08-16-2014, 09:25 AM | #1051 | |
Re: What did you do to your truck today? Chapter II
Brad handshoe |
08-16-2014, 04:36 PM | #1052 |
First work I've done on the new 66 since I got it last week, changed the oil, oil filter - it was dirty! Then just popped in a new air filter to replace the one that was crushed, was going to do a differential fluid change but luckily I realized they gave me the wrong gasket before I unbolted everything. Cleaned up the engine area a bit, then just spent a few hours under the truck trying to learn more about it.
08-17-2014, 08:24 PM | #1053 |
Finished up this little gem...
1967 C10 SWB Owner - Rustbelt Restorations |
08-17-2014, 08:37 PM | #1054 |
I almost finished the disassembly of my TH350. But got to the low-reverse spring retainer and didn't succeed in getting it out without the proper tool.
08-17-2014, 10:13 PM | #1055 |
Really nice work on the column! Need to get mine done...jealous.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
08-17-2014, 10:51 PM | #1056 |
Fabricated and test fit my new gauge mount setup. Should be straight and mounted tomorrow.also got my temporary stereo deck mounted.
08-18-2014, 03:28 PM | #1057 |
Pulled the extra tanks out ...for now! They need some work as you can see. The bolts are rusted to the tanks and would not budge! A busted elbow and some grinding took care of that though, and out they came!
08-18-2014, 05:03 PM | #1058 | |
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades. Formerly known as mtndewmaniac66. |
08-18-2014, 07:16 PM | #1059 |
Had the rims powdercoated and put new rubber on.
08-18-2014, 08:26 PM | #1060 |
I took my tranny to a local trans shop to have them take the low-reverse piston out. On a promise I'd take it back to get bushings put in when my rebuild kit comes, he didn't charge me a dime.
Went home and started cleaning... 3.5 hrs later.... :-) |
08-19-2014, 01:42 AM | #1061 |
Old member
Took it out for lunch and ran into some other's as well.
08-19-2014, 12:14 PM | #1062 |
Changed/cleaned out my fuel filter last night. This is after maybe 100 miles. Good thing I put a filter between the tank and pump. Just trying to limp this thing along (rarely driven) until I get everything for my motor swap.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
08-19-2014, 12:16 PM | #1063 |
Holy S#!T That's crazy!!!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
08-19-2014, 12:50 PM | #1064 |
RAT1968 '68 Cab/'71 Parts
I stole your pic. At least, a part" of it!!!!
Very tasty.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
08-19-2014, 01:02 PM | #1065 |
Dont bother cleaning just get a new tank !
08-19-2014, 01:22 PM | #1066 |
I'm not fooling with this tank, which is why I put the filter in. Its quick and easy to clean out with its replacement filters. Didn't think it get that dirty this quick though.
I already have this to go with this
08-19-2014, 02:57 PM | #1067 |
Old member
That's cool!
08-19-2014, 03:19 PM | #1068 |
Well, since you don't object, I went in for a little more P-Shop. You can probably tell why. :lol
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 08-19-2014 at 03:26 PM. |
08-20-2014, 08:22 AM | #1069 |
I came back from saying good bye to Pops , went by the paint jail where they've actually begun taking my truck apart , boy howdy is that rust bad ! . they said they'll begin bead blasting my new cab Thursday 8/28 .
Looking at those fresh cylinder heads , looks good . Mostly what the DIY'er can do best without ruining the heads by over porting is : unshroud the valve bosses as this is the # 1 pinch point in flow both intake and exhaust . Never polish the intake ports ! they need to be rough to maintain the fuel mix ~ polishing the intake tracts allows fuel mist to separate and cling to the tract walls . Polishing the exhaust ports and matching them to the exhaust manifold/header size gives HUGE gains in flow .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-23-2014, 10:10 AM | #1070 |
Just got these back from getting PC'ed......
08-23-2014, 10:50 AM | #1071 |
It's a good news, bad news thing.
Good news. Brought something home from vacation. It's a 6.0L and a 4L80E. It's amazing how cheep things are once you get out of California. Bad news. When I got back, my Suburban was supposed to be out of the paint shop. He has not touched it any further. Then I'm told, "I need $9400.00 more or I won't finish it". I am already into it for over $5000.00 and supposed to pay $2500.00 more. So, it came home. The outside looks close to done, inside needs work. Anybody know a good reasonable painter in the San Bernardino area? |
08-23-2014, 02:51 PM | #1072 |
Old member
I have the motor cover about done. I also have a new pan for the electric fans to install also.
Cover will go back to shop on Monday to have the front piece weld on it. Drove the truck this morning and it ran fine didn't notice any heat build up at all and temp gauge read just fine.
08-23-2014, 02:51 PM | #1073 | |
Painter and reasonable... those two words never go together...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
08-23-2014, 05:49 PM | #1074 |
I worked on getting the interior floor cleaned out today & getting it ready to install the sound deader, new carpet and new seatbelts. The seat is at the upholstery shop getting done. It's going to look great after it's all done. I set the carpet in there temporary just to see how it's going look.
"Now all I need is a shop to go with my shop vac!" |
08-24-2014, 05:06 PM | #1075 |
Hung my cleaned up driver's side fender today.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
