#76 |
Who Changed This?
![]() Join Date: Jan 2013
Re: Hard Starting Hot
The heat riser valve would be attached to an exhaust manifold, and the exhaust pipe attaches to it. It has a counterweight on it, which you should be able to move if the valve flap isn't stuck. You can try moving it. I'd recommend doing it cold. The pipe to the air cleaner is for Carburetor Heated Air. There is a valve in the snorkel that is closed cold and opens when the engine warms up. If it failed (or is disconnected) it can cause your carburetor to be hotter than normal under regular driving conditions.
#77 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
@Steeveee - nope, don't have that at all.
Heat test, after idling up to normal temp, outside is a cool 72. At Shut Down Temps Manifold: 150 Lower Carb Bowl: 98 5m Shut Down Temps Manifold: 180 Lower Carb Bowl: 115 10m Shut Down Temps Manifold: 176 Lower Carb Bowl: 125 15m Shut Down Temps Manifold: 166 Lower Carb Bowl: 125 The carb base plate is running 135 or so 5 minutes and greater.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#78 |
Mr. Cheyenne
Ran the truck up again for 10 minutes in the garage. This time around after ~15 minutes of being shut off the bottom of Carb bowl got to the same ~125 but the top of the bowl got to 120. Carb Base plate to Manifold still ~135.
Now I did this since after my 1st run I started her up at the end, zero problems. After my 2nd run where the whole bowl was at least 120 I tried again, started right up. So either I need to drive around normally and not just garage idle but I would think heat is heat (by idling or driving). I also have a ambient temperature of 72 outside but that is not the temp in my garage now after the truck running. Last bit could be that the STA-BIL 360 has started to help? I filled up and put my measured amount for my tank on Tuesday afternoon. I only driven about 10 miles before my garage test a bit ago (I didn't drive her at all yesterday). Edit Update after a short ride / keeping hood closed After about 12 minutes bowl reached 135 throughout the height of it and 150 at base plate. Started a wee bit harder this time but perhaps 1/2 crank more then when cold. Thinking the STA-BIL 360 must be helping.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 04-29-2021 at 01:34 PM. |
#79 |
Dont think stable has anything to do with it . Sta-bil is to keep the gas and alcohol from seperating or phasing out as it's called in the industry.
#80 | |
![]() FWIW, I found that 125 (ish) degrees at the bowl is the point where I start noticing hot start issue. At 135+ I can hear percolation which leads to heavy fuel saturation and bad ju-ju. There is a whole science about fuel vapor pressure and additives. It would be great if someone would contact STA-BIL and get their feedback about their products and vapor pressure.
1971 SWB step side: Original NM Forestry and then NM Fire truck Last edited by Carl Spangler; 04-29-2021 at 02:37 PM. |
#81 |
Mr. Cheyenne
It is also pretty cool outside, that could be helping my starting up or I am not doing enough real hard driving before shutting down. After I reached 135, the hard starting did come into play after I left it set with that temp for a bit over 30 minutes.
Though if temp has anything to do with this, then it seems I am clearly in the range of "high temp" after shutting down, even with cool low 70 temps outside. It seems to me the riser that is coming in should help if it keeps my carb bowl below 120. Though between the divorced choke and that breather line I am going to have some fun.
#82 |
Ok first photo is a heat riser. This is a 1964-78 Chevy heat riser. The second photo is a 72 Chevy air cleaner assembly on the engine. The vlave in the air inlet is the vaccum activated heat diaphram. If the vaccum diaphram is bad the valve in the snorkel will not open. It is normally closed. That diaphram is replacable.
#83 |
Mr. Cheyenne
I haven't any of that.
#84 |
#85 |
![]() Join Date: Mar 2015
Could this also be related to percolating / vapor lock / fuel boiling?
These issues are a lot more prevalent at the higher altitudes. I see you are in TX at 425 feet. Lowers the possibility but doesn't remove it. You had it idling for a long time without issues. One would think it would cause more heat than the sun. Distributor in good shape? Do you have another you can try? Just worked on one where the lower bushing had failed. |
#86 |
Mr. Cheyenne
No, not the Distributor. It's new along with the wires and coil. It did this before changing out the Distributor. So I am 95% this is not the problem.
I am thinking it is perlcolating / vapor lock / fuel boiling. Once I get my riser on, I should be able to tell a difference (or not). I'll be taking reading with my laser thingy - so I know what to look for now. Not sure why I didn't think of measuring temps on the carb bowl before.
