#1051 |
![]() Join Date: Sep 2017
Re: "Project Orangepeel" 52 A.D
Very nice and the colors look great.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#1052 |
love the attention to detail. your truck has it everywhere. nice job.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#1053 |
8Man Thank's
99 Thank You I appreciate that! Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1054 |
![]() Join Date: May 2007
shes really a beaut mark!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#1055 |
Thanks Russ!
#1056 |
![]() ![]() Join Date: Oct 2014
#1057 |
#1058 |
![]() Join Date: Sep 2016
Digging the gold and the engine. I'd be too keen to start it up just to hear that rumble haha. Too early yet though. What's next on the bucket list and have you done any more to the interior?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#1059 | |
#1060 |
I picked up the cap from Summit.
https://www.summitracing.com/parts/bkc-48-9606?seid=srese1&gclid=CjwKCAjw36DpBRAYEiwAmVVDMLtvC5roPoCY7wmk1DSN7KVSTSh6e5kK899i8AEJCTbakXY8q__rO BoC4R8QAvD_BwE As far as the interior goes I am in the middle of several things in the works. power windows,A/C,door pulls,inside levers for the doors and still need to build my console. Mark
#1061 |
Biker's Choice Screw-In Type Pop-Up Vented Gas Caps 48-9606
Biker's Choice 48-9606 - Biker's Choice Screw-In Type Pop-Up Vented Gas Caps View All Media https://static.summitracing.com/glob....jpg?rep=False https://static.summitracing.com/glob....jpg?rep=False $59.99
#1062 |
#1063 |
Post Whore
![]() ![]() Join Date: May 2015
Manual steering...manual brakes...but power windiws???....come on Mark...haha
#1064 |
![]() ![]() Mark
#1065 |
pic 1. These are my coil pack mounts I made.
I used 1/4-20 threaded rod and steel tubing I cut to length as spacers. Pic 2,3 a few more shots of the brackets.
#1066 |
Here are a few closer shots of the brackets and them.mounted to the crossmember on the sides of the motor.
#1067 |
Well look what showed up on Amazon this week
#1068 |
Awesome,good luck with the new project!
Mark
#1069 |
Playing with fitment. The stake pocket has a lot more room than I thought! Going to run some exhaust pipe to the bottom since that will be permanent. Then I can run rubber from the bottom of the pipe to the tank for replacing it in 20 yrs when the fuel hose dries out.
#1070 |
looking good!
#1071 |
Don't know if I noticed in your earlier post. How did you handle the vent tube since its a venting cap. Did you just tie it back into the filler hose??
#1072 |
haven't done anything with it yet till I finish the fuel system.
Mark
#1073 | |
#1074 |
Yes it takes alot of planning,I must say.
If you have welding TIG wire or metal hangers you can make templates for the shapes you need to make the corners etc. Mark
#1075 |
Update:
Pic 1. I cut a large access hole for installing the power windows units. And used 1x1 tube to reinforce the door. Pic 2. Window unit mocked up. Pic 3. Painted with POR. Pic 4. All painted and insulated Pic 5. Before installing the door I put the door seals on as well. Mark
