#76 | |
Re: better ride quality
The springs tested were similar to the line-up of C10 springs where there were different rating specs based on the options that dictated the use of a specific coil (it wasn't a test where one spring was from a 4cyl Chevette & another from a 454 Chevelle; the springs were all from one specific make/model). It was in an old magazine I had way before the NET (probably an old Hot Rod Magazine article on lowering).
#77 |
I am definitely going to order new front shocks, because my old ones are definitely shot. I guess this weekend I will remove the rear shocks and see how stiff it is and maybe drive it around and see how it rides with no shocks. What do you all think.
#78 | |
The reason is because once the shock is removed, there's nothing to control the 'energy' created when the spring is compressed & extended during travel. It may allow you to feel "hey, it rides better" or it might be so bouncy that's all you notice. It's free to try though so not much to lose.
#79 | |
#80 |
You could always try the worn-out fronts on the rear if they'll fit & are similar in dimensions (on these trucks they usually are). That would help dampen the energy w/o the extreme pressure.
#81 |
They are much different in length.
#82 |
Is there any way to tell if it is my shocks or my springs in the rear causing harsh ride?
#83 |
The new belltech shocks that I ordered will only have 1.5 inches of up travel. Do you all think that is enough or should I relocate the upper shock mounts? It will have around 3 inches of down travel if I don’t relocate the mounts.
#84 |
#85 |
I just realize that the new shocks for the front will give me around 3 inches of down travel and 1.5 inches of up travel that I would need to lower my upper bracket in order to even them out. I wonder if I do need to relocate it should I try and move it away from the frame a little at the same time in order to put it in a more horizontal position.
#86 | |
![]() Join Date: Dec 1999
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 09-25-2020 at 12:28 AM. |
#87 | |
#88 | |
#89 | |
#90 |
The tire tread started cupping = dips or waves (mainly visible/felt on the shoulders) on the tires surface:
#91 |
#92 |
It's common when the shocks are not working correctly. A few thousand miles is all it takes. Lots of HD trucks (especially Fords) have the issue because they just don't have enough shock dampening for their loads. When you rub your hand over a cupped tire, the tread feels like short 2-3" 'waves' in the tread.
#93 | |
Suspension should be able to cycle through the full movement (no matter how short) with out interference. Scoti mentioned he had once installed shocks that were to long, have made that mistake myself. My point was cycling the suspension and getting actual measurements will get you the numbers you need. The other way is to use a configuration that has been confirmed.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#94 |
So my front shocks were definitely wasted. After I got them off I compressed them fully and they stayed that way. I got the new ones on and it seems better but didn’t solve the problem. I think that the rear suspension is still to stiff.
#95 |
Keep chipping away. Front sounds like it's improved/improving. Now on to the rear & try some new/different parts to see what it yields.
#96 |
I think I am going to try and remove the rear shocks and see if the stiffness is in the shocks or coils.
Does anyone know if I can use 1963-66 rear coils on a 62? |
#97 |
As long as it's a truck-arm set-up, they'll swap in place. GM A/G bodies & Jeep coils will swap in too
#98 |
Ok thanks. Just asking because belltech only sells them for 63-66 but not 60-62
#99 |
I can't say w/100% accuracy but the 60-72 chassis only had minimal changes so I don't see why what works for a 72 wouldn't work for a 62. Biggest differences would be frame-to-chassis parts during the chassis change from Torsion bar/X-frame to A-Arm/Coil front suspension/ladder frame 62--> 63.
#100 |
So I detached one side of both shocks so I could test the spring softness and it is definitely not the springs that are causing the problem. They had plenty of bounce. Also I could not really compress the shocks by hand. I also noticed that the part number was printed on the spring and they are not the heavy duty version. So my plan is to get some replacement shocks for the rear. The only problem that I might run into is the top shock mount making contact with the protective sleeve on the new shocks. The old shocks just had an exposed rod as seen in the previous photos. I might have to make some clearance.
For those that were asking about the space between the bottom of my bed and the differential, it looks as though there is about 4 inches of clearance. |