#87 |
Mr. Cheyenne
I got my riser in today. Though I just realize a 3rd problem, I doubt my hard line will make it to the carb.... but I'll see how far I can get tomorrow morning - if it is not raining still.
#88 |
Can you post a pic of the thermal insulator you just got? Most are 3/8-1/2” thick which shouldn’t be an issue for the fuel line.
1971 SWB step side: Original NM Forestry and then NM Fire truck |
#89 |
Mr. Cheyenne
Mr. Gasket Carburetor Spacers - Carburetor Spacer, Phenolic, 1 in. Thick, 4-Hole, Spread Bore.
Photo upload is getting hung at "please wait".... ![]()
#90 | |
![]() Wow, that's a really thick spacer! Should lower the carb temp a LOT.
#91 |
![]() Join Date: Aug 2019
According to the show Engine Masters that 4 hole spacer will hurt your HP a little. It is better to have an open spacer with no individual holes.
#92 |
Mr. Cheyenne
Well, I didn't realize that perhaps I should be getting a smaller one - I just read that people have had great luck with this one. I suppose I could also get a 3/8 and 1/2 inch - then see how they all perform. It's not like these things cost a ton of $$.
I have a ton of bits coming in to test and adjust my fuel pressure too, which will allow me to remove my hard line and use a temp rubber line. So, I'll likely need to wait for that to get this 1 inch fellow to work.
#93 | |
Mr. Cheyenne
But being pretty much a stock engine, it's not like I am burning my tires at the stop light ;-)
#94 |
That was just for your information. Not a judgement on my part about which spacer is best for you.
#95 |
I'm in the Dallas-Fort Worth area. With my previous motor, 1974 350 stock block and heads, I had an aluminum Edelbrock intake manifold and carburaretor. I had hard starts too after driving and shutting off motor, say like running into a store or gassing up. I had to crank it, crank it, and crank it to start the motor. I installed a 1/2 inch plastic spacer and no more hard starts after driving.
With my current motor, 1968 327 with stock intake and quadrajet carburetor, I don't have any issues with hard starting hot issues. My stock intake manifold does have the oil splash pan thingy under the intake manifold though. Last edited by lil hoodlum; 05-01-2021 at 01:23 AM. Reason: I cain't spel corectly |
#96 |
Mr. Cheyenne
my intake has a very similar shield under it too - though where the carb sits, the pattern is different. Seems that one is where you need some kind of a heat shield between the intake and carb? They call yours a hot slot or something like that?
#97 | |
Mr. Cheyenne
#98 |
Mr. Cheyenne
Well, now I see why I needed open hole and not the 4 hole one. Luckily I can get one today (if they get off their butts to get it in to the store) that is the Mr. Gasket open style.
I did install this 4 hole one and give it a test. Running temp it does keep the bowl about ~10 deg lower. But after I parked her and let her set for ~45 minutes I am not really seeing any lower temps when I shoot my laser on the bowl. That was a little depressing to say the least. The hard fuel line and passenger vent hose just fits! Though my new Electric choke will have to be replaced with the stock divorced choke. There doesn't seem to be a way to replace the linkage on the Electric choke - it's like made into the unit (but I still need to try and pull it apart. Perhaps I can come up with a riser to it at some point...
#99 |
Was your 45 minute heat soak with the hood shut? That big V8 has a LOT of thermal energy and with a closed hood it has nowhere to go............. except into the carb.
![]() FWIW, when I park my hot truck (with carb insulator) outside, there's always enough breeze to keep the carb on my L6 from perc'ing the fuel in the bowl. When I park my truck in the garage I always open the hood and sometimes even put a small fan blowing at the carb. The worst is 'winter blend' fuel that has a relatively high vapor pressure.
#100 |
Mr. Cheyenne
yep, hood closed and in the garage - figured that would be worst case. Though it was a nice ~70 degs outside and misting, so not even close to Texas summer hot.
I suppose it should help more when the engine is actually running and on the move... Now if O'Riley's would get that open whole spacer in I can get it installed and tested. Heck, I even found that I can open up this Electric Choke and change out the linkage rod. I'll design the linkage with a bit of coat hanger, then find something a bit thicker in diameter. Where, not sure but I'll be on the lookout for something stiffer and will take push nuts.
