Old 10-28-2012, 09:46 PM   #1051
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 85 burb meets 6.0 lq4
Isn't it a little early to be selecting a Christmas tree?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-28-2012, 10:27 PM   #1052
85burb
85burb's Avatar
Lol. Ya a wee bit early. Needed that bush gone. Bees seem to like it to much.
On a side note I will be starting a 5.3 turbo build on the wife's truck. Who has turbo experience?
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-03-2013, 02:17 PM   #1053
85burb
85burb's Avatar
Well it is a sad day. Sold my intake and msd and efi. Buddy will be down for a little while. Going to factory efi. Getting a good deal for my system so I will order an compleat motor with required harness and ECM already wired for a swap. Hope the truck is only down a few weeks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 03:35 PM   #1054
watahyahknow
watahyahknow's Avatar
try the turbo forum http://www.theturboforums.com/forum.php lot of knowledge there , lot of different opinions too btw
curious about the new setup youre going to do , there allso kits available voor the ignition (msd) and carb intakemanifolds
i would like to turbo one of those motors too but use propane using that kind of a setup and an impco 425 carb
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-03-2013, 05:06 PM   #1055
68GMCCustom
huh?
Kurt -
Old 02-03-2013, 05:35 PM   #1056
85burb
85burb's Avatar
Originally Posted by 68GMCCustom View Post
huh?
I think I may have head problems.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 06:27 PM   #1057
85burb
85burb's Avatar
Pulled msd and intake and efi off. I think it took longer to take it off then to install it. Test fitted the origanal intake that came with my 6.0.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 06:55 PM   #1058
68GMCCustom
Well I think I may have a head problem too with all the coin I spend on mine but...
Is it down a cylinder?
Kurt -
Old 02-03-2013, 06:57 PM   #1059
85burb
85burb's Avatar
The head problem is my head not the burbs.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 11:13 PM   #1060
y5mgisi
Second Chance Program
y5mgisi's Avatar
You will be happy with the change i think.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 02-03-2013, 11:15 PM   #1061
85burb
85burb's Avatar
I think so. Excited to see what the power differance will be. More or less.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 11:51 PM   #1062
68GMCCustom
if you have to go efi.......GM's is better.
Kurt -
Old 02-03-2013, 11:54 PM   #1063
85burb
85burb's Avatar
That is what I am betting on.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-03-2013, 11:56 PM   #1064
85burb
85burb's Avatar
You ever get yours fixed up?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-04-2013, 06:39 PM   #1065
68GMCCustom
LOL......well....not exactly. I'm chasing a few inches of vacuum that was lost when changed to efi. Had 15-17" now have 10-12". At the current level my power brakes don't want to work...even with the vacuum storage canister. Went thru the injectors yesterday...but they seem OK. Took extra intake I have and mounted the injectors/fuel rail to it/hooked it up to the fuel pump and then lit up one injector at a time and they all shot good streams 3' in the air. Also still have the vibration I've been fighting since busting that u-joint a while back and getting a longer d-shaft made.
Working on ordering a new set of wheels/tires. Just haven't decided for sure (16/17,17/18,18/19)...just know in my head I want 28" tire up front and 29" or so in the back.
Oh....and re-upped my Goodguys membership, bought a GG's - Lone Star 2013 shirt, and plan to enter the early spring event so I can autocross it...so I do need to get the bugs out.
New trans shifts great tho!
Kurt -
Old 02-04-2013, 09:34 PM   #1066
85burb
85burb's Avatar
Interesting. I wonder what could cause the vaccum drop. On the wheels i would go 18/19 combo. I will be at that goodguys but prob only sat or sunday. we are going to swing by after a trip to colorado.
I just placed a order for my new fuel pump and fittings at summit. Got a walbro 392. Max psi of 60 and 255 lph. I cant deside if i want to just buy a intake with rails, injectors, throttle body or buy a hole motor with swap harness and ecm. I have a intake now but it has been sitting the hole time i have had my 6.0 so not sure how good the injectors are any more. It also needs a throttle body.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-04-2013, 11:02 PM   #1067
68GMCCustom
Based on my last 5yrs playing with "toys" and upgrading this, that and the other....
my main gripe has been that I didn't hold on to the old parts. Instead I sold them to fund this or that. Made me remember why I had gotten that "pack rat" instinct from my grandfather. Turn loose of it and you may find you need it (or another like it) later in life. Our next house (working to remodel now, sell, move by summer) will have a few acres with room for my shop and be our last habitat...so my kids are likely to wind up with a bunch of junk!
I'd reuse what you got, and add to it as needed. The rails and injectors can be cleaned.
Kurt -
Old 02-04-2013, 11:07 PM   #1068
85burb
85burb's Avatar
I may have them cleaned. Still need a new map, throttle body, mass air flow, intake pipes, all sensors on throttle body. I am going to contact a few places and see if i can get the top of a ls motor with all that for cheap.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-05-2013, 05:49 PM   #1069
68GMCCustom
Heck if you really wanted to make some power...you could get some big breathing genIV heads, intake, and TB....that is as long as you could keep your current harness/pcm.
*edit- in fact I have a spare genIV intake...its bare tho.
Kurt -
Old 02-05-2013, 09:17 PM   #1070
85burb
85burb's Avatar
I would like more power but i dont want to sacrifice any low end power and have to change converter and gears again. I hope i gain low end with this swap. At least low end driveability should be better i hope. After i get the wifes truck done i may start building a stouter motor. prob a stroker like 408 or 421. That should for sure help low end.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-06-2013, 03:34 PM   #1071
68GMCCustom
Yes it should. My setup has all kinds of power before 3500rpm...but enough for something that weighs nearly twice as much... I can't say.
Kurt -
Old 02-06-2013, 04:43 PM   #1072
watahyahknow
nothing beats cubic inches exept maibe a blower or turbo's , the LS type engine work realy well with turbo's
Old 02-06-2013, 11:30 PM   #1073
85burb
85burb's Avatar
Got new fuel pump and fittings in mail. Should get ECM and harness tomorrow!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-07-2013, 10:04 PM   #1074
85burb
85burb's Avatar
Well my harness and ecm came in today. But it has changed my plans. It is set up for a car intake. It will make problems on my burb as in having to change injectors or injector plugs, exteneding a few wires and such. But i think it will help a few issues for the wifes truck. As in hers will need much bigger injectors and possibly needing fuel rail mods to fit injectors in truck rails. so i will put a car type intake on wifes truck and take wifes intake and maf sensor and put it on the burb. But that brings me to how to get a harness for the burb. The wifes truck came with a factory one so i can have it reworked or just get a new one. I priced a rework and ecm flash and it was like 500 bucks and 4-6 weeks wait time. So for a few hundred more i can maybe buy a already worked one or a new one.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-08-2013, 03:11 AM   #1075
y5mgisi
y5mgisi's Avatar
Not all bad then?
