09-08-2023, 09:35 AM | #76 |
Re: 1966 custom cab short
Went with a 2.250" flowmaster you build it dual exhaust kit and dynomax turbo mufflers. The exhaust shops want around 2 grand for dual exhaust now.
Had to swap tailhousings from a s10 t5 tranny to my camaro t5. Then to retain my the top portion of my factory 2 barrel air cleaner i found a older 4 barrel base and cut it out to fit a newer style quadrajet riser and I was back in buisness |
09-08-2023, 09:56 AM | #77 |
Really happy with the 327 and camaro T5 . The camaro ratios are night and day better and the little mouse engine rips and revs so quick . I’m revving 2100 rpm at 75 mph and no lugging, 3:73 rear ratio and 28" tires
09-09-2023, 09:51 PM | #78 |
Nice work! The fresh 327 looks really good in there. Did you use a rattle can to paint it?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-11-2023, 07:52 PM | #79 |
09-11-2023, 10:31 PM | #80 |
That makes sense, thanks
09-11-2023, 10:36 PM | #81 |
09-11-2023, 11:04 PM | #82 |
This just gave me an idea to start a modern paint code thread for the 60-66 trucks. If you don't mind sharing it there, and here, please do.
09-13-2023, 10:11 PM | #83 |
