Old 01-19-2020, 02:38 AM   #76
lukeembry
Re: 85 C10 LT/6L80 Frame off build
Originally Posted by Schroedum View Post
Holy crap. Awesome build!
Thanks. Keep in touch
lukeembry is offline   Reply With Quote
Old 01-19-2020, 02:46 AM   #77
lukeembry
One of my favorite things on this build is the brakes. Master Power has a really killer set up for these trucks with 13” 4 piston fronts and 12” 4 piston rears. Works well with the Baer remaster.
One thing I’m super picky on is battery cables and terminals. I like them clean and simple.
Old 01-19-2020, 07:45 AM   #78
MHarvey
I completely understand where you’re coming from on the exhaust. I’m hoping mine isn’t too loud so I stuck with 2 1/2” piping and some quiet mufflers for it. The manifolds look really nice and give you great clearance around everything, that’s for sure.
Your attention to detail is awesome on everything with this truck. I can’t imagine what the finished product is going to look like. Getting anxious to see how it all turns out.
MHarvey is offline   Reply With Quote
Old 01-20-2020, 08:17 PM   #79
lukeembry
A few chassis pics
Old 01-20-2020, 08:25 PM   #80
lukeembry
Few more
Old 01-21-2020, 01:27 PM   #81
erichevy
erichevy's Avatar
Wow, looks amazing! Give me some inspiration for my 87 SWB.
1979 GMC C35 - Farm Work Truck
1986 GMC C25 Crew Cab
1987 SWB R10
erichevy is offline   Reply With Quote
Old 01-21-2020, 03:44 PM   #82
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Absolutely amazing work! Cant wait to see more!
--Josh
Old 01-21-2020, 04:41 PM   #83
lukeembry
a few more chassis pics
Old 01-21-2020, 04:45 PM   #84
lukeembry
Belltech springs and sway bars
Old 01-21-2020, 08:09 PM   #85
SCOTI
SCOTI's Avatar
Super nice!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2020, 10:03 PM   #86
moregrip
moregrip's Avatar
Solid! better rub some dirt on it! You know what happens if you don't!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-22-2020, 09:18 PM   #87
lukeembry
Final blocking of the Tamco 5310 primer with some 320 grit, reminding myself why I quit painting a few years ago! After this I finished with a DA and 500 grit before heading to the paint booth.
Old 01-23-2020, 01:05 AM   #88
Kermitt47
Kermitt47's Avatar
Beautiful truck, I love your attention to detail. I have a couple of engine questions. Does you front accessory drive lengthen the engine over the stock truck drive and where are you connecting the vacuum for the power brakes? The exhaust manifolds look great. Thanks
Kermitt47 is offline   Reply With Quote
Old 01-23-2020, 07:22 PM   #89
lukeembry
Thanks, I will have you an answer tomorrow on the accessory drive. I’m going to compare them. For the booster I drilled and threaded a 1/4 npt 90 degree 3/8” fitting under the rear cover.
Old 01-23-2020, 07:41 PM   #90
lukeembry
A few cab trim in pics using Tamco basecoat and 2104 clear
Old 01-23-2020, 08:04 PM   #91
lukeembry
I’m hoping for a extremely quiet truck inside with windows up so I went with Vibro Solutions for sound deadener. They have some nice kits for C10 trucks. 2mm mat with a 6mm closed cell foam for top layer. I covered the floor, firewall, back wall, under headliner and inside doors.
Old 01-24-2020, 08:03 AM   #92
lukeembry
comparing a L83 to the Holley mid-mount it looks to move the accessories forward roughly 1/2"-5/8" forward.
Old 01-24-2020, 10:48 AM   #93
STOCKISH
STOCKISH's Avatar
What color code is that blue?
--Josh
Old 01-24-2020, 08:34 PM   #94
lukeembry
Code 21 factory color
Old 01-24-2020, 10:51 PM   #95
lukeembry
All new American Autowire body/chassis harness, ecm mounted and all 3 Dakota Digital boxes mounted along with Vintage air evap box.
Old 01-24-2020, 11:16 PM   #96
Kermitt47
Kermitt47's Avatar
Thanks for the measurement. That makes a nice tight package. Are you going to keep the Active Fuel Management in the tune? This should make a nice driver when you get all the engine wiring sorted out.
Old 01-25-2020, 11:12 AM   #97
lukeembry
Yea I’m happy with the accessory drive, the fit, function and OE looks are awesome. I turned the afm off, I figure I can get 20 mpg without it and skip any issues it could cause in the future.
Old 01-25-2020, 02:51 PM   #98
Mattchu60
We must think alike, as my build is pretty similar to what your doing (yours is nicer!) but I also have the American Autowire 83-87 kit on the shelf to install into my c10.
How was the wiring install? The directions look pretty good - it does seem like all the engine wiring stuff can be skipped with the LS swap - did you end up using any of those wires in the engine bay side or coil them up/cut them off?
If you have any other tips for the wiring install please let me know - it looks strait forward when its sitting in the box, but in real life is usually not so easy.
Mattchu60 is offline   Reply With Quote
Old 01-26-2020, 11:31 AM   #99
lukeembry
The harness is super nice, anything you don’t want to use you can unpin and save in case you need it later. The only engine stuff I used was the alternator trigger wire. I remember shortening the headlight/parking lot harness some for looks. Make sure you have the correct crimpers and it’s not bad at all. I spent about 2 weeks in the afternoon but I’m very picky about how things look and usually do things multiple times so it takes longer. Feel free to pm me if you have questions. Be glad to help.
Old 01-26-2020, 11:37 AM   #100
lukeembry
A few pics of the new harness.
