08-08-2019, 02:40 PM | #76 |
Re: My "new" 1968 c20
sounds reasonable.
08-08-2019, 02:41 PM | #77 |
No more holes.
08-23-2019, 06:08 PM | #78 |
Did some floor repairs today and used the new streacher/shrinker for the first time makes life much easier
08-25-2019, 02:37 PM | #79 |
Welded it all up today. Just need to prime and seam seal it
08-27-2019, 04:40 PM | #80 |
Hung the radiator support and bolted on the door and fender . Both OEM pieces everything lined up pretty well even the rocker with a few 5 pound sledgehammer plows on a 2x4 . Came to the cab corner . It was a cluster ###! . It was almost like it was for an extended cab . Had to cut it into 3 pizza slices just to get it to line up. 5 hours I would rather not repeat. Other side is getting a few small pieces.
If anyone is doing cab corners stay away from the CHL brand
08-27-2019, 04:41 PM | #81 |
Also did the passenger door pillar and kick plate yesterday
08-27-2019, 05:41 PM | #82 |
Nice work, gittin her done before the winter come!!!
10-14-2019, 04:00 PM | #83 |
Should update the build. New cab counters and passenger rocker. Should have just made my own corners had to cut them all up to fit the truck. Drip rails so far are perfect
10-14-2019, 04:06 PM | #84 |
All painted today . I'm piecemealing it. Can't do the whole truck at once. Finish up the door jambs and cowl area next if the weather cooperates. Roof is going to be white not original to the truck but I want it that way
05-01-2020, 01:51 PM | #85 |
Bed is on did it last fall been to cold and rainy for much work .
07-09-2020, 07:16 PM | #86 |
Been doing the gutter/ firewall this past week made someprogress
09-23-2020, 10:08 AM | #87 |
Few new pics
09-23-2020, 12:34 PM | #88 |
Just here to tinker
Wow! Great work! That top is smoooooth.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-23-2020, 12:53 PM | #89 |
I’m in the process of doing the same rust repair/bodywork, and know how much work it is. Keep it up.
09-27-2020, 08:06 PM | #90 |
Finishing up the floor
09-27-2020, 08:10 PM | #91 |
First coat didn’t come out so nice . This is the second coat Omni single stage
09-28-2020, 02:09 PM | #92 |
Nothing wrong with single stage. Looks Good!!!
Carry on, man!!! |
09-29-2020, 10:30 AM | #93 |
I like it specially for solid colors . Talked to a painter after the first coat didnt go well. He told me to not add the reducer . It calls for 4:1:1 he recommended just 4:1 .
09-29-2020, 10:36 AM | #94 |
Finished the drivers floor yesterday lots of stitch welding got sunburn on my arms ,coated everything I could with por 15 prior to welding. Also coated the passenger side going to let it cure then paint it body color when I do the inside of the cab
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-30-2020 at 07:21 PM. |
10-18-2020, 10:47 AM | #95 |
New cab bushings . Still need to tourqe them down but it did raise the cab a good bit. Around 1/4 inch but it should come down after it torqued and settled. Decided black for the underside still needs another coat . Truck was basically only primed underneath no saddle paint that I could find
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 10-20-2020 at 09:16 PM. |
11-10-2020, 09:22 PM | #96 |
I keep plugging away
11-10-2020, 09:32 PM | #97 |
Noticed I forgot the cab prep pictures
11-11-2020, 12:37 AM | #98 |
Looks great Mark.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-11-2020, 08:40 AM | #99 |
Thanks . I'm really into it more than I wanted to be . Been neglecting my other cars but I can see light at the end of the tunnel.
11-11-2020, 01:43 PM | #100 |
Good lookin' work!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
