Old 07-17-2013, 01:05 PM   #1051
gdavis
gdavis's Avatar
Re: 1968
this is a whole lot easier than the way I was doing it. Thanks brian
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 07-17-2013, 03:05 PM   #1052
Xeen
Xeen's Avatar
Re: 1968
Anytime.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-17-2013, 04:07 PM   #1053
cubber
Re: 1968
Looks nice and clean.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 07-17-2013, 04:54 PM   #1054
gdavis
gdavis's Avatar
Re: 1968
I took the brake booster and MC off and got a can of hammered paint. It came out real nice. Went to three different stores to find a fitting. The one that fits in the rear of the OEM port valve. NAPA had it but it looked to buckey.11.00 auto zone did not have it. Advance auto 2.11 and it fit. Going to let the paint cure and then install the parts back on.
The brake pedal and benzel are for a 71/72 they want fit a 67/68. unless I switch to a 71/72 pads.
Check out Patches
Old 07-17-2013, 04:55 PM   #1055
gdavis
gdavis's Avatar
Re: 1968
thanks when are you going to enter that truck in a show.
Check out Patches
Old 07-17-2013, 05:09 PM   #1056
cubber
Re: 1968
Haha, I don't know. There haven't been too many around here lately that I could get to.
=MATTHEW
Old 07-17-2013, 06:35 PM   #1057
~Whitey~
~Whitey~'s Avatar
Re: 1968
Trucks looking great George... Hadn't seen it for a month! Nice work!
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 07-17-2013, 08:48 PM   #1058
gdavis
gdavis's Avatar
Re: 1968
Haven't done very much in this last month. But on the 27 maybe i will get all my body work fine tuned. Then i should be ready for paint around the 1st of Aug.
Check out Patches
Old 07-17-2013, 08:50 PM   #1059
gdavis
gdavis's Avatar
Re: 1968
Hey you guys. I am set up for the 27th of july for the fine tuning on the body work.
Check out Patches
Old 07-18-2013, 07:05 PM   #1060
gdavis
gdavis's Avatar
Re: 1968
Today I finshed my transmission lines they gave me a fit.
I installed the front clip back on the truck. Had to get my wife and the two boys (ages 7 & 9) to help me carry the front clip. But it worked.
I installed the brake booster and Master cly. Got to remove the booster again tomorrow I for the boot in the booster. But at least it want be hard to fix.
Attached the brake line to the master cly. Again the fittings gave me a hard time. Alignment issues
Installed the head light buckets. Classic Parts sent me the wrong adjustering screws. Ordered the right one's today 4.95 to ship 1.00 to buy 4 screws.
Installed the outer grill on the truck. really like the way it fits.
Not to bad of a day. Got a lot done on old patches.
Check out Patches
Old 07-18-2013, 08:16 PM   #1061
SeTx67
SeTx67's Avatar
Re: 1968
Making some progress George. Looks good
SeTx67 is offline   Reply With Quote
Old 07-18-2013, 09:37 PM   #1062
cubber
Re: 1968
You are on the downhill side, now, George!
=MATTHEW
Old 07-18-2013, 10:43 PM   #1063
gdavis
gdavis's Avatar
Re: 1968
Thanks you. I had my wife and the two boys helping me with the front clip.
Check out Patches
Old 07-18-2013, 10:44 PM   #1064
Xeen
Xeen's Avatar
Re: 1968
George those headlight buckets are an assembly you have to put the headlight in and put the beauty ring on then install it as one unit.
Old 07-18-2013, 10:44 PM   #1065
gdavis
gdavis's Avatar
Re: 1968
Last month someone turned the light out at the end of the tunnel. But now I replaced the light bulb and I can see the end again.
Check out Patches
Old 07-18-2013, 10:46 PM   #1066
gdavis
gdavis's Avatar
Re: 1968
I am doing this work under a canophy. I really can't see the fine dust untill I take a picture. Boy does it show every spot of dust.
Check out Patches
Old 07-18-2013, 10:48 PM   #1067
gdavis
gdavis's Avatar
Re: 1968
I found that out. I removed them anyway. They were in the way of getting my bolts in the grill on each side. The adj screws are to short and I ordered new ones.
Check out Patches
Old 07-19-2013, 06:31 AM   #1068
Xeen
Xeen's Avatar
Re: 1968
Yeah it all goes together in a certain order the headlights are the last thing you install.
Hmm thats odd, you didn't order the c10 headlight adjuster kit the first time?
Old 07-19-2013, 05:35 PM   #1069
gdavis
gdavis's Avatar
Re: 1968
yea i did but the book was wrong I guess. These screws are 2 1/4 inch long. and the ones they sent me first is 1 1/4 inch long.
Check out Patches
Old 07-19-2013, 05:39 PM   #1070
gdavis
gdavis's Avatar
Re: 1968
I installed the platic boot. the one that fits between the firewall and the booster.
Installed the grill support that supports the outer grill to the inter grill alone with the hood latch.
Both attached to each other.
Installed the hood latch.
Check out Patches
Old 07-20-2013, 08:27 PM   #1071
gdavis
gdavis's Avatar
Re: 1968
took it easy today. Did nothing on the old truck
Check out Patches
Old 07-21-2013, 05:18 PM   #1072
gdavis
gdavis's Avatar
Re: 1968
Today I had to take one of my boys to summer camp. He will be gone for a week. So I am just going to take the day off it is Sunday anyway.
Check out Patches
Old 07-22-2013, 10:31 PM   #1073
gdavis
gdavis's Avatar
Re: 1968
Today the rear brake hose came in. I tried to install it, but ran into another set back. The hose that Classic parts sent me was 4 inch to short. So I movied the holder that is welded to the rear end from the front of the rear end to the back side of the rear end. Now everything work good. I was going to mount the front turn signals, but I noticed a bare wire on one of the pig tails. better fix it up now than worring about it later. It is getting close to the 21st and that is body work time. I will be glad when I can shoot some color on the whole truck.
The truck is going to be solid orange. No chrome anywhere. The mirrows, wipers arms, front and rear bumpers, head light benzels, hoops are going to be orange. Even the inside of the truck is orange. The seats are old school roll and tuck black and orange. A Chevrolet bow tie in the middle on the seat with a 1968 sewed in with my name on one side and the wifey on the other.
I am expecting some more parts this week. I order a power steering pump, chrome 3'' breather, some 350 emblems. I am now looking for a quad jet carb that can be rebuilt. I have a friend that ownes a shop and that is about all he does is rebuilds carb and transmission.
Check out Patches
Old 07-22-2013, 11:59 PM   #1074
Xeen
Xeen's Avatar
Re: 1968
Today the rear brake hose came in. I tried to install it, but ran into another set back. The hose that Classic parts sent me was 4 inch to short. So I moved the holder that is welded to the rear end from the front of the rear end to the back side of the rear end. Now everything works good.
They sent you the correct hose.
On the 1972 rear axle there is a bracket for the brake hose that bolts on to the differential cover on the upper right hand quadrant which is why the hose is short.
Old 07-23-2013, 01:17 PM   #1075
gdavis
gdavis's Avatar
Re: 1968
That don't seen to be right. I am using a 1972 rear end and a 1972 cross member with the tab to mount the brake line. So you would think a 1972 hose should fix without any mod.
Check out Patches
