Closed Thread
Old 03-17-2011, 03:59 PM   #976
TyKby2
TyKby2's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Rev wheels are just licensed by AR not made by them, big difference
Kevin
1974 Chevy C-10 (The Mistress)
1971 VW Bus
1973 VW Super Beetle
1996 Jeep Cherokee
TyKby2 is offline
Old 03-17-2011, 11:29 PM   #977
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by spazzyfry123 View Post
So it looks like I'm just going to need to buy them and figure it out just how much needs to be milled on the front kind of deal.
My bed is tubbed out (about double the size of the factory wells) so rubbing on the inside shouldn't be an issue... But I'm buying them to look good. It'd be silly to have them sucked in.
I just want these wheels because of the "lip" around each spoke. BUT... With the money spent on spacers, extended studs, and having the extended studs put in for the rear... Then the milling of front rotors every time brakes are needed... I'll end up spending more than if I would have just bought some TTII's. Not to mention I do not want to be running spacers with the power I'm planning on running.
Too bad for the manufacturer. No telling how much money they are losing with not getting this done right.
So... Coys or American Racing...?
Spazzy,
Follow this LINK there is a drawing with the dimensions the rotors will need to be turned down to on the end. I also had to cut off the dust caps and end of the spindles for the rims to fit. Then I had to use silicone to hold the center caps on. They were an early version of these. I think the newer ones the center caps will work out better. good luck
mcbassin is offline
Old 03-18-2011, 08:05 AM   #978
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
I just put a set on my 71 and couldn't be happier! The front hub had to have just the lip shaved down took the guy about 10 minutes to do this. The backs fit fine with no spacer. I'm very pleased with how they look. Oh yea he did tap in the bearing cap a little too!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 03-18-2011, 08:46 AM   #979
brossow
Amateur Rust Fighter
brossow's Avatar
With all due respect, I think you need to define "fine" and post your pics from the other thread so no one else is misled by this. With your 275-series tires and no spacers, you've got what looks like 1/4-1/2" of clearance, which is going to rub as the body and rear end move, especially with the trailing arm rear. Your track width is also narrower at the rear than at the front. Yes, they bolted on, but please tell the whole story before others rush out and think they can do the same as you did without any problems. For people who run a wider tire (like my 295s) and/or actually care if their tires rub, these won't "fit fine" by most standards. However, a pair of spacers can be had for under $40 that will fix this.
That said, they look great on your truck, as I've said previously. I'm not posting this as a personal attack but simply trying to clarify things. I've spent WAY too much time working with others and top management at the company itself to get this fixed and provide accurate info to now just sit back when someone comes along and says they "fit fine."
I'll save others the trouble of finding your no-spacer pics. Here they are:
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 03-18-2011, 08:51 AM   #980
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
Now this guy has done his homework
I agree BROSSOW
JOHNORO is offline
Old 03-18-2011, 01:18 PM   #981
spazzyfry123
spazzyfry123's Avatar
Originally Posted by mcbassin View Post
Spazzy,
Thanks, Mike!
It looks like the newest ones don't require the dust cap to be cut up. Is it just the rotor hat surface that needs to be milled .38"? Or are there multiple angles that are needed? I'm planning on running the 20" wheels staggered and I have drop spindles. I'm not new to "making" things work with spindles and wheels, but it'd be nice if I didn't have to worry about the spindles. I had to grind down the loving crap out of my Lightning's spindles to fit the factory wheels... Sheesh.
-Tyler
Edited by Forum Staff!
spazzyfry123 is offline
Old 03-18-2011, 01:24 PM   #982
brossow
brossow's Avatar
Thanks, Mike!
It looks like the newest ones don't require the dust cap to be cut up. Is it just the rotor hat that needs to be milled .38"?
Can't address the milling question (haven't done mine yet) but the center cap on the new (-3AA revision) wheels is held in place by an O-ring rather than the long clips that needed to be cut down in previous revisions. The clips on the old-style center caps would bottom out on the rotor hat before seating completely on the rim; the new caps are so short that they don't do that.
