Old 08-08-2013, 05:40 PM   #1126
gdavis
gdavis's Avatar
Re: 1968
today I installed the steering column. It was not as bad as I thought it would be.
Also I installed the dome light. Had to fish the wires thru the back of the roof. Ran into a hornets nest at the dome light hole and they ran me out of the cab. But no more hornets now.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 08-09-2013, 07:30 PM   #1127
gdavis
gdavis's Avatar
Re: 1968
I'am not in love with this steering column. It is real hard to go in reverse. But I will let it be untill I have the truck running. I also installed the shifting linkage.
I got the collaspible steering shaft coming my way.
This next week I should have several parts coming in. Maybe I can get something done.
I got the new hasard knob coming. Going to try and drill and tap the new knob on the red part where it broke off. I don't want to spend anymore on this column. All I did was bought someone else's problems.
Check out Patches
Old 08-09-2013, 11:58 PM   #1128
Xeen
Xeen's Avatar
Re: 1968
George does the gear selection on the column work smoothly and without resistance when the shift linkage isn't connected?
If it does then it's probably not the column at fault it's more likely the shift linkage binding up, you need to check to see if the angle at which the rod is at is causing problems, you may have to bend the rod so it is at the proper angle.
I had to put a significant bend into mine to get it to line up properly so there was no binding.
If you look closely you can see the bend in the rod.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-10-2013, 09:36 AM   #1129
gdavis
gdavis's Avatar
Re: 1968
Yea the shifter work good untill I try to put it in reverse even when it is not connected to the linkage. It works the same way with the linkage. I know it is not the linkage. It has a hard time getting accross the reverse part of the column.
Check out Patches
Old 08-10-2013, 07:01 PM   #1130
gdavis
gdavis's Avatar
Re: 1968
I looked at the shifter linkage with a new eye. It is a little off. So witha little adjustment I manages to get reverse. But the park is another question. So i think I will odered a new shifter linkage. From some one. don't know yet. I do know I don't want the stock one. I think that is a big part of my problem.
I also installed my lower radiator hose. And the replacement plate where the old 68 e-brake attaches. With a new rubber stopper where the brake pedal arm hits.
Check out Patches
Old 08-10-2013, 11:50 PM   #1131
darkhorse970
darkhorse970's Avatar
Re: 1968
Very nice work !
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 08-11-2013, 02:40 PM   #1132
cubber
Re: 1968
looks good, George. I need to try to find my battery box. I relocated my battery to the bed, so I don't need the tray anymore. If I can find it, and you can use it, you can have it.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 08-11-2013, 03:27 PM   #1133
Xeen
Xeen's Avatar
Re: 1968
Generosity at it's finest!
Old 08-11-2013, 04:25 PM   #1134
gdavis
gdavis's Avatar
Re: 1968
Thanks so much guys. I enjoy reading your builds. I am having trouble with my column. It is hard to go into park. Even when it is not conected to the shifer linkage. It will not pull to the steering wheel to push into park. I can take a screw driver and stick between the forks and I can see the shifter move towards the steering wheel just like it suppose to. If I shove it hard enough it will go. But that is not how it should be. I seen someone with only one fork. I have two. One for the transmission to shift and one for the park. Could I remove the park fork? Has anyone experenced this before? Instead of removing the fork could I just grind the little tab where it rides over the fork? To go into park.
Check out Patches
Old 08-11-2013, 06:46 PM   #1135
Xeen
Xeen's Avatar
Re: 1968
George you need to call me so I can explain what the column looks like on the inside and explain to you how it works, I have a pretty good idea why it is binding.
Ok I'm going to try to explain this the best that I can.
The gear selector relies on a cam sprocket that prevents the transmission from jumping out of gear.
The cam sprocket has a spring washer behind it that puts tension on it so it can only be in two positions engaged and disengaged.
My guess is the spring washer is missing or damaged which is causing the cam sprocket to bind.
Old 08-12-2013, 06:13 PM   #1136
gdavis
gdavis's Avatar
Re: 1968
I took the column apart and found a little worn out parts. I had another one here and used the parts from it. Works as good as it can for now. I need to get a new shifter linkage. The one I have is 46 years old and needs replaceing. I put it all together and installed it and had to remove it for It didn't line up just right. but the third time was a charm.
