02-04-2022, 01:07 AM | #76 |
Blue 67
Re: My 53 GMC 3/4 ton project
I used the same steering linkage which I got with the electric box. I have a little interference with the access to the firewall which I believe will be okay when I finalize the install under the dash. If it doesn't, I have to enlarge the hole:
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
02-04-2022, 01:09 AM | #77 |
Nice, now, what is going on with that brake pedal, haha.
02-04-2022, 01:32 AM | #78 |
Blue 67
It got drunk! LOL
02-04-2022, 08:48 AM | #79 |
Awesome detailed description and pics of that electric steering conversion (as well as everything else you have done). I am having a blast watching you problem solve your way through this build!
02-04-2022, 09:26 AM | #80 |
Fantastic! Well done.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
02-04-2022, 11:41 AM | #81 |
Blue 67
Thank you for the comments.
It is fun to mess around with old and new parts and it is satisfying when it comes together. I get a kick out of recycling parts from junkyard!
02-11-2022, 10:43 AM | #82 |
Just finished reading through you build. I like the steering solution you are using. You are making great progress. I’ll be following!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
02-12-2022, 12:13 AM | #83 |
Blue 67
Thanks.
02-12-2022, 12:18 AM | #84 |
Blue 67
So, I took the eclectic steering off to do some final adjustment to the steering shaft adjustment and also, I wanted to finalize the mounting hardware under the dash. I was not very satisfied with 5/16 threaded rod, so I ended up with a 5/16 rod which fits very snuggly into the steering box mounting hole and I just threaded the two ends of it. Finally, I painted the steering and mounting bracket:
02-12-2022, 12:29 AM | #85 |
Blue 67
Moving on to fuel tank. This is a universal fuel tank from Tanksinc. It has the option of the either side or top fill. I am going with the side fill knowing (based on what I have read, please correct me if I am wrong) that I may have to raise the bed floor a little. The rear crossmember was in the way and I didn't know other tanks options such as Mustangs or Camaros would fit given the fact my truck frame is a 3/4 ton. I moved the stock cross member to the rear and then I made a new one for the front of the tank:
02-12-2022, 12:44 AM | #86 |
Blue 67
So, it ended up being a beautiful day in NW and I couldn't stay in any longer. I took one of my favorites out for a drive
I am more of the 4 door guy!
02-14-2022, 09:26 AM | #87 |
more doors is like more HP right?
will the steering assist be adjustable with that setup? |
02-15-2022, 11:14 AM | #88 | |
Blue 67
Yes, the steering has a manually adjustable knob which I have to mount somewhere.
02-15-2022, 11:25 AM | #89 |
Blue 67
While waiting for some small parts to arrive, I am jumped around and worked on the seat brackets. The seats are from a 2001 Tahoe. They are thicker (bulkier) than I would like but they are very comfortable for me (I have similar ones in my 2005 truck) and also fully powered including heat! Besides, paying only $50 for them, made them more attractive! Of course I have to either get a set of cover for them or just rebuild them. I also don't know if I should connect the under the cab plates to the frame or not for added security. I would be concern about vibration transfer to the cab?!
02-15-2022, 12:02 PM | #90 | |
Thanks! |
02-15-2022, 01:20 PM | #91 | |
Blue 67
02-15-2022, 02:05 PM | #92 |
Thanks! It makes perfect sense to me now. It will be interesting to see what you think of it once you have some time on the road. Keep up the great work (and the amazing pics and explanations).
02-15-2022, 11:00 PM | #93 |
Blue 67
Moving along.
I started working on brake lines and fuel system but first I needed a bracket for the proportioning valve. I titled the valve a little to avoid inner fender interference:
02-15-2022, 11:08 PM | #94 |
Blue 67
Now, when I put the inner fender on to mockup things, I came across these two questions which I would appreciate help with the answers (of course if I had an assembly manual ...):
Does the inner fender lip line up with the body inner cowl panel (the arrows in the first picture? And also, I don't remember when I did the disassembly, if the inner fender was attached to the firewall or if there was another panel (the second and 3rd pictures)?
02-15-2022, 11:32 PM | #95 |
I think if you rummage through your parts you'll find a part that fits between the inner fender and the firewall, light gauge metal. I think 3 bolt holes into firewall and 2 or 3 bolt holes( or maybe captured nuts) to fasten to inner fender. Sort of a square Z in shape about 10 inches long maybe...
When you find that peice you'll see how everything lines up |
02-15-2022, 11:42 PM | #96 | |
Blue 67
02-17-2022, 09:40 AM | #98 |
good info on how the electric steering works and the work around for making it work without a stock vehicle's modules. just curious, is there a fine tuner to get the steering wheel centered or is that an alignment issue afterwards?
02-17-2022, 10:52 AM | #99 |
Blue 67
Thank you NorCalGal. Very helpful.
There is some process which ofcourse I don't remember now (I don't this is just me getting old or something else)! I have the information buried somewhere! When I get to the wiring and start up I will post an update then.
03-02-2022, 01:47 AM | #100 |
Blue 67
So, I have been waiting for some small parts to arrive. Meanwhile, I got my new wheels and tires put together:
