Old 03-05-2014, 10:23 AM   #1076
Lowl!f3
Lowl!f3's Avatar
Re: intro + 66 black bagged long fleet
well I still have time. I just got my 65. So all the possibility research and questions are flying right now.
Anyone know if they sell drop spindles for the 65 so tou keep the six lug and drum brakes?
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 03-05-2014, 01:14 PM   #1077
Slammed66
Needs a Big Block
Slammed66's Avatar
Yea , you can use newer drop spindles, say 73-87. And there are aftermarket 6 lug rotors that will slide right on.
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 03-08-2014, 10:01 AM   #1078
coulter
coulter's Avatar
Originally Posted by Bomp View Post
Are you welding the front wheel tubs on the inside and out? Lookin' good.......Real Good
yessir i am.. dont know if it is necessary but i love to overdo stuff.
ive been slacking lately so im still not done with them...i will get more pics when i finish them up
Coulter first I would like to say I like your work so far. Maybe I missed the info. So I guess I will ask a few questions to clear it up for me.
1. What size bags did you use on your truck? 2600 up front and 2500 rear?
i used slam specialties ss7 all the way around.. it rides like a cloud!!!
2. The drop spindles are for/from what year model?
i got mine from a buddy. they came off of a 67-72 c10. cant remember the brand
3. Did you use original upper and lower control arms?
If you did. Do you have to swap ball joints? To which ones?
yes i used my stock control arms that came with my truck
i really cant remember for sure if you have to change the balljoints because there is a difference but i did anyway..i think the only thing that is different on the spindles i bought some for the 67-72 chevy truck. make sure you get moog balljoints if you buy some cause they pivot more than the cheapos so they wont bind up on a bagged truck
4. What is the lower control arms pocket depth?
at the wide end of the control arm it is 3" deep and the narrow end it is 2" deep. ive seen other people just go 3" the hole way but it seems like the bag sits flatter the way i did it
5. What is your rearend from?
stock rear end
6. Did you fab the step notch or buy one?
made my own.. its a little smaller than most of the ones you buy
7. Are the trailing arms longer on long bed then short bed trailing arms?
im not completely sure but i think the arms are the same for both
Originally Posted by NEWFISHER View Post
You know people love your build when their questions list is this long LOL!
Good work Coulter!
hahaha thanx
Originally Posted by rusty76 View Post
I know that is right^^^^
Thats right! And i still need some answers
sorry man ive been slacking big time on my build thread lately. ive been getting alot done this past week so it will be a runner again in no time
Originally Posted by Ta2Don View Post
Can't say for sure, but if Coulter is as busy pushing ink, as we have been in my studio, it may be a minute before he surfaces…
lol ya i have been pretty busy with tattoos lately. do you tattoo also???
Originally Posted by McMurphy View Post
Income Tats time of year....
i just got some new ones the other day
updates real soon.. the engine and trans are back in..
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 03-08-2014, 10:10 AM   #1079
Ta2Don
Ta2Don's Avatar
Updates Coming...
and yes, been tattooing for the past 23 years
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 03-18-2014, 06:31 PM   #1080
coulter
coulter's Avatar
o sweet man its always cool to see another artist do you have a website or anything? what shop do you work at?
well sorry not many pics but a lot of work has been done lately..
here is a short list of other mods i did to make the engine fit how i wanted it to without the oil pan hitting the ground when layed out.
installed 8" deep oil pan (had a 9" pan)
spaced the engine mounts up 1/2" and slotted the holes a little more to move the engine back a 1/2" also (needed more room for a flex fan)
the crosslink for my steering was hitting the oil pan so i had to mod it to make it fit (picture below)
modified the tranny crossmember for more room for the exhaust and also made it two peices cause it was near impossible to get it in and out without removing the exhaust.
here are a few pics
tranny crossmember mod. since i made it thinner i welded some flat stock on the front and back to help beef it up. It is super easy to install now
everything is hooked up and ready to go except for the radiator. I had to move the mount and little bit further forward to clear the new fan..
btw i went with the flex fan because at idle it would start to heat up with that electric fan. i plan on running both fans just in case. i also added a different tranny cooler instead of trying to use the radiator to cool the engine and tranny so it should be good to go now
new tranny cooler. not real sure if i need a fan on this??? i was thinking of making a little scoop that will direct air toward it while going down the road. anyone have experience with one of these?
steering u joint welded in place. installed new bearings in the column and shortened the shaft an inch shorter than stock so i could adjust the column more forward to get the steering wheel further away from me
here is the steering crosslink after i modded it.. i welded it back together then went overkill by adding gussets and boxing it in all the way around where it was welded together cause i dont wanna take any chances
all i really have left now is finish the wheel tubs. mod my hood hinges some more and install the front clip and radiator
Old 03-18-2014, 06:57 PM   #1081
Ta2Don
Ta2Don's Avatar
You have been busy...
DON
Proverbs 27:17
Old 03-18-2014, 07:07 PM   #1082
jdoisher
jdoisher's Avatar
Lone Star Round Up?
http://67-72chevytrucks.com/vboard/s...d.php?t=531177
Maggie's truck!
jdoisher is offline   Reply With Quote
Old 03-19-2014, 12:54 AM   #1083
Fattback
Fattback's Avatar
Looking great.
Rob
Fattback is offline   Reply With Quote
Old 03-19-2014, 04:32 PM   #1084
rusty76
rusty76's Avatar
Kool man. I have been hoping everyday we would see some updates. Killer work as always.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-19-2014, 04:41 PM   #1085
1963c-10
1963c-10's Avatar
Very nice fab work and mods. Killer build you have going on.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-22-2014, 06:51 AM   #1086
66PANEL
66PANEL's Avatar
Hey Coulter I just got to say ur a bad ass! I really dig what u've done and ur bike's r bad ass to! I got a road king that I've always wanted to suicide, but anyway u've given me a lot of new ideas! Thanks this tread has been inspiring to me!
66PANEL is offline   Reply With Quote
Old 03-23-2014, 11:45 AM   #1087
chad64chevy
chad64chevy's Avatar
I'm digging the updates, truck is looking good!! tattoos look bada$$, I don't have any experience with the trans cooler, but I just got my 18" dual pass one in the other day, haven't installed it yet either! I shortened my steering column 3in. also haven't finished that yet, I got a list of things I got to get done since I have a garage now
chad64chevy is offline   Reply With Quote
Old 03-26-2014, 01:49 PM   #1088
crossland1962
crossland1962's Avatar
I believe that this is the longest build page that i have read from start to finish! It only took me 3 days i never have more than a few minutes at a time! You have some SKILLS FOR SURE!!
crossland1962 is offline   Reply With Quote
Old 04-06-2014, 03:01 AM   #1089
coulter
coulter's Avatar
thanx for all the compliments and taking the time to read the whole thread
well the truck is running again and im just about done with everything. sorry ive been slackin on the updates..i went for a cruise today and snaped a few shots real quick. i didnt take any of the new front wheel tubs since i got them done but i will get some tomorrow and im gonna post a few progress pics from the last few weeks
also i got my rear cokers today. i couldnt be happier with the sizes of the tires i picked and the new stance!!! i love it
anyway here are the ones i took today
Old 04-06-2014, 03:22 AM   #1090
JJ's Sierra Grande
JJ's Sierra Grande's Avatar
As usual Coulter, you have the best pics on here.
JJ's Sierra Grande is offline   Reply With Quote
Old 04-06-2014, 06:44 AM   #1091
FrankyV8
Awsome truck, and damn what lovely pics.
FrankyV8 is offline   Reply With Quote
Old 04-06-2014, 11:15 AM   #1092
Jeff La
Awesome pics.
Jeff La is offline   Reply With Quote
Old 04-06-2014, 12:20 PM   #1093
likaroc13
Rollin' Old Skool
Cool pics, & the truck continues to look more killer each time you post!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 04-06-2014, 12:36 PM   #1094
66Dually8.1
Nice Ride lots of work!
66Dually8.1 is offline   Reply With Quote
Old 04-06-2014, 01:59 PM   #1095
rusty76
rusty76's Avatar
Nothing I would change. Love the truck, love the look. Killer work as always.
My build thread
Crossmembers CC
Old 04-06-2014, 02:40 PM   #1096
coulter
coulter's Avatar
thanx guys!!!!! here are the pics of the wheeltubs i promised.. plus a few bonus detail shots
[IMG]https://farm4.staticflickr.com/3686/13673115413_cc1dae24c4_c.jpg
[/IMG]
welded both sides
had to do some rust repair
filled in the cutout about 1/2" to make it less noticeable that i lowered the bumper
and here is how they turned out
dont worry ive got a cool idea on how to get my centercap mounted up since it wont fit right now.. that is coming soon
i used stainless this time for the trim peice so i can polish it up
had to trim the hinges even more. i welded on some 1/8th thick x 1/2 wide flat stock to beef it up a little bit.
also drilled some holes to make it match the latch plate.
ok here are all the bonus shots! enjoy
[IMGhttps://farm8.staticflickr.com/7216/13673085085_bd70cbcfac_c.jpg[/IMG]
[IMGhttps://farm4.staticflickr.com/3797/13673129033_3b4bed22f5_c.jpg[/IMG]
thats all for now.. dont worry i still have plenty of ideas coming soon
Old 04-06-2014, 02:47 PM   #1097
McMurphy
McMurphy's Avatar
Well.
No wonder you been so quiet around here, busy busy !!
Your work is so ....... wow.
Yep, thats all I got
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-06-2014, 03:00 PM   #1098
coulter
coulter's Avatar
haha ya ive been working like a mad man lately. i dont want to miss out on any more shows!!!
Old 04-06-2014, 03:54 PM   #1099
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-06-2014, 08:29 PM   #1100
rusty76
rusty76's Avatar
Looks great. I like the drilled hinges.!
My build thread
Crossmembers CC
