07-01-2020, 06:17 PM | #1026 |
Re: A '54 named Busty
better go camping before our great CA leader makes it illegal again
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
07-01-2020, 06:35 PM | #1027 |
Post Whore
so true
07-06-2020, 01:55 PM | #1028 |
I hope you enjoyed your camping trip.
07-06-2020, 08:09 PM | #1029 |
Post Whore
thanks, yes we did, it was rad and much needed, I am now trying to get motivated to walk into the garage and do the fuel plumbing...
07-07-2020, 12:46 AM | #1030 |
Post Whore
mandatory stare and compare
stock sending unit vs the sump pump |
07-07-2020, 12:48 AM | #1031 |
Post Whore
and here's a little close up, I got this sending unit with the screw on couplers for a reason so I was not going to cut them off and use the compression AN adapters, it took me a while but I got the right AN adapter that simply screw in, I like this clean setup
07-07-2020, 12:50 AM | #1032 |
Post Whore
and she's in, these sending units come in two different clock positions but this one is good enough for me as long as it fits I can route the steel braided lines accordingly
07-07-2020, 12:54 AM | #1033 |
Post Whore
I swear would it kill 'em to label the return line on this Corvette fuel filter regulator?!?!?! had to find a labeled diagram to run the lines the proper way as it sure aint intuitive at all and the stubs are not long enuff to tell a 3/8ths from a 5/16ths
I know there's an arrow but I took that as directional flow from tank to engine, all I want is a little "R" next to the proper nipple ha ha |
07-07-2020, 07:39 AM | #1034 | |
07-07-2020, 10:35 AM | #1035 | |
Post Whore
gonna spend most of today cutting up my thumbs whilst attempting to make more steel braided fuel lines, I found some great Fragola brand -6 AN fittings I've ran them in the past so it's just a matter of cutting the lines and putting them on end is in sight! Last edited by Gregski; 07-08-2020 at 11:34 AM. |
07-07-2020, 08:40 PM | #1036 |
Post Whore
Spaghetti Western
07-07-2020, 08:41 PM | #1037 |
Post Whore
Injector wires in place (approximately) we fully expect to make adjustments as we go
07-07-2020, 08:42 PM | #1038 |
Post Whore
added the coil wires...
07-07-2020, 08:44 PM | #1039 |
Post Whore
added, alternator wires, TPS, MAF, Temp, you get the idea, we just keep building and building...
07-07-2020, 08:45 PM | #1040 |
Post Whore
and pretty soon all that was left was the Transmission branch of wires to run...
07-07-2020, 10:01 PM | #1041 |
Looking good
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
07-08-2020, 08:23 AM | #1042 |
Man that looks like fun! Almost road worthy.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-08-2020, 10:15 AM | #1043 |
What is the Fun Meter on all this wiring?
07-08-2020, 10:42 AM | #1044 |
Wiring is the worst, such a pain. I like to use small zip ties to hold it all together as I go. They are easy to cut off, no adhesive to deal with and you can pull wires out of them if needed. Probably go through a few hundred when building a car.
07-08-2020, 11:02 AM | #1045 |
Post Whore
ha ha, I love a brother who follows along and reads the thread, well, I think my mamma must have dropped the PCM on my head too many times, cause I actually enjoy wiring so we give it a high score of ... [wait for it] ...
Wiring Fun Level (WFL) = 8.0 Cons - old sticky tape gets your hands dirty, nice and black unless you wear gloves to undo it all |
07-08-2020, 11:06 AM | #1046 |
Post Whore
I hear you brother and thank you for the advice I will give the little ones a go, I know that the old tape I used the lighter in color with writing on it, (which you can no longer buy, darn it) was super easy to work with and do and undo and reuse, the darker one is much more difficult to use
07-08-2020, 11:10 AM | #1047 |
Yep, hook up that multimeter and you have a winner...or a looser and you re-do it.
I've not done the thinning of the PCM like you did, and I hooked it up with with all the connectors attached to the wires, but it does looks interesting. Where/how did you learn to thin the harness?
07-08-2020, 11:11 AM | #1048 |
Post Whore
so all these wires will get shortened and new pins crimped on,
FYI the PCM uses two different size pins the pin side is the same size but the part that grabs the wire is two different sizes depending on the gaugeness or thickness of the wire Mouser part numbers: 829-15359001 $15 for 50 and 829-15359002 $20 for 50 I decided to mount the PCM to the firewall on the passenger side for the following reasons
07-08-2020, 11:12 AM | #1049 |
But where does the AC go?
07-08-2020, 11:17 AM | #1050 |
Post Whore