Check out Patches
Old 08-13-2013, 08:48 PM   #1137
gdavis
gdavis's Avatar
Re: 1968
Today some parts came in.
Both rear brake lines
Both rear view mirrows with extra arms.
I will install the brake lines tomorrow. I wrap the mirrows in some cloth and put them up untill I get ready for them. I need to start installing stuff for I am running out of room.
Check out Patches
Old 08-14-2013, 12:08 AM   #1138
Mustard72
Mustard72's Avatar
Re: 1968
Looking good George. August 24 is right around the corner.
I'm out of room, too, and my wife has requested that we be able to get at least one car in the garage this winter. Making room by installing parts is awfully fun, though, isn't it?
A couple of pages ago, you mentioned replacing the rubber boot on the brake pushrod between the firewall and the booster. Where did you get the boot? Local parts store? I haven't seen one on line anywhere. Granted, I haven't looked to hard yet, but still...
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 08-14-2013, 07:26 PM   #1139
gdavis
gdavis's Avatar
Re: 1968
yea it is. week inn afte the next. I had mine. Just forgot to install it when I put it together. sorry
Check out Patches
Old 08-14-2013, 07:35 PM   #1140
gdavis
gdavis's Avatar
Re: 1968
Today i installed the last two rear brake lines. I AM DONE WITH THE BRAKES. except for bleeding them.
here is a picture of the mirrow and arms I got in the mail yesterday. I was going to paint the mirrows orange, but the price of the mirrow were great so i will leave them chrome. The arms I really have not made my mind up on them. orange or black what do you guys think????????
In one of the pictures you can see a 1/2 inch gap between the steering wheel and the column. Is that normal just asking. also I had a extra set of mirrow arms that I got from a trade. So I sold them and made a difference for the good set I bought. The good set cost me half what they would have cost. Love it when somethings come together.
Check out Patches
Old 08-14-2013, 09:31 PM   #1141
Xeen
Xeen's Avatar
Re: 1968
Hey George;
The gap between the column and the steering wheel can't be helped because that steering wheel wasn't designed for that column.
As far as the mirror arms go I would paint them orange because they would look out of place if they were black considering everything else is orange.
Old 08-15-2013, 04:55 PM   #1142
gdavis
gdavis's Avatar
Re: 1968
Originally Posted by Xeen View Post
Hey George;
yea that really sucks. Oh well It will do untill I find a 68 wheel cheap.
Check out Patches
Old 08-15-2013, 11:11 PM   #1143
cubber
Re: 1968
You'll be on the road soon!
=MATTHEW
Old 08-16-2013, 07:26 PM   #1144
gdavis
gdavis's Avatar
Re: 1968
I sure hope so. I am planning on intering it in the Christmas parade in Crystal River this year.
Check out Patches
Old 08-16-2013, 07:31 PM   #1145
gdavis
gdavis's Avatar
Re: 1968
Today I went over to a friends house and got another vent window frame, sun visor rod and a few odd and end parts. I had three vent windows stored over there and none of them were any good. All for free he is a good guy. We help each other out a lot. Freinds like him don't grow on trees. Brian I might have a new set of parking brake arms coming my way this next week. I will let you know.
Check out Patches
Old 08-17-2013, 03:45 PM   #1146
gdavis
gdavis's Avatar
Re: 1968
Well I finshed sand blasting the visor rods and the vent windows frames. Here is the results of my work thus far. Monday I will paint them orange so the paint will have time cure before I try to install the glass. This will give me time to order all the parts I need to fix both vent windows and seal for both doors.
Check out Patches
Old 08-17-2013, 05:55 PM   #1147
Xeen
Xeen's Avatar
Re: 1968
Very nice George, I like the attention to detail.
Old 08-17-2013, 08:47 PM   #1148
gdavis
gdavis's Avatar
Re: 1968
thanks Brian
Check out Patches
Old 08-17-2013, 11:28 PM   #1149
cubber
Re: 1968
I found something for you today!
=MATTHEW
Old 08-18-2013, 10:49 AM   #1150
gdavis
gdavis's Avatar
Re: 1968
I sent you a PM.
Check out Patches