Brent
brossow is offline
Old 03-18-2011, 01:52 PM   #983
mcbassin
Still Learning
mcbassin's Avatar
Thanks, Mike!
-Tyler
I don't think you would have to do multiple angles or anything, I did that to try to retain as much side wall as possible on the rotor. I understand the making things work deal too.
mcbassin is offline
Old 03-18-2011, 01:54 PM   #984
mcbassin
Still Learning
mcbassin's Avatar
Do you know if the new centercaps will fit on the older version rims? I would like to buy if they will.
mcbassin is offline
Old 03-18-2011, 01:55 PM   #985
brossow
brossow's Avatar
Not sure (I've only had the new rims to work with) but I would guess they won't. The new ones use a rubber O-ring that seats in a groove inside the bore, which I strongly suspect isn't present on the older rims.
Brent
brossow is offline
Old 04-23-2011, 10:29 PM   #986
HarrolLS1
HarrolLS1's Avatar
never mind!
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Inside every older person is a younger person wondering what happened
HarrolLS1 is offline
Old 04-23-2011, 10:38 PM   #987
brossow
brossow's Avatar
Originally Posted by HarrolLS1 View Post
Hope this is not a repost but I saw this posting on their blog
http://aewc.blogspot.com/2010/03/bos...ease-caps.html
[snip]
still no update on the backspacing options!
Only a year late.
EDIT: LOL! Looks like you figured that out while I was posting my reply.
Brent
brossow is offline
Old 04-23-2011, 11:49 PM   #988
mcbassin
Still Learning
mcbassin's Avatar
Well I guess we'll see. I would sure like to see them tweak the back spacing issue too. It sure would be cool to just bolt on a perfect fit year late and a dollar short
mcbassin is offline
Old 04-28-2011, 05:47 PM   #989
djw32
Update!
American Wheel Corp will be fixing the lip issue very soon. I will keep you posted on the info as I get it.
David
djw32 is offline
Old 04-28-2011, 06:08 PM   #990
brossow
brossow's Avatar
Originally Posted by djw32 View Post
Update!
David
If I had a dollar for every day that passes between when AEW says something is coming soon and when it actually arrives, I'd have enough to buy a set of Coys instead.
Brent
brossow is offline
Old 04-29-2011, 01:28 AM   #991
djw32
Good point. Hopefully I will have some positive info soon.
djw32 is offline
Old 04-29-2011, 08:55 AM   #992
mcbassin
Still Learning
mcbassin's Avatar
Has anyone actually purchased a set of these so called "direct bolt on" Boss 338s yet?
mcbassin is offline
Old 04-29-2011, 09:11 AM   #993
brossow
brossow's Avatar
Yeah -- guys with the '88-up trucks they were designed for.
Brent
brossow is offline
Old 04-29-2011, 09:38 AM   #994
k5hart
k5hart's Avatar
I was about to say this! Mine would have directly bolted on to my 1991 with the right tire sizes.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline
Old 04-29-2011, 11:20 AM   #995
mcbassin
Still Learning
mcbassin's Avatar
The last blog I saw on there site said they were making them and had addressed the grease cap. HERE
mcbassin is offline
Old 04-29-2011, 11:21 AM   #996
brossow
brossow's Avatar
Check the date? That was March 2010 with the -3AA wheels that still don't fit right.
Brent
brossow is offline
Old 04-29-2011, 11:29 AM   #997
hotrodhomi
hotrodhomi's Avatar
They're worth the extra effort to get them to fit if you ask me. I have the 3AA series
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline
Old 04-29-2011, 11:35 AM   #998
mcbassin
Still Learning
mcbassin's Avatar
What did you have to do to get yours to fit? Spacers in the rear and cut the rotor up front?
mcbassin is offline
Old 04-29-2011, 11:48 AM   #999
hotrodhomi
hotrodhomi's Avatar
yes
'66 impala ht
Old 07-05-2011, 05:33 PM   #1000
bguild
bguild's Avatar
So tell me who has the best deal on these? I am looking for 20x8.5 fronts with 20x10 rears? If there is a place that is cheaper let me know? I am in KC as well.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline
Closed Thread
