Old 09-02-2018, 12:22 AM   #1126
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Originally Posted by mud.man.rj View Post
Truck and colour looks great, love the wide rear tubs.
Mudman.
Thank you mud man
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 09-02-2018, 12:45 AM   #1127
smokedat
smokedat's Avatar
Got around wrapping up the rear axle . I touched up the POR15 Silver areas I installed new stainless tub bolts and finalized the brake assembly, installed the brake pads. still amazes me the hole system works. From a Frankenstein mess of parts, No assistance from a specialized team one man show
Old 09-02-2018, 09:29 AM   #1128
LT7A
Absolutely. Something to be proud of. Parts from all over and now they look like they belong.
When you say tub bolts do you mean like at wheel tubs? If so, all good.
Reason I ask is that Jeep guys call the main body "the tub" and I'd be concerned if you used SS bolts at body mounts. I have some on the core support of my Cutlass that I re-did the front end on a long time ago and learned I need to replace. I didn't realize at the time that the stainless bolts were not up to the strength of chassis bolts.
Old 09-02-2018, 11:18 AM   #1129
smokedat
smokedat's Avatar
pics of the final assembly. Brake pads are in there really easy to install or remove there only held by the side studs on the caliper torqued to 40NM. Im going to keep that rear stance as it tucking nicely and still have like 2'' of travel before bottoming out
Old 09-02-2018, 11:50 AM   #1130
smokedat
smokedat's Avatar
Thanks. Yes the wheel tubs, I applied a bit of anti seize I know that Stainless bolts can bite in and be difficult to remove.
Old 09-03-2018, 08:27 PM   #1131
smokedat
smokedat's Avatar
Top got done, new knock censors and harness
Old 09-04-2018, 10:59 PM   #1132
smokedat
smokedat's Avatar
got a pic my wife wanted of the boys and the hot wagon i built for them next to dads truck.
Old 09-04-2018, 11:01 PM   #1133
smokedat
smokedat's Avatar
got a few pics of the engine. The intake manifold is not bolted yet, its primer white i will be painting it like a cream tone to match interior ulphostery
Old 09-04-2018, 11:22 PM   #1134
oldman3
oldman3's Avatar
Cool pic with the boys, engine looks great...Jim
oldman3 is offline   Reply With Quote
Old 09-05-2018, 08:50 AM   #1135
smokedat
smokedat's Avatar
Thank you Jim
Old 09-11-2018, 07:32 AM   #1136
mcbassin
Still Learning
mcbassin's Avatar
Very clean! Looks great Alex!
mcbassin is offline   Reply With Quote
Old 09-11-2018, 03:55 PM   #1137
z71se
Any new updates? This thing should really get some attention at the Brothers shows!
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 09-11-2018, 09:09 PM   #1138
Dads79GMC
Dads79GMC's Avatar
Oh ya!!!!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 09-11-2018, 09:35 PM   #1139
mongocanfly
Post Whore
mongocanfly's Avatar
Great looking install!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-12-2018, 08:56 PM   #1140
smokedat
smokedat's Avatar
Thanks everyone, it’s appreciated.
Progress is slow I only get to work on it on sundays. I did manage to align the alternator and space out the water pump cover. I also installed the alternator bullet pulley, and I installed an aluminum coil pack frame and the spark plugs
Old 09-12-2018, 08:58 PM   #1141
smokedat
smokedat's Avatar
Old 09-12-2018, 09:21 PM   #1142
smokedat
smokedat's Avatar
Here’s pic of the alternator spacing with new pulley
Old 09-12-2018, 09:50 PM   #1143
smokedat
smokedat's Avatar
I need to finalize the intake manifold, Il be painting it cream tone and change the the throttle body to a Holley 92mm and change the bottom seals and a new throttle link bracket form lokar
Old 09-12-2018, 10:17 PM   #1144
smokedat
smokedat's Avatar
I was contemplating a fabricated aluminum intake manifold like the Holley sniper, but that would require more mods to install a throttle bracket this had to be done secured bullet proof status and it would require that I redo my fuel delivery up to the fuel rails, at this point I’m done chasing out problems finding solutions to custom fit applications.
Old 09-13-2018, 08:18 PM   #1145
smokedat
smokedat's Avatar
Here are the components for my rebuild of the manifold.
Old 09-13-2018, 08:38 PM   #1146
z71se
You should chrome out the alternator. They can be taken apart easily.
Old 09-15-2018, 06:44 PM   #1147
smokedat
smokedat's Avatar
here with the painted manifold and new throttle body.
Old 09-15-2018, 06:51 PM   #1148
smokedat
smokedat's Avatar
Before and after
Old 09-15-2018, 06:53 PM   #1149
smokedat
smokedat's Avatar
The color tone got lighter after it fully dried. I will be doing my interior door panels and seats this color Santa Fe
Old 09-17-2018, 11:44 AM   #1150
mud.man.rj
mud.man.rj's Avatar
Your truck will be so beautiful you may not want to drive it, but sure hope you do....a lot.
Really coming along nicely, appreciate your attention to detail.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
73c10, c10, cheyenne, ls1, swap
