Old 06-27-2020, 09:40 PM   #76
Jason 56
Re: 1959 Fleetside Short Bed Project
Truck is looking awesome! I’ll be following.
Not sure the 2011 6 speed will work with your 2002 engine. That trans is controlled by a tcm( transmission control module) that is contained in the ecu. Gm didn’t start using a tcm until 2007 when they changed to the 58x reluctor. Your 2002 won’t be compatible unless you change the reluctor wheel n ecu To one that has an internal tcm... if that’s possible. I’m not sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 07-01-2020, 03:47 AM   #77
daveshilling
daveshilling's Avatar
Originally Posted by BLAC View Post
With all the craziness going on with the Coronavirus lockdown I decided to buy a trailer and truck to pull my project out of LA with my fiance to her parents house on a ranch in Idaho. A big bonus is that my father in law has built a lot of hotrods and task force trucks... so this will be picking up some serious steam.
These are all massive updates, you're going HARD. Keep it up, every day is one day closer to cruising time!
daveshilling is offline   Reply With Quote
Old 07-12-2020, 04:50 PM   #78
BLAC
BLAC's Avatar
Interesting, I havent read anyhting about not being able to use a tr6060 with a 24x. I will be running Holley stand alone. Not sure if that makes a difference but I will look into it.
1959 Apache Fleetside Short Bed
BLAC is offline   Reply With Quote
Old 07-12-2020, 04:52 PM   #79
BLAC
BLAC's Avatar
Thanks! more updates coming soon
Old 07-12-2020, 05:36 PM   #80
BLAC
BLAC's Avatar
Cut off the stock mounting points for the rear end and making it a permanent fixture
Adding some bracing
Cups for upper air bag mounts
rear shock mounts:
Old 07-12-2020, 05:54 PM   #81
BLAC
BLAC's Avatar
More bracing in the rear to fit around a fuel cell
Making lower control arms
Old 07-12-2020, 07:53 PM   #82
slammed57
slammed57's Avatar
killer pipe work
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 07-12-2020, 10:26 PM   #83
youngrodder
youngrodder's Avatar
Man that's an impressive chassis....Nice work.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-12-2020, 11:13 PM   #84
BLAC
BLAC's Avatar
Originally Posted by slammed57 View Post
killer pipe work
thats what she said... sorry
Old 07-12-2020, 11:14 PM   #85
BLAC
BLAC's Avatar
Marc
thank you! my father in law has a JD2 manual bender we put to work. I am really considering a roll cage...
Old 07-13-2020, 12:13 AM   #86
59chev
59chev's Avatar
Kick ass fabrication work!!
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 07-14-2020, 08:02 AM   #87
Jason 56
Wow, great fab skills! Very very nice work.
Old 08-09-2020, 05:08 PM   #88
BLAC
BLAC's Avatar
the progress continues...
Got new Holley valve covers. The red should be good for a few HP
About 2 weeks of sha-hit loads of grinding and sanding to get the whole frame (top and bottom) metal finished getting it ready for primer.
Throwing sparks in gawds country
bottom side of the frame where the 1959 Apache meets the 2015 Camaro SS
Top of the fabricated rear airbag mount
I love me some files
Primered black until I get back home to LA where I will have it blasted and epoxy primered.
Old 08-09-2020, 05:21 PM   #89
BLAC
BLAC's Avatar
Going back together (and I got a zx14 )
5 Gallon Air Lift tank mounted behind the drivers step
Dual Viair 444C compressors mounted
Air Lift 3h manifold mounded behind the seat
Got some of her clothes back on
Old 08-09-2020, 06:55 PM   #90
Jason 56
Wow! Your fab work is so clean. Very inspirational and makes me wish I went with a similar suspension. Your truck is going to be top notch!
Old 08-10-2020, 01:32 AM   #91
BLAC
BLAC's Avatar
Thanks! It’s fun now that the air management is installed and it moves around on its own haha
Next up is one piece glass in the doors
Old 08-19-2020, 10:50 PM   #92
BLAC
BLAC's Avatar
1959 Apache Fleet Side + 2015 Camaro SS = Camache
Starting to build the raised bed frame. Because of the IRS I am able to keep a pretty decent bed depth and only ended up raising the bed floor about 6" while being able to lay the body on the ground:
Old 08-20-2020, 08:36 AM   #93
youngrodder
Looks great man..Nice fab work
Marc
Old 08-20-2020, 11:51 AM   #94
daveshilling
BAD ASS!!! So much work in these photos, you're killin it. I love all the bent tube, it really shows off how bespoke the chassis is vs. bolting on parts from the hot rod store like I did. Excellent work...I won't even try to keep up. I made two fuel lines and a bracket this month lol!
Old 08-20-2020, 02:01 PM   #95
BLAC
BLAC's Avatar
Marc
Thanks I appreciate it. Progress is fun, sometimes I need to work on little pieces like mounts because looking at “the whole picture” can be overwhelming ha
Old 08-20-2020, 02:02 PM   #96
BLAC
BLAC's Avatar
Definitely a lot of time captured in these pictures haha nothing wrong with bolting in parts, your truck is going to be awesome. You are way ahead of me if you are already building fuel lines haha
Old 08-20-2020, 09:04 PM   #97
reg3
Wow!! Killer fab work my man, I really like those rear upper bag mounts! You've got one killer rig on your hands!
reg3 is offline   Reply With Quote
Old 08-20-2020, 09:15 PM   #98
slammed57
slammed57's Avatar
Very nice fab work!
My 57 current build
Old 08-29-2020, 05:18 PM   #99
BLAC
BLAC's Avatar
Core Shifter base installed with a Hurst stick and an unbranded Hurst shift ball. Shifts are nice and short and precise.
Old 01-19-2022, 09:24 PM   #100
BLAC
BLAC's Avatar
Holy neglected thread, batman...
I am still working on the truck, lots has been done, I am just way behind on updates. I will go a more comprehensive update when I have a little more time but here are a couple teasers..
I went air/air intercooler, here is the evolution of the mount design:
Looks good! I went with a Treadstone IC, should be good for 1,000hp:
not exactly fitting... the cross bars gotta go:
Im liking it... What isnt pictured is a lot of metalwork in the opening, contouring the IC with a rolled edge to look like factory:
Happy with that!
oh and I picked up a snail... BW S480 SXE
