12-19-2019, 10:08 PM | #76 | |
Re: 68’ GMC frame off build
Great job on that hardware. Good choice. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
01-17-2020, 11:29 AM | #77 |
Looking back over your thread I noticed the incredible work done to your bedside. That has to be the least amount of paint removed for the shortening process I've ever seen. That is one patient and skilled dude. I say just throw some clear on it, it's too pretty to hide!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-23-2020, 02:32 AM | #78 |
Thanks, I think it’ll look pretty sharp.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
01-23-2020, 02:34 AM | #79 | |
01-23-2020, 10:13 AM | #80 | |
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
01-30-2020, 02:43 PM | #81 |
In for the ride!
01-30-2020, 06:34 PM | #82 |
Almost Satisfied
I couldn't grind the paint off that neat with taped lines...let alone weld it back together
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
01-30-2020, 11:21 PM | #83 | |
Currently a slow ride but it’s about to speed up.
I’m just glad that there’s a guy local to me doing it.
02-12-2020, 12:49 AM | #84 |
Picked up another part of the puzzle.
Scored a nice running 327 from a buddy of mine. It’s not the forever engine busy it’ll do for now. Putting the little man to work helping out. He’s sorta interested in working on them, he loves the idea but is pretty slow joining me. I’m just gonna let him join at his pace. Don’t want to push him away
02-12-2020, 04:14 AM | #85 |
Started on the brake line install tonight. I bought a kit from Inline Tube. I can’t complain about the fitment or quality. Every line required a little bit of tweaking but nothing more than I expected. I’d buy it again happily.
The only issue I have is that it didn’t come with any fittings to connect the lines where needed. Lucky for me I never throw anything out and all the original lines including unions were up in the attic.
02-16-2020, 03:33 AM | #86 |
Finally went and picked up my box sides. They’ve been ready since Xmas but I’ve just been too busy to make the 3 hour drive to get them.
I couldn’t be happier. Here’s some close ups.
02-16-2020, 12:21 PM | #87 |
Fenders look great and you will be proud of that In line tube kit.
It saves time and looks good too. I put a full set of stainless tubes on a truck of mine years ago. It was the best looking part of the truck against a black painted frame. But nobody but me crawled under there to look Great Progress . Will you clear coat those rear fenders or ??? .
02-16-2020, 03:47 PM | #88 | |
I’m on the fence about the bed scars. Part of me wants to just blend them since I’ll have to blend the the rockers and cab corners anyways. But another, possibly bigger part of me wants to just blend the cab pieces and and then clear the whole truck. Decisions decisions
02-20-2020, 05:20 AM | #90 |
Agreed! A 67-68 GMC has always been on my wish list.
02-20-2020, 05:31 AM | #91 |
Put together the 327 over the last few days.
Was at a swap meet this past weekend and scored some 461 cylinder heads. Completely rebuilt, complete with z/28 valve springs. This allowed me to comfortably install a Comp Cams 274. Complete with headers and the Black widow exhaust, she should sound pretty wicked. The engine had a billet oil pan on it when I bought it, not my style but it’s really good quality. So scuff and paint works for me.
02-21-2020, 03:00 AM | #92 |
Engine and trans are in.
327/700r4
02-21-2020, 11:49 PM | #93 |
Now that's just eye candy there...
02-22-2020, 11:46 PM | #94 |
Thanks.
That’s the plan, mostly original body, detailed everything else😁😃
03-07-2020, 04:13 PM | #95 |
Pulled the rear out of storage and got her all cleaned and painted.
It’s the factory 3:73, 5-bolt rear from my 72’ blazer. Had it rebuilt a few years before I pulled it from the truck.
03-07-2020, 04:26 PM | #96 |
Also pulled the parts truck in and removed and broke down the box. It had been disassembled at some time, and whomever reassembled it used 1/4’’ bolts instead of 5/16. What a pain in the ass.
The wood floor has some rot at the front and rear but nothing I can’t cut off for the shortbox conversion.
03-12-2020, 12:15 AM | #97 |
Remember these pics? Looks pretty good, nice original cab in good shape.
Very little rust, just needs some corner work
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 Last edited by YBNORML; 03-12-2020 at 12:26 AM. |
03-12-2020, 12:25 AM | #98 |
Well, let this be a lesson to the newbies.
Rust is like an iceberg, “if you’re lucky you can see 15% of it” This is by no means a complaint as I new that there would be more repairs needed than what was visible. For a short time I even considered just putting it together and driving it as is. But to me Patine is faded or damaged paint. NOT RUST THROUGH!!
03-12-2020, 12:30 AM | #99 |
An idea of what’s needed. Plus a few more parts.
In all honesty, probably should’ve just done the whole floor. By the way, I’m not the one doing the work, farmed it out to a buddy with far better skills in this area.
03-12-2020, 12:14 PM | #100 |
Looks familiar! It'll be a better truck in the end.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
