01-01-2024, 02:28 PM | #76 |
Re: 1970 C10 ChassisFab Build Thread
He's on Instagram as 72_Plaid_Sub
01-05-2024, 02:35 PM | #77 |
Got the flip up license plate installed! The hitch is totally hidden now and doesn't hang below the bumper.
This is a cheap universal hitch I bought off Amazon for $150 that I wanted to make work since the only other C10 hidden hitch available is like $400. It took a lot of work to mod the bumper brackets and drill some holes through thick steel, but I'm excited that it all worked out. Just needs some paint touch ups now.
My 1970 C10 ChassisFab LWB to SWB Build Thread |
01-08-2024, 04:52 PM | #78 |
Parking brake installed! This is just a cheap 330 lb-ft linear actuator that will be wired to a maintained parking brake button/switch and double pole relay.
My 1970 C10 ChassisFab LWB to SWB Build Thread Last edited by nicklear36; 01-09-2024 at 12:33 PM. |
01-08-2024, 06:09 PM | #79 |
Farm out!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
01-08-2024, 07:53 PM | #80 |
that's nifty
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-11-2024, 11:40 AM | #81 |
chevy truck fan
nick, very cool parking brake idea... would you be willing to share a little more detail(s) on what used & install methods? IE: specific cable routing and components - pics too . I would like to try this on my '86 build... if not offended... !!
01-11-2024, 04:38 PM | #82 | |
Relay: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Cable Connector: note: only need the cable connector from this kit. I've search everywhere for the single part but I could not find one! https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Actuator: https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 Button: https://billetautomotivebuttons.com/...mergency-brake LMC Truck Park Brake Cables and Brackets: -34-1251 (x2) -34-3121 (x2) -34-3800 (x2) -34-3838 (x2) -34-3928 (x2) (cut down because it will be too long) https://www.lmctruck.com/1967-72-che...g-brake-cables
01-16-2024, 02:10 PM | #83 |
chevy truck fan
nick, thank you! appreciate the links & knowledge. I am hoping that it can "universal install" onto my '86 C10 I am assuming that the parts are descent weather acceptable?
01-17-2024, 03:35 PM | #84 |
Amazon states they are IP54 rated, which should be fine on the undercarriage of a vehicle. If you drive your truck in the rain though, a splash shield of some sort would help give some peace of mind.
01-28-2024, 08:21 AM | #85 |
Great progress! That hidden trailer hitch is sweet. We will have to see some pics of it in use once you start haulin' with it! I like the random shop buddy pics. And that actuated parking brake is trick! That is an awesome idea. I could have used something like that on mine. With the exhaust tucked up in the frame I had a hard time routing the brake cables. They still rub and bind on the exhaust a bit and cause the pedal to have trouble returning.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
01-29-2024, 02:47 AM | #86 |
Thanks all for the words of encouragement! Pops helped me move the frame to his place today to give me some more space at my house. On to phase two!
02-12-2024, 02:00 AM | #87 |
Getting there
02-12-2024, 12:12 PM | #88 |
chevy truck fan
nick, loving the update. was wondering what you used for the radiator pipe and did you make yourself or farmed it out?
thanks! |
02-12-2024, 01:16 PM | #89 | |
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
02-12-2024, 08:45 PM | #90 |
That's a beautiful rolling chassis! That orange just pops. I'm along for the ride.
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" |
02-16-2024, 10:22 PM | #91 |
02-17-2024, 11:09 AM | #92 |
Nick, nice work on this, but I have a question about the oil fill and pcv provisions. I'm assuming you had to get an intake that had the oil filler tube on it, was it new or used? Also , what about pcv?
Thanks, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-17-2024, 12:28 PM | #93 | |
https://paceperformance.com/i-514637...e-drilled.html
02-17-2024, 02:01 PM | #94 | |
02-26-2024, 08:55 AM | #95 |
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
03-13-2024, 02:20 PM | #96 |
Some progress pics.
Shortbed chop is underway, dents have been pulled, and all cab rust has been cut out. Lots of dirty work and time with the death wheel! I found a pretty knarly sideswipe on the driver side bed panel that took lots of pulling. Thanks to metaloxfab for the video on Youtube showing how to properly cut the bedsides. I also wanted to add the true shortbed wheel well tip in front of the rear wheels so I spent the extra money to get those patch pieces from LMC.
03-20-2024, 12:35 AM | #97 |
Active Member
I haven't had this pop up on my YT algorithm yet, good video. Thx!
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
03-20-2024, 06:58 AM | #98 |
Nice touch on the wheel well corner. Most people miss that and it always stands out to me. I've always wondered why GM made that change between long and short beds.
04-23-2024, 01:27 PM | #99 |
Sectioned the rear wheel wells to be able to raise the bed floor 10.5 inches. This was not easy by any means but I'm going for a stock look on the entire truck so this was a must.
04-23-2024, 02:06 PM | #100 |
Nice work. It looks good!
