08-29-2019, 02:17 PM | #1 |
Always on the hunt...
Re: F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Reque
Last BBC alternator bracket Id pic...
10-07-2019, 05:40 PM | #2 |
Do you still have the clutch z bar bracket
10-10-2019, 07:26 AM | #3 |
On the road
Hi Mel,
would you happen to have another BB fan shroud?
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
10-14-2019, 08:46 PM | #4 |
That pictured engine side BBC bellcrank/z bar pivot ball stud seen earlier in thread has been sold/shipped, we do have another original BBC bellcrank pivot ball stud available, this one was removed from an original 72 C/20 402 big block truck. $165. + $10. for the ride, payment can be sent via US postal moneyorder, paypal or credit card over the phone. Let us know, Mel
10-06-2019, 10:10 AM | #5 |
Looking for 1968 bbc ac brackets for swp. I have the intake manifold bracket and arm as well as the front compressor plate but need the rest.
10-15-2019, 12:27 PM | #6 |
On the road
Mel, I do appreciate your honesty. I am still interested in it, it would be residential address and zip is 71457. Please be patient with me if I don't answer right away as I am working overseas on an offshore installation and communications can be probematic plus I am probably 11 hours ahead of West coast time. Many thanks
10-17-2019, 01:09 AM | #7 | |
10-17-2019, 10:44 PM | #8 |
On the road
Mel I will take it all, PM sent
10-18-2019, 12:02 AM | #9 |
I’m looking for the upper AC bracket, the one on the manifold. Any chance you have that one?
Thanks |
10-18-2019, 09:46 AM | #10 | |
10-18-2019, 12:13 PM | #11 |
I’ll take the middle one, please PM me your PP info, thanks.
10-18-2019, 12:39 PM | #12 |
10-18-2019, 12:05 AM | #13 |
10-19-2019, 12:20 PM | #14 |
On the road
Thanks Mel
11-14-2019, 02:07 AM | #15 |
Hi Mike, hope your trip home was uneventful and went as planned. The big block fan shroud and clutch fan have been shipped out via FedEx home delivery on Wed. 11/13, as of this evening FedEx is projecting that you should see the box on Wed. 11/20 by the end of the day. Thanks again and let me know if we can help with anything else, Mel
01-10-2020, 12:26 AM | #16 |
hello i am looking for the ac bracket that bolts to intake manifold as well as piece that attaches to it, the metal line for distributor advance and the throttle stop and bracket that attaches to the front of carb with single spade terminal that points straight out. all parts are for 72 model thanks phillip
01-10-2020, 11:46 PM | #17 | |
01-13-2020, 02:24 PM | #18 |
just checking back thanks
01-14-2020, 06:51 PM | #19 | |
01-14-2020, 10:59 PM | #20 |
ill take them thank you
01-18-2020, 11:53 PM | #21 |
Hello Phillip, here is the other requested part to be combined/sent along with the BBC AC compressor mounting brackets and 72 BBC vacuum advance line. The below pictured fuel vapor canister and mounting bracket setup was removed from a 72 BBC 402 C10, it has the same 7030605 part number that you sent us molded onto the top of canister, see below highlighted second to last pic. Price is $65. and add $5. more for combined shipping in larger box than was previously quoted. Thanks, Mel
01-19-2020, 03:33 AM | #22 |
ill take it as well thank u very much lmk where to send payment
01-13-2020, 02:52 PM | #23 |
Is any of the stuff in post still available???
01-14-2020, 04:45 PM | #24 |
Mel, sent you a PM about a carb spacer. Thanks.
01-14-2020, 06:21 PM | #25 |
If looking for BBC parts then yes, if you check first post you will see that the thread has been updated and multiples of these BBC parts have been added/sold over the last year plus. We decided to turn this one into a long running "request a BBC part" thread so that we don't have to have multiple threads for the same/like parts going at the same time and it also saves lots of room in our inbox storage as it cuts down on parts request pm's. Let me know which big block items you are looking for info on and we can add pics/pricing if parts are on hand. Thanks
Hello, just had a look back thru over two hundred messages and couldn't find anything from you on a carb spacer, if big block related just add requested parts info here and if we have it available I'll add it. Thanks, Mel |
