 10-03-2016, 09:24 AM   #86
OLDYELLOW
OLDYELLOW's Avatar
I apologize, maybe I'll get done with the Grand Dorito soon and replace it with some GM metal.
Old 10-16-2016, 06:53 PM   #87
oldyellowssun
This weekend we finished up the floor and got it painted. I also cut bolts out of the bed so that we can get it ready to take off.
Old 10-16-2016, 09:04 PM   #88
IronCanine
I'm trying....
IronCanine's Avatar
Looking great. Can't see the ground anymore!
Old 10-17-2016, 04:10 PM   #89
mcbassin
Still Learning
mcbassin's Avatar
Very nice looking project. You have done a great job repairing the rust. Keep up the good work. Subscribed....
mcbassin is offline   Reply With Quote
Old 10-18-2016, 08:20 PM   #90
oldyellowssun
Thanks!
Old 10-22-2016, 06:24 PM   #91
oldyellowssun
Today we built a frame for the bed of the truck to go on. After, we took the bed off.
Old 10-22-2016, 07:40 PM   #92
IronCanine
I'm trying....
IronCanine's Avatar
I recognize those blocks!
Old 10-23-2016, 02:30 PM   #93
oldyellowssun
Forgot to post this yesterday. Here's a picture of the bed on the frame we built
Old 10-23-2016, 03:23 PM   #94
Dad's72
Dad's72's Avatar
Good idea. Got any measurements on the bed roller frame
Dad's72 is offline   Reply With Quote
Old 10-23-2016, 07:27 PM   #95
OLDYELLOW
OLDYELLOW's Avatar
6' long x 5' wide x 32" high. We bought eight 2x4x8 studs and had nothing left but a little saw dust. Found the 10" wheels at harbor freight for $4 a piece.
Old 10-23-2016, 08:10 PM   #96
oldyellowssun
Dad, I hope these are the measurements that are correct after you made it 7 inches too long. We had to go back and cut off seven inches
Old 10-23-2016, 08:16 PM   #97
oldyellowssun
Since we got the bed off we were able to work on the cab corner today.
Old 10-23-2016, 11:35 PM   #98
Dad's72
Dad's72's Avatar
Thank you. Gona do this. I will have to adjust the length for my long bed. Did you just bolt it down to the 2x4?
Old 10-24-2016, 07:01 AM   #99
OLDYELLOW
OLDYELLOW's Avatar
Yes, so it want slide around when you push it.
Old 10-24-2016, 08:42 AM   #100
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress on the bed and cab.
