04-05-2017, 11:21 PM | #976 |
Re: 72 K30 Build
you are doing an awesome job on your truck....
04-08-2017, 10:04 AM | #977 |
Re: 72 K30 Build
Thank’s you guys!
Last Thursday it was time to punch the hole for the throttle lock. Gotta tell ya, I really didn’t want to screw this up and with my skills at punching holes lately, oh crap! Aftermarket bezel molds appear to give the correct location but it is not, for comparison factory bezels are much closer.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
04-08-2017, 10:08 AM | #978 |
Re: 72 K30 Build
All is good, took a few minutes and reset the odometer as well.
04-08-2017, 01:50 PM | #979 |
Re: 72 K30 Build
Looks cool! I should have reset the odometer on Jr.!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
04-10-2017, 09:40 AM | #980 |
Re: 72 K30 Build
I wasn't going to reset this one either but since I got back into it, it will be really nice to start off at zero.
Locating colored wire in the color and gauge needed has been kind of a pain to find locally. When we did find some it’s way over priced so threw in the towel and ordered a nice selection of closeout wire from RockAuto! Shop stock!
04-11-2017, 09:16 AM | #981 |
Re: 72 K30 Build
Decided to mount the Gear Vendors Digi-Drive (GV’s brains) under the passenger’s seat. Going to pass the shift solenoid and the speedo signal cables through the floor. Only problem with this location is that the dash switch harness is not long enough, called GV and they don’t offer an extension or longer harness. Their recommendation was to extend the harness on the dash switch side and that may end up being how we do it. But first thought I’d try to be a little more modular and extend it from the RJ12 end first, got coupler’s and 2, 6p6c straight wired 4’ telephone cables on order.
04-11-2017, 06:08 PM | #982 |
6>8 Plugless........
Re: 72 K30 Build
That's looking very nice. Who's bezel or wood grain applique did you go with? I need to get a new one for my 72.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-12-2017, 09:45 AM | #983 |
Re: 72 K30 Build
You have a good eye my friend! We’ve been saving this wood grain set that we acquired from Gary Terry CSM for our C10 project. The K30 has been turning out pretty nice so we decided to use them on this truck rather than let the stuff sit in a box. I don’t know that we could have replaced the bezel from the same source if I’d muffed it up.
Lots of interesting stuff here on this topic. https://www.google.com/search?domain...D%3A1%3B&hl=en Here’s a short thread I posted in back in 2012 talking about acquiring this stuff… http://67-72chevytrucks.com/vboard/s...d.php?t=537546 I believe ours is a Counterpart bezel using the marine teak wood, checkout this post from forum member mikentosh on the color differences of this product. http://67-72chevytrucks.com/vboard/s...&postcount=270
04-17-2017, 10:43 AM | #984 |
Re: 72 K30 Build
It looks like the GV dash switch extension is going to work, toned each line with and without the extension and no difference on the plug end. In the same Amazon order, we picked up these shrink wrapped connectors that are a good deal at just .11 cents a connector. Some auto parts places are charging $1 a piece for this style and so far the few we've used worked great.
04-18-2017, 08:45 PM | #985 |
Re: 72 K30 Build
I have a GV on my 93 with 4:10 rear and 4L80. 1900 rpm at 70 mph. i found support with GV to be outstanding although i bought my unit from craigs.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
04-19-2017, 10:07 AM | #986 |
Re: 72 K30 Build
That’s really good to hear, we’ve only called twice so far and they have been very helpful. Double OD, you are the man deejaaa1!
Pulled both battery trays and mounted the relay sockets and circuit breakers for our electric fans, headlights, trailer brake, etc. also a large fuse holder for the high amp alternator. The idea is to try and hide this stuff behind the battery’s. Ha, you are probably wondering, what’s that cable he’s using (Dorothy’s Ruby Slippers?)? We acquired some custom battery cables from CE Auto Electric a while back. I’ve already got some high-quality ofc, tinned, high heat cable in several gauges that’s very similar left over from an earlier project that we’ll be using also. https://ceautoelectricsupply.com/custom-cables/
04-20-2017, 11:52 AM | #987 |
Re: 72 K30 Build
This cheapo eBay crimper does a real nice job!
04-20-2017, 01:47 PM | #988 |
Re: 72 K30 Build
That crimp definitely looks like it should hold! Looks much better than using a crimping die in the bench vise. In fact, all of the wiring tasks you've shown are looking really clean.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
04-21-2017, 10:44 PM | #989 |
Re: 72 K30 Build
That's nice of you too say Rick!
In progress, slow but sure...
04-22-2017, 11:48 AM | #990 |
Re: 72 K30 Build
Looks like some headlight relays going in, did that to my truck, made a good difference pulling direct battery current. Nice crimper!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-26-2017, 06:40 PM | #991 |
Re: 72 K30 Build
nice crimp, when I make my own battery cables I like to solder the end as well as the crimp, the wire can corrode inside over time and not make a good connection....just my opinion... I just ordered one of those crimpers.thanks for showing it!....better than the one i have that you have to hit with a hammer....
04-27-2017, 06:18 PM | #992 |
Re: 72 K30 Build
Yes, thanks for sharing those crimpers! I just ordered one too. Nice work on your wiring. It looks great!
04-29-2017, 12:25 AM | #993 |
Re: 72 K30 Build
Wade , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
05-01-2017, 11:23 AM | #994 |
Re: 72 K30 Build
Thanks you guys!
Yep, thinking I’m really going to like the headlight upgrade most definitely safer & brighter, Blue will most likely get the same treatment before too long. So what's happening with the Rat Mike? Ha, that’s saying a lot coming from the ruler of the wiring wasteland! Thanks Wade! Jim & Ryan, I don’t know how long the crimper will last but it worked great on that fancy 4 gauge of ours! Here’s a 10-minute battery cable crimping video using this same tool by a guy named Rick Perry. Check out how tight the crimp is @ 4:40 he shows a crimped end cut open. https://www.youtube.com/watch?v=xyXMJIgpeyE Haven’t been on the forum much the last couple weeks, unfortunately we had a family emergency. My mother in law was hospitalized rather suddenly which then lead to hospice in our home until she passed away. Her funeral is in a couple days and things should get back to normal for my wife and I. I did get to start the K30 off of the key and tested a few things. Other than the neutral safety switch needing a little adjustment everything that’s hooked up has tested out perfecto! Gave the fenders some bling, used some strip caulk on all the emblem studs.
05-01-2017, 11:47 AM | #995 |
Re: 72 K30 Build
Family's gotta come first. Sorry for your loss!
05-01-2017, 01:04 PM | #996 |
Re: 72 K30 Build
Sorry for your loss Brett!
Bling is always nice!
05-01-2017, 09:22 PM | #997 |
Re: 72 K30 Build
I'm betting it works great for the lighter stuff like that 4ga. I'm hoping I can use it on some of the 00 I use on my trucks. If not, I'll use it for alt cables and such. Haha
05-02-2017, 07:11 AM | #998 |
Re: 72 K30 Build
I'm also sorry for your loss Brett. That's great news though that the circuits you've tested have been working!
05-02-2017, 10:49 AM | #999 |
Re: 72 K30 Build
Thanks guys, appreciate it.
05-08-2017, 10:08 AM | #1000 |
Re: 72 K30 Build
Here’s how things looked last Saturday. Dash wiring/duct work is getting there and should be done soon, I hope. Going to add a rocker switch in the speaker enclosure for a cargo and possible tool box lights in the bed. Sending both switched and constant power back for whatever may come up?
Tags |
72chevy, dually, flatbed, k30, motorhome |
