Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-29-2019, 08:46 PM   #76
sweetk30
sweetk30's Avatar
Re: 1969 C50 crew cab build
1ton down is setup for 2.75" wide stock leafs . aftermarket like lift kits go 2.5" you cant cut in the the housing for 3" wide unless you do a home brew u-bolt conversion as you will loose the 2 bolt holes for the spring plate .
the width for a dana 60 front is 32" center to center .
the 1ton rear for a 14ff is 40.5" center to center and 2.5" wide springs .
the rear can be worked around a bit but the front has the pass side spring mount cast in to the diff housing .
todays axles i would tend to start looking at ford f-450 and f-550 super duty stuff . there a lot bigger and bigger parts and also factory 19.5 rim size .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-29-2019, 10:06 PM   #77
Drewbee
Thanks for the info. I’m looking at the K50 rtech build and he said he just put the 1 Tom axles in. I know there are bigger axles but I’m just wondering if it’s as easy as sliding in the 1 ton axles and bolting them to the leaf springs.
Drewbee is offline   Reply With Quote
Old 07-30-2019, 04:45 AM   #78
Pvmt-Pndr
Put everything in your new thread instead of here...
Pvmt-Pndr is offline   Reply With Quote
Old 12-11-2019, 08:42 AM   #79
Drewbee
Any new progress?
Old 05-11-2021, 12:18 PM   #80
goldenburb
goldenburb's Avatar
2021 I understand life keeps use Busy, But any updates ?
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 12-20-2022, 11:20 AM   #81
Ricky Rodder
It's ashamed this one died off.
Ricky Rodder is offline   Reply With Quote
Old 12-29-2022, 11:56 PM   #82
LynnB
Please say it ain't so Joe.
would love to see this finished.
Any one know the OP?
LynnB is offline   Reply With Quote
Old 03-26-2023, 04:48 PM   #83
gup1972
Hello all. Life got in the way and the build is for sale. It pains me to let it go, but I have no choice. Frame as shown in pics, 1997 cummins 12 valve w/125,000 miles, 2012 G56 6-speed transmission that was rebuilt 10,000 miles ago, mint front clip from C50, and various other parts. No cabs, beds, front or rear ends included. Take it all for $10k. I have way more than that in it. 636-432-9509
gup1972 is offline   Reply With Quote
Old 03-26-2023, 05:06 PM   #84
gup1972
some pics
Old 12-18-2023, 01:49 AM   #85
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man, wish I was in the position to take her off your hands and finish things out.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
