Old 05-04-2017, 05:58 PM   #76
irl104
Re: My 1968 C30 Wrecker rebuild
With a few days that I have been able to work on this. I have made some progress. I got the red paint bought and painted.
irl104 is offline   Reply With Quote
Old 05-04-2017, 06:02 PM   #77
irl104
Cold weather and rain has been our forecast. A few more pictures. The red painting is complete. Next up will be the silver.
Old 05-04-2017, 06:21 PM   #78
flashed
Its all looking good ,staying tuned for more .
flashed is offline   Reply With Quote
Old 05-04-2017, 08:59 PM   #79
Moose Monkey
Moose Monkey's Avatar
WOW. looking great. Are you going to mount the old two way on dash or roof top? Had one mounted on driver door but keep banging knee.
70 c 10 daily Rider
Moose Monkey is offline   Reply With Quote
Old 06-18-2017, 06:32 PM   #80
irl104
Moose, I'm not sure I'm going to put a radio in it yet. I've had just a day here and there to work on this again. I had to remove the winch and get it broke loose from years of sitting. I ordered new bearings and seals for it. I ordered new bearings, races, lug nuts, studs, and seals for the wrecker dollies. I did some painting using chassis saver silver. I did give in on painting the bed black, well mostly, like it was originally.
Old 06-18-2017, 07:22 PM   #81
irl104
Finally got things coming together. I used Herculiner on the bed to make it more durable.
Old 06-19-2017, 02:36 PM   #82
Moose Monkey
Wow!!!! Almost makes me want to break down just for honor of being towed by your truck. She is looking great.
70 c 10 daily Rider
Old 06-28-2017, 04:34 PM   #83
irl104
It took me a full day to get the bed mounted on the chassis by myself. It's starting to come together.
Old 06-30-2017, 10:14 PM   #84
irl104
Adding more final touches.
Old 07-01-2017, 01:50 PM   #85
Moose Monkey
Nice exhaust. She coming together.
70 c 10 daily Rider
Old 07-01-2017, 03:04 PM   #86
flashed
Its looking great .
Old 07-01-2017, 03:38 PM   #87
Shaky
Six in a row makes it go...
Shaky's Avatar
This is excellent. Glad to see you kept the 292.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 08-12-2017, 02:37 PM   #88
irl104
With a few days here and there, there has been some progress made. I got the dollies and sling assembled. Mounted the power take off shaft and made the linkage.
Old 08-12-2017, 04:01 PM   #89
irl104
I got the clutch cable ran for the winch. The marker lights and the exhaust pipes mounted. In the process of rebuilding the winch right now and painting the west coast mirrors. It's been nice to be able to get a few things accomplished on this.
Old 08-14-2017, 10:00 AM   #90
outfield
It's looking great!
I saw a 67/68 Chevy Wrecker out in the middle of nowhere yesterday and thought of your build! It may have been a runner, but looked like it needed a lot of work!
outfield is offline   Reply With Quote
Old 08-30-2017, 08:50 PM   #91
irl104
Outfield, they are almost a thing of the past. That would have been neat to see. The days I've been able to work on this I have been doing the wiring. The wiring is all done on it now. One glitch I need to figure out. Just about done rebuilding the winch.
Old 08-30-2017, 09:04 PM   #92
flashed
Looks nice ,cant wait to see more .
Old 09-04-2017, 07:40 PM   #93
Moose Monkey
She is looking great. What glitch? We don't have anything like that, only good things!
70 c 10 daily Rider
Old 09-08-2017, 04:15 PM   #94
irl104
Moose Monkey.
My one glitch is when I turn the right turn signal on my bright light indicator flashes on the dash. When I turn on my high beams on, my right turn indicator comes on in the dash. I think I need to switch the wiring.
Old 09-08-2017, 08:12 PM   #95
Moose Monkey
Dark blue right turn goes into switch. Light green high beam . goes to floor switch. See no glitch.
70 c 10 daily Rider
Old 09-09-2017, 07:59 AM   #96
irl104
I used factory wiring on this, not the original. I need to trace it down to where it is wrong and move the two wires. In the column area or the fuse box area. I'm not sure.
Old 09-09-2017, 08:14 AM   #97
Moose Monkey
On dash pin 11 high beam. Pin 09 right turn. On high beam switch pin 03 still checking on turn signal switch
70 c 10 daily Rider
Old 09-09-2017, 08:24 AM   #98
Moose Monkey
Pin j on turn signal switch.
70 c 10 daily Rider
Old 09-09-2017, 08:10 PM   #99
irl104
Moose,
Thank you for the information.
Old 09-09-2017, 09:31 PM   #100
Moose Monkey
She is shaping up WOW
70 c 10 daily Rider
